Grob 109
Old September 14th 08, 03:02 PM posted to rec.aviation.soaring
Brien
Default Grob 109
Thinking of buying a 109A need to know the good the bad and the ugly of it.
Just what do I need to know about it, I have had people say stay away from
it others say it is good if you know how to fly it ?
Old September 14th 08, 03:11 PM posted to rec.aviation.soaring
John Smith
Default Grob 109
The first question you must answer is what do you want to do with it.
(Yeah, fly, I know... but what kind of flying.)
Old September 14th 08, 04:26 PM posted to rec.aviation.soaring
brianDG303
Default Grob 109
Old September 14th 08, 05:15 PM posted to rec.aviation.soaring
Cats
Default Grob 109
Old September 15th 08, 02:58 PM posted to rec.aviation.soaring
Andreas Maurer[_1_]
Default Grob 109
On Sun, 14 Sep 2008 09:15:27 -0700 (PDT), Cats
I was
told it is well capable of doing aerotows of quite heavy gliders.
Onle the G109 Turbo which is equipped with a Limbach 2400 DT engine
with 135 hp (compared to its standard engine of 80 or 100 hp).
Bye
Andreas
Old September 15th 08, 04:03 PM posted to rec.aviation.soaring
John Smith
Default Grob 109
I'm not sure this option is available for the A model. The turbo charged
engine surely transforms the B model into a pretty powerful touring
airplane and adds tow capability. (Range around 500nm, cruise speed 110
knots, fuel consumption between 4 and 4.5 gph, and service ceiling over
18.000 ft!) I sometimes use it in winter to do "power flights" on my
glider pilots license. I rarely fly it in glider mode.
These numbers are with the new supercharged engine. This new engine
isn't exactly cheap, though.
Old September 16th 08, 04:45 AM posted to rec.aviation.soaring
chris
Default Grob 109
I was wondering if anyone has fitted winglets on the 109, it seems
like that might help control effectiveness and maybe add to climb
[power on and off].
Chris
Old September 16th 08, 01:54 PM posted to rec.aviation.soaring
Andreas Maurer[_1_]
Default Grob 109
On Mon, 15 Sep 2008 17:03:27 +0200, John Smith
You are correct - the new Limbach/Korff engine (the turbocharger was
actually developed by Korff who also does the retrofitting) is only
available for the 109B.
Unfortunately - but there have been one or two used 109 Turbos for
sale which were in the 60.000 - 70.000 Euro range, which is
affordable.
Bye
Andreas
Old July 12th 19, 07:19 PM posted to rec.aviation.soaring
Default Grob 109
Hej jag undrar var typ skylten sitter på en Grov G109 jag hittar inte den
Old July 13th 19, 08:21 AM posted to rec.aviation.soaring
Default Grob 109
I delivered a 109A from Arizona to the east coast. Out west, it didn't do well with the density altitude. I could climb OR keep the engine at a reasonable temperature. It couldn't do both at the same time. It was more manageable once I got to lower elevations of the midwest.
Once you eventually get up to altitude, it does scoot along pretty well. That's about the only thing that it did well.
I worked a few strong thermals in Arizona, but you have to imagine flying a 2-33... ballasted to double its gross weight. I wouldn't plan on doing much soaring unless you live somewhere with strong conditions.
Its frankly not a very good airplane and not a very good glider. I'm not sure what your intentions and expectations are, but I think that most people would be better off buying a Cessna 150 and/or a Libelle.
Grob Bob O'Rilley Soaring 3 April 29th 05 07:22 PM
Grob G-102 maintenance Stephen Szikora Soaring 4 November 25th 04 09:49 AM
Grob 103 SL R.W. Carpenter Soaring 2 March 21st 04 10:21 PM
WTB Grob 109 b Steve B Soaring 10 July 21st 03 06:54 PM
GROB 102 Vorsanger1 Soaring 4 July 11th 03 11:34 PM
