Hi all,
I have an exhaust stud hole in my cylinder which is about half gone. I removed the exhaust stack and part of the helicoil is showing and upon further investigation, it looks like about half of the threads holding in the helicoil are gone. The stud and the nut came in one piece. I removed the helicoil since it isn't doing its job anymore and I'm curious about the next course of action. The helicoil is a 5/16-24 and it should have been a 5/16-18. I suppose I could put in a new one and hope the remaining threads will hold the coil and stud, but I'd rather fix it better. I'd also rather not pull the cylinder and have the hole filled and retapped. Any good suggestions out there? Some sort of threaded insert? Thanks Dave |
On Fri, 05 Dec 2008 20:49:54 -0500, Dave wrote:
Hi all, I have an exhaust stud hole in my cylinder which is about half gone. I removed the exhaust stack and part of the helicoil is showing and upon further investigation, it looks like about half of the threads holding in the helicoil are gone. The stud and the nut came in one piece. I removed the helicoil since it isn't doing its job anymore and I'm curious about the next course of action. The helicoil is a 5/16-24 and it should have been a 5/16-18. I suppose I could put in a new one and hope the remaining threads will hold the coil and stud, but I'd rather fix it better. I'd also rather not pull the cylinder and have the hole filled and retapped. Any good suggestions out there? Some sort of threaded insert? Thanks Dave sad to think that it is time to make the faithful old cylinder into a door stop but that is the likely outcome. exhaust studs are made in about 10 sizes of oversize to counter the wear in the cylinder threads but having a helicoil negates all that. go shopping for a new one (cylinder). Stealth Pilot |
On Dec 5, 6:49*pm, Dave wrote:
Hi all, I have an exhaust stud hole in my cylinder which is about half gone. I removed the exhaust stack and part of the helicoil is showing and upon further investigation, it looks like about half of the threads holding in the helicoil are gone. The stud and the nut came in one piece. I removed the helicoil since it isn't doing its job anymore and I'm curious about the next course of action. The helicoil is a 5/16-24 and it should have been a 5/16-18. I suppose I could put in a new one and hope the remaining threads will hold the coil and stud, but I'd rather fix it better. I'd also rather not pull the cylinder and have the hole filled and retapped. Any good suggestions out there? Some sort of threaded insert? Thanks Dave Since this is the "homebuilt" group you can use this trick,,, Warning,, not legal on certified stuff.. First the bad news is you will be able to fix it but it probably involves pulling the cylinder altho if you are a contortionist ya might get lucky. All you need is a "step stud" there is one size on one end and different on the other,, Dorman is one company that makes those and I am sure there are others. You can also build one at home if you have a lathe. Since the helicoil is shot the hole in the cyl is close to the right size to tap to 3/8-24 or even 3/8-16. Just get the hole tapped with decent threads and screw in the step stud and you are good to go. There is also the idea or using a 'Keensert" but you will still have to retap the hole too... Tailwinds . Ben,,,, |
Exhaust stud hole needs help | Dave | Owning | 2 | December 7th 08 03:02 PM |
1000 km in a Ka-6e DS is a glider stud! | [email protected] | Soaring | 11 | October 9th 07 05:52 PM |
Worm Hole no Need for Black Hole | Michael Baldwin, Bruce | Products | 2 | May 8th 07 11:04 AM |
Sorry - GPN Black hole... | Jono Richards | Soaring | 0 | February 10th 06 09:39 AM |
A-65 exhaust stud specs | Jerry Jensen | Home Built | 4 | March 3rd 04 01:13 AM |
