How exactly did they work? Could the turrets be fired independently at
multiple targets? What crew members controlled them? etc? etc? |
"William Anderson" writes: How exactly did they work? Could the turrets be fired independently at multiple targets? What crew members controlled them? etc? etc? There were turrets in 5 locations - Upper Forward, Upper Aft, Lower Forward, lower Aft, and the Tail. A;; turrets were power operated, including teh tail. There were 5 Gunner's Stations on the aircraft - the Upper Gunner, who had a dome on top of the fuselage in the Aft Pressurized Compartment, and who acted as the coordinatoe. The Bombardier-Gunner, with a sight in the extreme nose. The Right and Left Side Gunners, with domes on wither side of the Aft Pressurized Compartment, The Tail Gunner, in a small pressurized cabn in the extreme tail. All Gunners hy gyroscopic lead computing sights with stadiametric ranging. As the Gunner tracked teh target, the gyroscopes measured the rate of movement of the target in Azimuth and Elevation, The Gunner would also track teh target in range, by using a "Motorcycle throttle" type grip in the sight to size a ring of dots in the sight picture to match the airplane's wingspan. Since the wingspan of an attacking fighter would be known, or estimated slose enough, this would give Range and Range Rate (Closing speed) information to hte sight. The sights fed their Azimuth/ Elevation/Range and Az/El/Range Rate data to the Central Fire COntrol computer, which was an electromechanical analog computer that would take the sight's data, the firing airplanes' current environment - (Altitude, Speed, Outside Air Temp, and produce a Firing Solution for that target. The computer sent teh xontrol signals to the turrets, which aimed the guns to correct for Lead, Gravity Drop, Jump, and the firing airplane's motion. Most sighting stations could control more than one turret. The Upper Gunner controlled both Foreward and Aft Upper Turrets. The Bombardier normally controlled the Lower Forward Turret. The 2 Side Gunners could trade off control of the Lower Aft Turret. The Tail Gunner controlled the Tail Turret. The Tail Gunner and Bombardier-Gunner each had deadman switches on their sights. If they did not have the deadman switch held cloased, their turrets (Lower Forward and Tail) could be controlled by the Side Gunners. The two Side Gunners had a switch box between them that would control which Side Station controlled the three turrets. Each sighting station could aim independantly, adn whichever turrets were available to that station when a target was designated would track and fire at teh target that the station was tracking. It was an amazing system, and once the original bugs were worked out, it worked quite well. The CFC system was also used on the B-50, which was basically an uprated B-29 with P&W R4360 engines. While the basic principals of remotely-controlled turrets and a computing sighting system was used on the B-36, teh B-36's gunners didn't control multiple turrets. (I don't know why for certain, but I'll bet that the -36 was so large that a Gunner just didn't have enough of a field of view to make it worthwhile. The B-45, B-47, and B-52, and B-66 all had only tail guns, radar aimed and computer controlled. On the B-47, the Gunner was the Copilot, who had the turret controls and radar displays on hte aft bulkhead of teh cockpit. His ejection seat swivelled around so that he was facing aft when he was working the guns. The other jets ahd dedicated gunners. Hope this helps. -- Pete Stickney A strong conviction that something must be done is the parent of many bad measures. -- Daniel Webster |
"William Donzelli" wrote in message om... (Peter Stickney) wrote in message ... All Gunners hy gyroscopic lead computing sights with stadiametric ranging. As the Gunner tracked teh target, the gyroscopes measured the rate of movement of the target in Azimuth and Elevation, The Gunner would also track teh target in range, by using a "Motorcycle throttle" type grip in the sight to size a ring of dots in the sight picture to match the airplane's wingspan. Since the wingspan of an attacking fighter would be known, or estimated slose enough, this would give Range and Range Rate (Closing speed) information to hte sight. To add to this fine explanation, starting right around the beginning of 1945, AN/APG-15 radars started making there way in B-29s. This was a fairly small, cheap set that took much of the guesswork for figuring range out of the gunners hands (although they could always go back to the manual method, especially when the radars broke down). True, but the radars were only installed on the B models during WWII, meaning that they were largely limited to use by IIRC the 315th BW. The remainder (and vast majority) of the Superfort fleet soldiered on with the purely optical system. Note that the 315th BW is apparently the major source of the oft-repeated apocryphal tale that all the B-29's had their guns (except for tail mount) stripped and went into battle with reduced crews at Lemay's behest; apparently that might have been the case for the 315th, or a goodly portion of it, but little evidence exists that any of the other bomb wings followed suit. Brooks -- William Donzelli |
"William Anderson" wrote in message ...
How exactly did they work? Could the turrets be fired independently at multiple targets? What crew members controlled them? etc? etc? From 'Flying Guns: World War 2 - Development of Aircraft Guns, Ammunition and Installations 1933-45' by Emmanuel Gustin and myself: "The B 29 finally appeared with five turrets: Front upper, front lower, aft upper, aft lower, and tail turret; as initially foreseen the tail also had a 20 mm cannon in addition to the twin .50"s. The tail guns were exclusively controlled by the tail gunners in his own compartment, but the other guns were operated from four sighting stations, one in the nose and three in a compartment aft of the wing. Each gunner could simultaneously operate two turrets, as the situation of the moment demanded. The "master gunner" was the upper gunner in the aft compartment, and he assigned turrets to gunners with his control panel. The gunners had to track the attacking aircraft from their sighting stations, which had a reflector gunsight that generated signal outputs by a "Selsyn" system. An analog computer used the elevation, azimuth and range inputs from the gunner to calculate the lead and the parallax compensation, and aimed the gun turret with an Amplidyne drive unit. The computer took into account the effects the air density, the airspeed and the angle of the guns relative to this airspeed had on the bullet trajectory. A factor that could not be taken into account was the flexibility of the bomber's fuselage itself, and its tendency to expand or shrink locally as temperature varied. These caused a variable misalignment between the sighting station and the gun turret. The heating effect was large enough to make alignment of the guns on a butt outdoors, exposed to the sun, impracticable. The guns had to be harmonised indoors to meet specifications." Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
"Tony Williams" wrote in message m... "William Anderson" wrote in message ... How exactly did they work? Could the turrets be fired independently at multiple targets? What crew members controlled them? etc? etc? From 'Flying Guns: World War 2 - Development of Aircraft Guns, Ammunition and Installations 1933-45' by Emmanuel Gustin and myself: "The B 29 finally appeared with five turrets: Front upper, front lower, aft upper, aft lower, and tail turret; as initially foreseen the tail also had a 20 mm cannon in addition to the twin .50"s. The tail guns were exclusively controlled by the tail gunners in his own compartment, but the other guns were operated from four sighting stations, one in the nose and three in a compartment aft of the wing. Each gunner could simultaneously operate two turrets, as the situation of the moment demanded. The "master gunner" was the upper gunner in the aft compartment, and he assigned turrets to gunners with his control panel. Actually, I believe his title was "fire control gunner". I believe you are correct in stating that the tail gunner was the only crewmember who could fire the tail guns. The gunners had to track the attacking aircraft from their sighting stations, which had a reflector gunsight that generated signal outputs by a "Selsyn" system. An analog computer used the elevation, azimuth and range inputs from the gunner to calculate the lead and the parallax compensation, and aimed the gun turret with an Amplidyne drive unit. As Peter has already pointed out, the gunner also had to dial in the wingspan of the attacking aircraft (gunners spent a significant amount of time training on Japanese aircraft recognition and corresponding wingspan data); the navigator input the airspeed and air temperature data into the system. Brooks The computer took into account the effects the air density, the airspeed and the angle of the guns relative to this airspeed had on the bullet trajectory. A factor that could not be taken into account was the flexibility of the bomber's fuselage itself, and its tendency to expand or shrink locally as temperature varied. These caused a variable misalignment between the sighting station and the gun turret. The heating effect was large enough to make alignment of the guns on a butt outdoors, exposed to the sun, impracticable. The guns had to be harmonised indoors to meet specifications." Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
m... From 'Flying Guns: World War 2 - Development of Aircraft Guns, Ammunition and Installations 1933-45' by Emmanuel Gustin and myself: "The B 29 finally appeared with five turrets: Front upper, front lower, aft upper, aft lower, and tail turret; as initially foreseen the tail also had a 20 mm cannon in addition to the twin .50"s. The tail guns were exclusively controlled by the tail gunners in his own compartment, but the other guns were operated from four sighting stations, one in the nose and three in a compartment aft of the wing. Each gunner could simultaneously operate two turrets, as the situation of the moment demanded. The "master gunner" was the upper gunner in the aft compartment, and he assigned turrets to gunners with his control panel. The gunners had to track the attacking aircraft from their sighting stations, which had a reflector gunsight that generated signal outputs by a "Selsyn" system. An analog computer used the elevation, azimuth and range inputs from the gunner to calculate the lead and the parallax compensation, and aimed the gun turret with an Amplidyne drive unit. The computer took into account the effects the air density, the airspeed and the angle of the guns relative to this airspeed had on the bullet trajectory. A factor that could not be taken into account was the flexibility of the bomber's fuselage itself, and its tendency to expand or shrink locally as temperature varied. These caused a variable misalignment between the sighting station and the gun turret. The heating effect was large enough to make alignment of the guns on a butt outdoors, exposed to the sun, impracticable. The guns had to be harmonised indoors to meet specifications." When the Soviets reverse-engineered the Tu-4 BULL from the B-29, how successful were they at copying such systems? -- Andrew Chaplin SIT MIHI GLADIUS SICUT SANCTO MARTINO (If you're going to e-mail me, you'll have to get "yourfinger." out.) |
"Andrew Chaplin" wrote in message ... "Tony Williams" wrote in message m... From 'Flying Guns: World War 2 - Development of Aircraft Guns, Ammunition and Installations 1933-45' by Emmanuel Gustin and myself: "The B 29 finally appeared with five turrets: Front upper, front lower, aft upper, aft lower, and tail turret; as initially foreseen the tail also had a 20 mm cannon in addition to the twin .50"s. The tail guns were exclusively controlled by the tail gunners in his own compartment, but the other guns were operated from four sighting stations, one in the nose and three in a compartment aft of the wing. Each gunner could simultaneously operate two turrets, as the situation of the moment demanded. The "master gunner" was the upper gunner in the aft compartment, and he assigned turrets to gunners with his control panel. The gunners had to track the attacking aircraft from their sighting stations, which had a reflector gunsight that generated signal outputs by a "Selsyn" system. An analog computer used the elevation, azimuth and range inputs from the gunner to calculate the lead and the parallax compensation, and aimed the gun turret with an Amplidyne drive unit. The computer took into account the effects the air density, the airspeed and the angle of the guns relative to this airspeed had on the bullet trajectory. A factor that could not be taken into account was the flexibility of the bomber's fuselage itself, and its tendency to expand or shrink locally as temperature varied. These caused a variable misalignment between the sighting station and the gun turret. The heating effect was large enough to make alignment of the guns on a butt outdoors, exposed to the sun, impracticable. The guns had to be harmonised indoors to meet specifications." When the Soviets reverse-engineered the Tu-4 BULL from the B-29, how successful were they at copying such systems? Apparently rather successful--the same system was later used on their Tu-16 as well, IIRC. Brooks -- Andrew Chaplin SIT MIHI GLADIUS SICUT SANCTO MARTINO (If you're going to e-mail me, you'll have to get "yourfinger." out.) |
"Kevin Brooks" wrote in message ... Apparently rather successful--the same system was later used on their Tu-16 as well, IIRC. The Soviets did not need to copy the gun aiming system, as selsyn aiming was used in battle ships by 1920. Follow Stickney's lead and stick to cut and paste Kevin. |
| NAS and associated computer system | Newps | Instrument Flight Rules | 8 | August 12th 04 06:12 AM |
| Computer STAR/SID names | K. Ari Krupnikov | Instrument Flight Rules | 0 | July 21st 04 11:22 AM |
| Rag and tube construction and computer models? | BllFs6 | Home Built | 24 | April 12th 04 01:20 PM |
| CONRAC CORP C5A COMPUTER TEST SET | Mikel Giles | Military Aviation | 0 | February 7th 04 06:09 PM |
| The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 23rd 03 12:01 AM |
