It seems that a payout winch similar to those used for hang gliders
might be useful as a more efficient alternative to auto tows. You can make better use of the runway length and have perhaps a safer launch with proper calibration. Is anyone using such systems? Are they practical? Are they in fact better than a straight auto tow? |
Gary Boggs uses a payout winch system http://www.nwskysports.com/
wrote in message ... It seems that a payout winch similar to those used for hang gliders might be useful as a more efficient alternative to auto tows. You can make better use of the runway length and have perhaps a safer launch with proper calibration. Is anyone using such systems? Are they practical? Are they in fact better than a straight auto tow? |
BT, Bill, Ian, and Frank
Thanks for the comments. At our site, I am fairly certain that we could never use a reverse pulley because airport management wouldn't permit it. We might get away with a payout winch with a retrieve system so we could exit the runway quickly after the launch. I may be forced to visit Gary for a peak at his system. Pete BT wrote: Gary Boggs uses a payout winch system http://www.nwskysports.com/ wrote in message ... It seems that a payout winch similar to those used for hang gliders might be useful as a more efficient alternative to auto tows. You can make better use of the runway length and have perhaps a safer launch with proper calibration. Is anyone using such systems? Are they practical? Are they in fact better than a straight auto tow? |
wrote in message ... It seems that a payout winch similar to those used for hang gliders might be useful as a more efficient alternative to auto tows. You can make better use of the runway length and have perhaps a safer launch with proper calibration. Is anyone using such systems? Are they practical? Are they in fact better than a straight auto tow? It comes down to how much room you have and how fast you are willing to drive. The typical glider will need about 60kts from a tow car on a straight auto tow. That sixty knots will cover 6000 feet of runway in a minute. To that 60 kts, you have to add whatever speed you intend to use for rope payout. If you intend to pay out 2000 feet of rope in that minute, the car will have to go a third faster or 80 kts or 92mph. 92mph cuts your climb time to 39 seconds on a 6000' runway not allowing for acceleration and stopping distances. Of course you have to iterate these number again since you'll need to pay out that 2000 feet in only 39 seconds. You'll also need to add distance for accelerating and stopping the tow car. Ninty is already getting kinda fast for me but there's more. To that 92mph, you will need to add about 2% for each thousand feet of density altitude. Say your DA is 5000 feet then you need to drive the car at 101mph on a calm day (Don't even think about 10,000' DA's). Of course, if you have a 15 knot headwind, that drops it to 'only' 85 or so. So, if you are willing to drive that fast and have that much room, will it result in a usable release height? Probably. 39 seconds is enough to reach about 1800 feet AGL on a 2000' rope. Most people who have worked this out have a winch. A winch with 6000 feet of rope can deliver 3000 feet AGL and use only about a quart of fuel doing it. Bill D |
I have done a few launches behind Gary's payout system.
it is on awesome system from a functionality stand point in that you launch, wind up the rope and drive back to the starting point to set up for the next launch. The rope drags very little and setting up for the next launch is quick. I didn't see any advantage in runway length required. But then I was doing it on a 3 mile plus dry lake so it wasn't an issue and 2000 ft + tows were no problem. I suspect that on a 5000 foot runway it would be comparable to a straight auto tow in launch height. Brian HP16T |
Gents:
I have assumed, perhaps incorrectly, that a payout winch would have an advantage. If I have 2000 ft of cable on a spool and a 6,000 ft runway, the car with a payout winch use almost all of the 6,000ft runway length. Were we to do a regular auto tow, the car could only use 4,000ft of the runway to lift the glider. A reverse pulley would also give us the full 6,000 ft but, in our case, we can't use it because of runway management issues, not aerodynamics. Pete Brian wrote: I have done a few launches behind Gary's payout system. it is on awesome system from a functionality stand point in that you launch, wind up the rope and drive back to the starting point to set up for the next launch. The rope drags very little and setting up for the next launch is quick. I didn't see any advantage in runway length required. But then I was doing it on a 3 mile plus dry lake so it wasn't an issue and 2000 ft + tows were no problem. I suspect that on a 5000 foot runway it would be comparable to a straight auto tow in launch height. Brian HP16T |
On Sep 22, 11:53*pm, Pete Brown wrote:
Gents: I have assumed, perhaps incorrectly, that a payout winch *would have an advantage. If I have 2000 ft of cable on a spool and a 6,000 ft runway, the car with a payout winch use almost all of the *6,000ft runway length. Were we to do a regular auto tow, the car *could only use 4,000ft of the runway to lift the glider. A reverse pulley would also give us the full 6,000 ft but, in our case, we can't use it because of runway management issues, not aerodynamics. Pete Your airport designator? Frank Whiteley |
We've done thousands of payout winch launches at our airport, 4S2.
Even in no wind, we never have to drive over about 65mph. Fortunately though, the wind is always blowing here in the wind capitol of the world, Hood River, Oregon. Our winch works very well and has several safety advantages over a conventional winch. Airport management continues to be our biggest problem. Feel free to call me with any questions. My phone numbers are on my web site, along with some links to videos of our winch in action on YouTube. www.nwskysports.com |
Reciprocal auto tow works better the cable is pulled through a pulley at
the other end. as each launch is finished the car returns to the pulley end and picks up the other end of the cable ready for next launch. Some British clubs use a "Skylaunch" commercially built retrieve launch system see their web site. At 02:24 22 September 2008, Bill Daniels wrote: wrote in message ... It seems that a payout winch similar to those used for hang gliders might be useful as a more efficient alternative to auto tows. You can make better use of the runway length and have perhaps a safer launch with proper calibration. Is anyone using such systems? Are they practical? Are they in fact better than a straight auto tow? It comes down to how much room you have and how fast you are willing to drive. The typical glider will need about 60kts from a tow car on a straight auto tow. That sixty knots will cover 6000 feet of runway in a minute. To that 60 kts, you have to add whatever speed you intend to use for rope payout. If you intend to pay out 2000 feet of rope in that minute, the car will have to go a third faster or 80 kts or 92mph. 92mph cuts your climb time to 39 seconds on a 6000' runway not allowing for acceleration and stopping distances. Of course you have to iterate these number again since you'll need to pay out that 2000 feet in only 39 seconds. You'll also need to add distance for accelerating and stopping the tow car. Ninty is already getting kinda fast for me but there's more. To that 92mph, you will need to add about 2% for each thousand feet of density altitude. Say your DA is 5000 feet then you need to drive the car at 101mph on a calm day (Don't even think about 10,000' DA's). Of course, if you have a 15 knot headwind, that drops it to 'only' 85 or so. So, if you are willing to drive that fast and have that much room, will it result in a usable release height? Probably. 39 seconds is enough to reach about 1800 feet AGL on a 2000' rope. Most people who have worked this out have a winch. A winch with 6000 feet of rope can deliver 3000 feet AGL and use only about a quart of fuel doing it. Bill D |
| Collision Avoidance Systems for gliders | noel56z | Soaring | 21 | March 15th 07 02:45 AM |
| Winch Launch Stresses on Vintage Gliders | Mike Schumann | Soaring | 31 | January 30th 06 10:29 PM |
| LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 01:33 AM |
| Anti collision systems for gliders | Simon Waddell | Soaring | 2 | September 21st 04 09:52 AM |
| Winch launch | M B | Soaring | 0 | October 30th 03 08:33 PM |
