Does anyone know if there is an FTP or HTTP web resource where I can
download text-based, computer-parsable TFR descriptions on a regular basis? (I've surfed the FAA and AOPA web sites but can only find graphical versions.) Thanks ted in az usa asg-29 n8829a |
"Tuno" wrote in message
... Does anyone know if there is an FTP or HTTP web resource where I can download text-based, computer-parsable TFR descriptions on a regular basis? (I've surfed the FAA and AOPA web sites but can only find graphical versions.) Thanks ted in az usa asg-29 n8829a tfr.faa.gov has both text and graphical. As all TFRs are actually NOTAMs, you can get them from DUAT.com or DUATS.com also. |
Thanks Mike -- I was already aware of those; the problem is there is
no formatted TFR data that I can download and parse programatically. Whatever data is driving the graphical versions is what I'm interested in -- it just seems to be under lock and key somewhere. -ted |
... Thanks Mike -- I was already aware of those; the problem is there is no formatted TFR data that I can download and parse programatically. Whatever data is driving the graphical versions is what I'm interested in -- it just seems to be under lock and key somewhere. I'm not sure exactly what you're looking for, or what you're trying to do ultimately. I think you can still access DUATS via Telnet. If you access FDC NOTAMs only on the DUAT site, the TFRs are listed first, so perhaps it's the same via Telnet, but you may have to access each state individually and download a lot of other FDC NOTAMs you don't need, but perhaps this is a solution that might work for you. The FAA NOTAM server is located at the FAA command center. The FAA doesn't provide direct access. They disseminate the information via the tfr.faa.gov web site and to 3rd party providers like GTE DUAT and CSC DUATS. How AOPA and other providers get the information is anyone's guess, but I suspect they get it via Telnet from one of the 3rd party providers. |
On Thu, 23 Oct 2008 02:46:03 GMT, Mike wrote:
I'm not sure exactly what you're looking for, or what you're trying to do ultimately. Which has nothing to do with the fact you're a full fledged, home grown, born from birth ****ing idiot, does it? -- If you really must fellate me, Though the thought appalls; Remember work the shaft And cup the balls. http://tinyurl.com/krvrm |
Tuno wrote:
Does anyone know if there is an FTP or HTTP web resource where I can download text-based, computer-parsable TFR descriptions on a regular basis? (I've surfed the FAA and AOPA web sites but can only find graphical versions.) Thanks http://tfr.faa.gov/save_pages/notam_actual_notam number.html Where a notam number such as 8/4722 is encoded as 8_4722 giving a URL of http://tfr.faa.gov/save_pages/notam_actual_8_4722.html This gives the raw notam text within a HTML table. Since the notam text has a format of td FDC 8/5571 ZDZ .... /td it should be trivial to parse it out of the HTML. -- Jim Pennino Remove .spam.sux to reply. |
Jim: thanks -- this is new and good stuff, but I'm not sure it will
help me. The raw notam text is written for a human to read and make sense; it's not formatted in a regular (e.g. tabular) way that I can write a program to parse. Mike et al: Here's what I'm trying to accomplish: I have a web page that glider pilots use for getting specially formatted airspace data files that are generated from the FAA's NFD. (See www.justsoar.com.) For special soaring events, especially regional and national contests, I want to add a feature that appends TFRs to the product data files. To do this I have to be able to programatically download and parse data files (or web pages) that provide the TFR data in a precise, regular format, just like the NFD. (The NFD uses the ARINC specification 424-15, which describes Special Use Airspace polygons in terms of rhumb lines and arcs (e.g. from point A to point B around center C of radius X). I'm looking for the same style of descriptions for TFRs (and other NOTAMs).) -ted |
Tuno wrote:
Jim: thanks -- this is new and good stuff, but I'm not sure it will help me. The raw notam text is written for a human to read and make sense; it's not formatted in a regular (e.g. tabular) way that I can write a program to parse. Mike et al: Here's what I'm trying to accomplish: I have a web page that glider pilots use for getting specially formatted airspace data files that are generated from the FAA's NFD. (See www.justsoar.com.) For special soaring events, especially regional and national contests, I want to add a feature that appends TFRs to the product data files. To do this I have to be able to programatically download and parse data files (or web pages) that provide the TFR data in a precise, regular format, just like the NFD. (The NFD uses the ARINC specification 424-15, which describes Special Use Airspace polygons in terms of rhumb lines and arcs (e.g. from point A to point B around center C of radius X). I'm looking for the same style of descriptions for TFRs (and other NOTAMs).) -ted Good luck on that. TFR's are just notams, and while there is a consistant style to them, they are meant to be human readable. Parsing that text given the fixed style should be trivial for the TFR's that are circular. Irregular shapes would be a bit harder. However, there are also what I believe to be GIS files of some sort at http://tfr.faa.gov/save_pages/notam number.shp.zip where notam number is the same format as before. I think these are only available for TFR's that have been graphically mapped. -- Jim Pennino Remove .spam.sux to reply. |
![]() "Tuno" wrote in message ... Does anyone know if there is an FTP or HTTP web resource where I can download text-based, computer-parsable TFR descriptions on a regular basis? (I've surfed the FAA and AOPA web sites but can only find graphical versions.) Thanks ted in az usa asg-29 n8829a Doesn't AOPA display graphically all TFR's on their website? |
Yes, but again, I'm not interested in graphical versions. I want the raw data that drives them. |
A Free Source for US Airspace Data | 2KA | Soaring | 4 | September 20th 08 11:06 PM |
Digital airspace data question -- any FAA data gurus out there? | Tuno | Piloting | 2 | December 27th 07 05:06 PM |
source for Spectra? | [email protected] | Soaring | 1 | July 17th 07 02:29 PM |
Flight Data recorders on a 757 - What data? | Al Dykes | General Aviation | 0 | January 1st 07 05:09 PM |
FAA ATA-100 data source | Paul Tomblin | General Aviation | 0 | November 23rd 06 04:08 PM |
