Interesting biplane project... look at the wing profile
Old December 2nd 08, 01:27 AM posted to rec.aviation.homebuilt
Bob Kuykendall
Default Interesting biplane project... look at the wing profile
On eBay:
http://cgi.ebay.com/ebaymotors/ws/eB...m=260325125475
Item number 260325125475 if that URL doesn't work for you.
The thing I'm curious about is the wing profile. Sections like that
seem to work for the F-117 stealth fighter. But it seems a bit out of
place on this aircraft.
Thanks, Bob K.
Old December 2nd 08, 02:07 AM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"Bob Kuykendall" wrote in message
On eBay:
Ooooooh-K....
Empty CG in front of the wing - and will only move forward when someone
sits on the seat? It's probably a good thing that he couldn't get it off
the ground...
Geoff
Old December 2nd 08, 02:24 AM posted to rec.aviation.homebuilt
On Dec 1, 7:07�pm, "Capt. Geoffrey Thorpe" The Sea Hawk @See My
On eBay:
http://cgi.ebay.com/ebaymotors/ws/eB...m&item=2603251....
Ooooooh-K....
the ground...
Geoff
Actually, that is the proper way of setting up the aircraft. Just
about every pusher configuration aircraft is stability relaxed empty.
As soon as pilot is on board the cg moves forward and the aircraft has
a positive stability margin sufficient for safe flight (well most of
the time - LOL).
I am curious just how the cg is going to move forward other than
pilot, passengers, or cargo?
Old December 2nd 08, 10:26 PM posted to rec.aviation.homebuilt
the time - LOL).
Correct.
I misread the ad - I thought it said 2" in front of the wing - not wing
_CENTER_ - my mistake.
Geoff
Old December 2nd 08, 04:28 AM posted to rec.aviation.homebuilt
Nothing especially new there. It is a faceted surface. Lots of
'interesting' characteristics with regard to lift & drag.
But what really makes my hair stand on end is the empty weight. A tad
on the chubby side, in my opinion.
-R.S.Hoover
Old December 2nd 08, 10:01 AM posted to rec.aviation.homebuilt
MC[_3_]
Nothing especially new there. *It is a faceted surface. *Lots of
You mean not much lift for drag -right?
But what really makes my hair stand on end is the empty weight. *A tad
What did you expect from tarps for wing coverings?
Cheers
Old December 5th 08, 01:54 PM posted to rec.aviation.homebuilt
Dear MC,
I wasn't referring specifically to this aircraft (too little data)
but to faceted wing surfaces in general.
From what I CAN see ( at least on the lower wing ), the characteristic
transition surface(s) needed to make the faceted portion work, appears
to be missing.
-R.S.Hoover
Old December 2nd 08, 04:44 AM posted to rec.aviation.homebuilt
Richard[_8_]
On eBay:
Thanks, Bob K.
Why wold anyone think it flies?
Old December 2nd 08, 05:23 AM posted to rec.aviation.homebuilt
Craig[_2_]
On eBay:
Thanks, Bob K.
anybody got a match?
Craig
Old December 2nd 08, 10:07 PM posted to rec.aviation.homebuilt
Morgans[_2_]
It says right in the descriptions, that this is not intended to fly, but
driven in a parade, or as an advertising gimmick.
Overkill, is right.
Jim in NC
LS3A Wing Profile Data Robert Fidler Soaring 14 October 27th 08 09:59 PM
EAA Biplane Project CHEAP $500 Victor Bravo Home Built 1 March 12th 08 08:02 PM
Any-1 remember biplane folding upper wing at show? On-Condition Home Built 2 September 21st 05 04:06 AM
ASW27 wing profile templates basils27 Soaring 0 June 29th 05 11:46 AM
Biplane wing dihedral vincent p. norris General Aviation 20 June 18th 05 02:58 AM
