Kestrel 19 Questions
Old October 28th 08, 02:52 PM posted to rec.aviation.soaring
Default Kestrel 19 Questions
Sorry for posting aircraft-specific questions in here, but I haven't
received any responses from my queries in the Kestrel401 forum.
I recently bought a Slingsby T59D Kestrel 19. Love the ship Okay,
it's big and heavy, but so am I.
I need to get my hands on the Addenda for the POH, specifically
numbers 3, 4, 5, 6 and 8. Does anyone have a copy that they could
photocopy and send to me (I'll pay costs), or scan and e-mail?
Slingsby wants 70 GBP for this -- am I naive in thinking that's rather
costly?
Secondly, I've read on-line that there is a modification to the
spoilers to add a second panel and (hopefully) increase their dismal
effectiveness. Does anyone have a copy of the information on how to
do this, and willing to share? Is the modification approved? How
effective is the new setup? The directions used to be posted at
gliderpilot.net, but it seems that the files section has not returned
up after the unfortunate problems earlier this year.
Thirdly, my weight and balance is "odd", to say the least. I've only
got a 9-lb range to stay within CoG limits, which seems fairly narrow
(same was true for the factory-delivered W&B). Granted, my previous
experience was with club ships (1-34, L-33, G-102) which had a wide
range. The plane has also flown 40 lbs under min. pilot weight (we
goofed) but flew beautifully -- certainly not like an aircraft beyond
aft CoG. Is this typical for the Kestrel?
TIA,
John
Old October 29th 08, 12:55 PM posted to rec.aviation.soaring
JJ Sinclair
Assuming a 36" root chord and an allowable CG range of (e.g.) 25%-40% of
root chord, you'd have an allowable range of CG movement of 5.4" and
there's no way a 9-lb increment will move you from outside front to
outside rear of such a range on a man-sized glider of Kestrel mass.
I'd agree with Bob, where'd the 9# come from? If the ship has been
repaired or re-finished, it could have gained significant tail weight
and this would require much more cockpit weight to stay within
published CG range. Guess that would/could bring the minimum cockpit
load up to within 9# of the maximum cockpit load? There is also a
maximum weight for non-lifting surfaces (fuselage + pilot) which could
be the limiting factor on the high side. Guess it isn't a deal breaker
as long as you hit the 9# range. I remember a Nimbus-3 that was in
about the same situation.
JJ
Old October 29th 08, 07:35 PM posted to rec.aviation.soaring
I think I'm running into the max weight consideration. I need to get
my calculation sheet and figure out the max pilot without considering
gross dry (on the weekend).
The factory W&B and placards indicate a pilot weight range from 221 to
229 lbs, with a ship empty weight of 731 lbs. The max landing weight
was 960 lbs, so the 229 pilot would hit gross dry weight. The W&B
calculations are designed to have min pilot weight giving full aft
CoG.
I removed 10 lbs of lead from the nose bulkhead -- had a Slingsby
stamp on it, so I guess it was installed at the factory. The tail has
been repaired, the rudder enlarged, and a repair to a wingtip. New
empty weight is 737 lbs -- which indicates 16lbs added for the various
repairs. Slingsby also upped the gross dry weight to 990lbs. The new
figures are not out of line from the factory, given the change of
weight locations (10 lbs out of nose, 15 added to tail).
My calculations give a minimum pilot weight of 243 lbs, and simple
math puts the max pilot at 253. I'll fully calculate the range when I
get to my papers.
However, the ship flew quite well with a 200 lb pilot -- he said it
handled beautifully. He should have been quite aft of CoG, but it
didn't handle like it was too aft... so what gives?
As an aside, why would the designers allow for only 80 lbs of water to
be carried? Hardly seems worth the effort (I can only carry 50 lbs).
I know one pilot wrote a while ago about modifying his Kestrel to
carry something like 250 lbs... what would that do to the legal status
of the aircraft when flying loaded? Insurance factors when trying to
land (over)loaded due to a rope break? Just wondering...
Thanks all,
John
Old October 29th 08, 08:24 PM posted to rec.aviation.soaring
math puts the max pilot at 253. *I'll fully calculate the range when I
get to my papers.
Found some figures.
CoG range is 11.5 - 14.76" aft of datum (leading edge at root)
Main wheel weight, 633 # at 2.5" aft
Tail wheel weight, 104# at 165.5" aft
Pilot sits at 17.2" forward
Plug it into the formula, gives min pilot of 247.7# and a max pilot of
359.5# (but I'm limited to 253# due to gross dry weight). Of course,
I might be having an off day with the calculator (or messing up my
physics); my memory keeps nagging that it's 243 minimum from the W&B
pictures and formulae.
My test pilot at 200# gives a CoG of 16.39" aft... 1.63" beyond the
max aft allowable. Yet, the ship flew beautifully.
Very odd, I think.
Regards,
John
Old October 29th 08, 08:42 PM posted to rec.aviation.soaring
JJ Sinclair
John,
Recommend you get a new W&B with you in the cockpit. Some ships fly
quite well behind the aft limit (Nimbus-3), but the concern would be;
How well do they recover from a spin with an aft GC? Your removing
factory weight from the nose and known added aft weight (rudder) would
leave me nervous.
JJ
math puts the max pilot at 253. �I'll fully calculate the range when I
get to my papers.
Found some figures.
Very odd, I think.
Regards,
John
Old October 28th 08, 07:32 PM posted to rec.aviation.soaring
Bruce
T59D - Heavy on the ground but a pleasure in the air.
Some comments -
1] Why would you want extra airbrake?
There are two versions of the landing flaps, but from my experience the landing flaps are effective at establishing
steep descents. Just be aware the roll rate is a lot lower in landing flap.
The airbrakes are pretty weak on their own.
The drogue chute really brings you down fast - but make sure you have excess speed.
Throw airbrake, landing flap and the chute out and "if you can see it over the glare shield you cant get there" applies.
2] The one I fly does not have a tiny CG range, the allowable cockpit weight ranges from 79kg to 110kg. So - 9 pounds
where? - on the tail 9 pounds is quite a lot.
3] The anti balance tab on the elevator (Mod 9) allows aft CG limit to be 15.83 inches.
As an aside - You know who your real friends are the second time you ask for help rigging the T59D - Especially when
someone has lost the tool to pull the wings together...
If you manage to get any manual pages I would appreciate - the condition of 1771s is so poor they are virtually
unreadable. I sent you a copy of the BGA data sheet with the basic information directly.
My guess on real L/D is at least as good as the claimed 1:44.
costly?
TIA,
John
Kestrel Maintenance Manual Robin Birch Soaring 7 April 23rd 19 11:28 PM
FS: Glasflugel H401 Kestrel [email protected] Soaring 2 August 14th 07 05:52 PM
Epic vs Kestrel Kyle Boatright Home Built 0 August 3rd 06 03:19 AM
Slingsby Kestrel 19m Grant Johnson Soaring 1 July 27th 06 06:14 AM
Sierra Wave: Kestrel vs. 1-26 Ray Lovinggood Soaring 4 April 8th 05 02:24 AM
