Hi Pilots,
I have a V2cxT that has the standard S-H disc brake that no longer works very well. I have been through the obvious fixes; pads, new fluid, bleed, etc. and haven't been able to bring it back up to original performance which was adequate but not stellar. I know a number of pilots have complained about this world-wide and S- H has issued a voluntary TN. The fix is to basically throw the old stuff away and replace everything including wheel and tire with the French-made Beringer system. Beringer makes performance brake systems for motorcycles, aircraft, etc. It is not cheap and probably not an easy install. Does any one have first hand knowledge about this fix? How easy is it to install and what are the performance gains? I hate to lay out the cash without an understanding of how much of an improvement I will see. Let me know, thanks. Bob |
On Nov 25, 9:33*pm, BravoCharlie
wrote: Hi Pilots, I have a V2cxT that has the standard S-H disc brake that no longer works very well. *I have been through the obvious fixes; pads, new fluid, bleed, etc. and haven't been able to bring it back up to original performance which was adequate but not stellar. I know a number of pilots have complained about this world-wide and S- H has issued a voluntary TN. *The fix is to basically throw the old stuff away and replace everything including wheel and tire with the French-made Beringer system. *Beringer makes performance brake systems for motorcycles, aircraft, etc. *It is not cheap and probably not an easy install. Does any one have first hand knowledge about this fix? *How easy is it to install and what are the performance gains? *I hate to lay out the cash without an understanding of how much of an improvement I will see. Let me know, thanks. Bob Better idea. Remove the Tost wheel and brake and send them to Vintage Brake (www.vintagebrake.com) in Sonora, California for a rebuild (~ $150). After three years, my Nimbus 2C still has powerful brakes. |
On Nov 25, 11:58*pm, bildan wrote:
On Nov 25, 9:33*pm, BravoCharlie wrote: Hi Pilots, I have a V2cxT that has the standard S-H disc brake that no longer works very well. *I have been through the obvious fixes; pads, new fluid, bleed, etc. and haven't been able to bring it back up to original performance which was adequate but not stellar. I know a number of pilots have complained about this world-wide and S- H has issued a voluntary TN. *The fix is to basically throw the old stuff away and replace everything including wheel and tire with the French-made Beringer system. *Beringer makes performance brake systems for motorcycles, aircraft, etc. *It is not cheap and probably not an easy install. Does any one have first hand knowledge about this fix? *How easy is it to install and what are the performance gains? *I hate to lay out the cash without an understanding of how much of an improvement I will see. Let me know, thanks. Bob Better idea. *Remove the Tost wheel and brake and send them to Vintage Brake (www.vintagebrake.com) in Sonora, California for a rebuild (~ $150). *After three years, my Nimbus 2C still has powerful brakes. The Ventus 2cx has a Tost "adaptation" of a cleveland wheel and brake plus a motorcycle handle-mount master cylinder. This is a disc system and not related to the Tost mechanical hub. I'm not sure Vintage Brake will help here. Hope that helps, Best Regards, Dave |
On Nov 25, 8:58*pm, bildan wrote:
On Nov 25, 9:33*pm, BravoCharlie wrote: Hi Pilots, I have a V2cxT that has the standard S-H disc brake that no longer works very well. *I have been through the obvious fixes; pads, new fluid, bleed, etc. and haven't been able to bring it back up to original performance which was adequate but not stellar. I know a number of pilots have complained about this world-wide and S- H has issued a voluntary TN. *The fix is to basically throw the old stuff away and replace everything including wheel and tire with the French-made Beringer system. *Beringer makes performance brake systems for motorcycles, aircraft, etc. *It is not cheap and probably not an easy install. Does any one have first hand knowledge about this fix? *How easy is it to install and what are the performance gains? *I hate to lay out the cash without an understanding of how much of an improvement I will see. Let me know, thanks. Bob Better idea. *Remove the Tost wheel and brake and send them to Vintage Brake (www.vintagebrake.com) in Sonora, California for a rebuild (~ $150). *After three years, my Nimbus 2C still has powerful brakes.- Hide quoted text - - Show quoted text - I had a scored disc from a off-field landing where sand was forced in between the disc and pads. After I used the brakes a couple of times the sand gouged up both the disc and pads, then the brakes didn't work as well. I also found that when pulling hard on the spoiler handle, my spoilers were hitting their stops (full open stop) and this bacame the limiting factor in brake application. A couple of turns on the pushrod end that fed the master cylinder, fixed the problem. Make sure your brake is full on, well before the spoilers hit their stops (if your brake is on the spoiler handle). Roger on the Vintage Brake guys, JJ JJ |
On Nov 26, 6:55*am, JJ Sinclair wrote:
On Nov 25, 8:58*pm, bildan wrote: On Nov 25, 9:33*pm, BravoCharlie wrote: Hi Pilots, I have a V2cxT that has the standard S-H disc brake that no longer works very well. *I have been through the obvious fixes; pads, new fluid, bleed, etc. and haven't been able to bring it back up to original performance which was adequate but not stellar. I know a number of pilots have complained about this world-wide and S- H has issued a voluntary TN. *The fix is to basically throw the old stuff away and replace everything including wheel and tire with the French-made Beringer system. *Beringer makes performance brake systems for motorcycles, aircraft, etc. *It is not cheap and probably not an easy install. Does any one have first hand knowledge about this fix? *How easy is it to install and what are the performance gains? *I hate to lay out the cash without an understanding of how much of an improvement I will see. Let me know, thanks. Bob Better idea. *Remove the Tost wheel and brake and send them to Vintage Brake (www.vintagebrake.com) in Sonora, California for a rebuild (~ $150). *After three years, my Nimbus 2C still has powerful brakes.- Hide quoted text - - Show quoted text - *I had a scored disc from a off-field landing where sand was forced in between the disc and pads. After I used the brakes a couple of times the sand gouged up both the disc and pads, then the brakes didn't work as well. I also found that when pulling hard on the spoiler handle, my spoilers were hitting their stops (full open stop) and this bacame the limiting factor in brake application. *A couple of turns on the pushrod end that fed the master cylinder, fixed the problem. Make sure your brake is full on, well before the spoilers hit their stops (if your brake is on the spoiler handle). Roger on the Vintage Brake guys, JJ JJ As Dave noted my actuator is a lever on the stick which is wimpy compared to the spoiler handle. Dave what do you suggest for a replacement Bowden cable? This one looks like a bicycle system and not even as beefy as a motorcycle version. Mine is adjusted fine but I might be losing some effectiveness with cable stretch and/or housing give. The adjuster is just the cable clamp nut. I have also heard the suggestion to replace the plastic brake fluid line with braided stainless. Any thoughts about that? |
On Nov 26, 10:54*am, BravoCharlie
wrote: On Nov 26, 6:55*am, JJ Sinclair wrote: On Nov 25, 8:58*pm, bildan wrote: On Nov 25, 9:33*pm, BravoCharlie wrote: Hi Pilots, I have a V2cxT that has the standard S-H disc brake that no longer works very well. *I have been through the obvious fixes; pads, new fluid, bleed, etc. and haven't been able to bring it back up to original performance which was adequate but not stellar. I know a number of pilots have complained about this world-wide and S- H has issued a voluntary TN. *The fix is to basically throw the old stuff away and replace everything including wheel and tire with the French-made Beringer system. *Beringer makes performance brake systems for motorcycles, aircraft, etc. *It is not cheap and probably not an easy install. Does any one have first hand knowledge about this fix? *How easy is it to install and what are the performance gains? *I hate to lay out the cash without an understanding of how much of an improvement I will see. Let me know, thanks. Bob Better idea. *Remove the Tost wheel and brake and send them to Vintage Brake (www.vintagebrake.com) in Sonora, California for a rebuild (~ $150). *After three years, my Nimbus 2C still has powerful brakes.- Hide quoted text - - Show quoted text - *I had a scored disc from a off-field landing where sand was forced in between the disc and pads. After I used the brakes a couple of times the sand gouged up both the disc and pads, then the brakes didn't work as well. I also found that when pulling hard on the spoiler handle, my spoilers were hitting their stops (full open stop) and this bacame the limiting factor in brake application. *A couple of turns on the pushrod end that fed the master cylinder, fixed the problem. Make sure your brake is full on, well before the spoilers hit their stops (if your brake is on the spoiler handle). Roger on the Vintage Brake guys, JJ JJ As Dave noted my actuator is a lever on the stick which is wimpy compared to the spoiler handle. *Dave what do you suggest for a replacement Bowden cable? *This one looks like a bicycle system and not even as beefy as a motorcycle version. Mine is adjusted fine but I might be losing some effectiveness with cable stretch and/or housing give. *The adjuster is just the cable clamp nut. *I have also heard the suggestion to replace the plastic brake fluid line with braided stainless. *Any thoughts about that? Here's a note Tom sent me after the Great Weedoni improved mine (this is years ago prior I upgraded to Antares). I don't have the specifics on the cable and housing, but almost anything is an improvement over the bicycle cable original. Pay attention to the routing: no corners, and no obstruction of controls !! http://www.nadler.com/public/ventus2...ke%20cable.htm Hope this helps ! Best Regards, Dave "YO electric" PS: Give a call if you want to discuss... |
On Nov 26, 9:03*am, DRN wrote:
On Nov 26, 10:54*am, BravoCharlie wrote: On Nov 26, 6:55*am, JJ Sinclair wrote: On Nov 25, 8:58*pm, bildan wrote: On Nov 25, 9:33*pm, BravoCharlie wrote: Hi Pilots, I have a V2cxT that has the standard S-H disc brake that no longer works very well. *I have been through the obvious fixes; pads, new fluid, bleed, etc. and haven't been able to bring it back up to original performance which was adequate but not stellar. I know a number of pilots have complained about this world-wide and S- H has issued a voluntary TN. *The fix is to basically throw the old stuff away and replace everything including wheel and tire with the French-made Beringer system. *Beringer makes performance brake systems for motorcycles, aircraft, etc. *It is not cheap and probably not an easy install. Does any one have first hand knowledge about this fix? *How easy is it to install and what are the performance gains? *I hate to lay out the cash without an understanding of how much of an improvement I will see. Let me know, thanks. Bob Better idea. *Remove the Tost wheel and brake and send them to Vintage Brake (www.vintagebrake.com) in Sonora, California for a rebuild (~ $150). *After three years, my Nimbus 2C still has powerful brakes..- Hide quoted text - - Show quoted text - *I had a scored disc from a off-field landing where sand was forced in between the disc and pads. After I used the brakes a couple of times the sand gouged up both the disc and pads, then the brakes didn't work as well. I also found that when pulling hard on the spoiler handle, my spoilers were hitting their stops (full open stop) and this bacame the limiting factor in brake application. *A couple of turns on the pushrod end that fed the master cylinder, fixed the problem. Make sure your brake is full on, well before the spoilers hit their stops (if your brake is on the spoiler handle). Roger on the Vintage Brake guys, JJ JJ As Dave noted my actuator is a lever on the stick which is wimpy compared to the spoiler handle. *Dave what do you suggest for a replacement Bowden cable? *This one looks like a bicycle system and not even as beefy as a motorcycle version. Mine is adjusted fine but I might be losing some effectiveness with cable stretch and/or housing give. *The adjuster is just the cable clamp nut. *I have also heard the suggestion to replace the plastic brake fluid line with braided stainless. *Any thoughts about that? Here's a note Tom sent me after the Great Weedoni improved mine (this is years ago prior I upgraded to Antares). I don't have the specifics on the cable and housing, but almost anything is an improvement over the bicycle cable original. Pay attention to the routing: no corners, and no obstruction of controls !! http://www.nadler.com/public/ventus2...ke%20cable.htm Hope this helps ! Best Regards, Dave "YO electric" PS: Give a call if you want to discuss... Thanks I will try a few more tweaks before I s-can the whole works. |
http://www.nadler.com/public/ventus2...ke%20cable.htm Man that's ugly! Why would anyone ruin a great hydraulic disc brake by actuating the master cylinder with a bicycle cable? Andy |
On Nov 26, 7:54*am, BravoCharlie
wrote: I have also heard the suggestion to replace the plastic brake fluid line with braided stainless. *Any thoughts about that?- I found that the plastic brake line works perfectly well with very little stretch. I'm using Nylo-Seal NSR 1/8" OD, .026" wall stuff so the internal volume is as low as possible and the hoop and longitudinal stresses are reasonable. I originally expected that the small internal cross-section would make the flow rate low enough that the brakes would be slow to apply and slow to release, but that has not been the case. It seems that disk brakes operate with such little displacement that even .004in^2 of cross-section on a 4-foot tube provides adequate flow. Thanks, Bob K. |
On Nov 25, 11:33*pm, BravoCharlie
wrote: Hi Pilots, I have a V2cxT that has the standard S-H disc brake that no longer works very well. *I have been through the obvious fixes; pads, new fluid, bleed, etc. and haven't been able to bring it back up to original performance which was adequate but not stellar. I know a number of pilots have complained about this world-wide and S- H has issued a voluntary TN. *The fix is to basically throw the old stuff away and replace everything including wheel and tire with the French-made Beringer system. *Beringer makes performance brake systems for motorcycles, aircraft, etc. *It is not cheap and probably not an easy install. Does any one have first hand knowledge about this fix? *How easy is it to install and what are the performance gains? *I hate to lay out the cash without an understanding of how much of an improvement I will see. Let me know, thanks. Bob Bob, I have the Beringer system in my Antares 20E. Even at 660kg gross, the wheel brake performance is outstanding. I can't speak to the ease of conversion for the V2cx though, sorry. Hope that helps, Best Regards, Dave PS: Did you already replace the factory Bowden cable housing and core with something robust enough, and add an adjuster ? |
brake fittings | [email protected] | Home Built | 6 | April 30th 07 01:33 AM |
K21 brake parts | Stuart Kinnear | Soaring | 10 | June 26th 06 09:54 PM |
looking for a 75 to 100 ton press brake about 8/10 ft | Adrian eyre | Home Built | 1 | January 6th 05 05:28 AM |
BRAKE FLUID | Ventus B | Soaring | 9 | October 17th 04 07:25 PM |
My squishy brake | JFLEISC | Owning | 0 | June 30th 04 01:44 AM |
