Pretensioning cables
Old November 18th 08, 05:33 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Default Pretensioning cables
Anyone have a good method for pretensioning cables. There has been some
issues of late with 601Xl control cables getting loose after the first
few flights.
I'm looking for info on ways to pretension 1/8" galvanized cables that
are tensioned between 22 and 40 lbs.
Old November 18th 08, 06:31 PM posted to rec.aviation.homebuilt
Gregory Hall
"Gig 601Xl Builder" wrote in message
m...
issues of late with 601Xl control cables getting loose after the first few
flights.
I'm looking for info on ways to pretension 1/8" galvanized cables that are
Pre-tensioning cables is not possible. You must mean post-tensioning?
Gregory Hall
Old November 18th 08, 07:33 PM posted to rec.aviation.homebuilt
jan olieslagers[_2_]
m...
flights.
Must mean post-installation but pre-crash.
Old November 18th 08, 07:29 PM posted to rec.aviation.homebuilt
On Nov 18, 10:33*am, Gig 601Xl Builder
few flights.
Only once have I seen a pair of cables go slack soon after
installation, and I think (just an opinion) that there was a lot of
the heavy, waxy oil in the cable that squeezed out and let the strands
come together under tension. That would let them relax some. All the
other cables we've ever installed stayed tight. Are you sure there's
no deformation taking place in the control system? Or maybe they're
being tensioned in a warm shop, then the airplane goes out into the
cold and the aluminum shrinks more than the steel cable and they'll go
a little loose.
Dan
Old November 20th 08, 09:54 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
On Nov 18, 10:33 am, Gig 601Xl Builder
few flights.
a little loose.
Dan
Thanks Dan for the only straight answer. Am I sure there isn't any
deformation? No I'm not, because it hasn't happened yet to a plane I
have had access to. The people that have have said that no there is no
deformation.
In one case a plane was flown recently from Florida to South Carolina.
On arrival in SC the aileron counter balance cable was so slack that it
was unmeasurable with a tension gauge. From building the same design I
would have to think that enough deformation to loosen the cable that
much would be clearly visible.
This is an extreme example. Most is the reports are in the neighborhood
of 10-12 lbs change in tension.
Old November 20th 08, 11:17 PM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
few flights.
a little loose.
Dan
It is pretty amazing how much pressure a person can exert with their feet.
I believe the 601 control horns are 6061T6 extruded angle(?)
Just to be sure, make a careful inspection of the rudder and horns.
Make sure the attachments are still secure.
Richard
(remove the X to email)
The democracy will cease to exist when you
take away from those who are willing to work
and give to those who would not.
Thomas Jefferson
Old November 21st 08, 03:28 AM posted to rec.aviation.homebuilt
On Nov 20, 3:17*pm, cavelamb himself wrote:
"It is pretty amazing how much pressure a person can exert with their
feet."
My thoughts exactly!
It depends on the design of the control system (Independent pedals
vs a rudder bar). "Way back when", I had an issue with finding myself
putting way to much foot pressure on the rudder pedals. Finally
switching to something with toe brakes cured me fast!
Vaughn
Old November 24th 08, 05:50 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Bryan Martin wrote:
Bryan, I'd not noticed you on RAH before. You know the issue I'm asking
about. Maybe you can add something that I've left out that could help.
Old November 21st 08, 05:58 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Yep 6061T6. BUT the problem isn't showing itself in the rudder cables it
is in the ailerons.
Old November 21st 08, 09:22 PM posted to rec.aviation.homebuilt
Morgans[_2_]
is in the ailerons.
Wood wings, or metal?
Jim in NC
FS: Piper Jumper Cables Video Man Aviation Marketplace 1 January 29th 07 12:27 AM
Antonov control cables John Home Built 7 October 6th 06 12:40 AM
FS: Piper Booster cables Ottprivatesale Owning 0 July 11th 06 04:36 AM
unsticking cables dlevy Owning 12 January 8th 06 09:39 AM
MiG-29 cables alcatraz Military Aviation 0 March 1st 04 10:01 PM
