No reply at all in 24hr on r.a.owning, so I'll try he
Anyone else have their Garmin 430 screen flash or blink white on them periodically. Noticable mostly at nite. Local hanger flying expert says it is well known and easy fix by any avionics shop. Anyone go through such a fix and know what's done? I flew with an 8 yo 430 install which had a continuous milk white bright screen, and later the owner got an internal battery replaced in an afternoon. Could that be the same? I want to be a bit informed before calling the avionics shop. |
"Mike Isaksen" wrote in message
... No reply at all in 24hr on r.a.owning, so I'll try he Anyone else have their Garmin 430 screen flash or blink white on them periodically. Noticable mostly at nite. Local hanger flying expert says it is well known and easy fix by any avionics shop. Anyone go through such a fix and know what's done? I flew with an 8 yo 430 install which had a continuous milk white bright screen, and later the owner got an internal battery replaced in an afternoon. Could that be the same? Never had that happen to me while in flight. However, after the WAAS upgrade, it does flash white during the boot-up process before the initial screen. Marco |
Thanks Marco. I'll look for that. Another poster mentioned a contrast
adjustment. I'll play before taking it in. Still at frg? "Marco Leon" wrote ... "Mike Isaksen" wrote ... No reply at all in 24hr on r.a.owning, so I'll try he Anyone else have their Garmin 430 screen flash or blink white on them periodically. Noticable mostly at nite. Local hanger flying expert says it is well known and easy fix by any avionics shop. Anyone go through such a fix and know what's done? I flew with an 8 yo 430 install which had a continuous milk white bright screen, and later the owner got an internal battery replaced in an afternoon. Could that be the same? Never had that happen to me while in flight. However, after the WAAS upgrade, it does flash white during the boot-up process before the initial screen. Marco |
... Thanks Marco. I'll look for that. Another poster mentioned a contrast adjustment. I'll play before taking it in. Still at frg? Yes. Are you at FRG? |
"Marco Leon" wrote ... "Mike Isaksen" wrote ... Thanks Marco. I'll look for that. Another poster mentioned a contrast adjustment. I'll play before taking it in. Still at frg? Yes. Are you at FRG? Yup, and it's sad with gas still at over $5/gal. |
I've heard of (and seen) that, although I thought it only affected
WAAS units, and possibly only after a firmware upgrade. If it's the same issue, go to the AUX page, Display, adjust the contrast lvl down to 90, and see if it still happens. If that doesn't fix it I'd call the shop. todd. On Nov 17, 1:25*am, "Mike Isaksen" wrote: No reply at all in 24hr on r.a.owning, so I'll try he Anyone else have their Garmin 430 screen flash or blink white on them periodically. Noticable mostly at nite. Local hanger flying expert says it is well known and easy fix by any avionics shop. Anyone go through such a fix and know what's done? I flew with an 8 yo 430 install which had a continuous milk white bright screen, and later the owner got an internal battery replaced in an afternoon. Could that be the same? I want to be a bit informed before calling the avionics shop. |
Thanks, I'll give that a try. It is a WAAS upgraded unit. I'm new to the
plane, but the other partner who went thru the upgrade thinks he saw it before the mod. "tjd" wrote ... I've heard of (and seen) that, although I thought it only affected WAAS units, and possibly only after a firmware upgrade. If it's the same issue, go to the AUX page, Display, adjust the contrast lvl down to 90, and see if it still happens. If that doesn't fix it I'd call the shop. On Nov 17, 1:25 am, "Mike Isaksen" wrote: No reply at all in 24hr on r.a.owning, so I'll try he Anyone else have their Garmin 430 screen flash or blink white on them periodically. Noticable mostly at nite. Local hanger flying expert says it is well known and easy fix by any avionics shop. Anyone go through such a fix and know what's done? I flew with an 8 yo 430 install which had a continuous milk white bright screen, and later the owner got an internal battery replaced in an afternoon. Could that be the same? I want to be a bit informed before calling the avionics shop. |
| Garmin 430 screen flashes | Mike Isaksen | Owning | 0 | November 16th 08 06:00 AM |
| Garmin Pilot III screen fault | d&tm | Piloting | 4 | February 6th 07 11:30 PM |
| Garmin iQue 3600a -- sunlight screen readability? | Chuck | Instrument Flight Rules | 7 | March 24th 05 11:00 PM |
| Garmin iQue 3600a -- sunlight screen readability? | Chuck | Piloting | 17 | March 24th 05 11:00 PM |
| Garmin 195 screen problem | BPattonsoa | Home Built | 30 | December 3rd 03 03:14 AM |
