FM Immunity
Old December 3rd 08, 12:14 AM posted to rec.aviation.piloting
Tman[_2_]
Default FM Immunity
What is that -- and does it matter to GA avionics? Heard it referenced
a few times in the sale of an older GIII. But Google does not turn up much.
T
Old December 3rd 08, 12:21 AM posted to rec.aviation.piloting
Bob Noel[_5_]
Default FM Immunity
(It's not applicable in the USA.)
It has to do with the lack of frequency protection for ILS. High
power FM stations (in Europe) can bleed enough RF into ILS frequencies
that ILS receivers (and technically VOR receivers) need to do a
better job rejecting out-of-channel frequencies.
I can dig up some references from work, but I'm not sure
how many are available for free.
Old December 3rd 08, 02:52 AM posted to rec.aviation.piloting
Gerry Caron[_2_]
Default FM Immunity
"Bob Noel" wrote in message
much.
It's an ICAO Annex 10 rule that requires ILS receivers installed after Jan
2001 (?) to have improved FM Immunity. As Bob said, it requires a tighter
spectral mask on the receivers to better reject bleed over from adjacent
channels. It can be a real issue for CAT II/III ops. Since Part 25 a/c are
normally certified for world-wide ops, they've had to meet it even tho it
wasn't a real problem in the US.
As it turns out, it is needed in the US; but not for the original reason.
Since then our FCC approved HD radio standards that allow significantly more
out-of-band emissions than the old analog signals. Just hope the FAA hasn't
installed an ILS on 108.1 MHz near a 107.9 MHz HD station.
Gerry
Old December 3rd 08, 06:07 PM posted to rec.aviation.piloting
RST Engineering
Default FM Immunity
Hey Gerry ...
Isn't 108.1 a protected ILS test frequency like 108.0 for VOR test?
Although I agree; I got my instrument ticket in San Diego and the Genave
A200 was more than willing to provide music on approach into the back course
at Lindberg Field.
more out-of-band emissions than the old analog signals. Just hope the FAA
hasn't installed an ILS on 108.1 MHz near a 107.9 MHz HD station.
Gerry
Old December 6th 08, 07:12 PM posted to rec.aviation.piloting
Mike
Default FM Immunity
"Gerry Caron" wrote in message
ng.com...
much.
are normally certified for world-wide ops, they've had to meet it even tho
it wasn't a real problem in the US.
Proper frequency management would probably prevent a problem. Even if it
didn't, it wouldn't take long for the FAA to figure out there was a problem.
Even if the problem wasn't discovered by a PIREP, all ILS systems are
periodically flight checked.
Old December 6th 08, 11:30 PM posted to rec.aviation.piloting
Maxwell[_2_]
Default FM Immunity
"Mike" nospam @ aol.com wrote in message
| ng.com...
| In article ,
referenced
| much.
Jan
tighter
tho
reason.
FAA
problem.
You have a tremendous grasp on the obvious little mikey.
Old December 8th 08, 06:25 PM posted to rec.aviation.piloting
Mike
Default FM Immunity
"Maxwell" #$$9#@%%%.^^^ wrote in message
news
| ng.com...
| In article ,
referenced
up
| much.
frequencies
Jan
tighter
adjacent
a/c
tho
reason.
significantly
FAA
it
problem.
You have a tremendous grasp on your package, Maxipad. That's why small
children are afraid of you on the bus, as they should be.
