http://w3n-a.blogspot.com/2008/12/secondary-stall.html
This stall is called a secondary stall since it may occur after a recovery from a preceding stall. It is caused by attempting to hasten the completion of a stall recovery before the airplane has regained sufficient flying speed. When this stall occurs, the back-elevator pressure should again be released just as in a normal stall recovery. When sufficient airspeed has been regained, the airplane can then be returned to straight-and-level flight. This stall usually occurs when the pilot uses abrupt control input to return to straight-and-level flight after a stall or spin recovery. It also occurs when the pilot fails to reduce the angle of attack sufficiently during stall recovery by not lowering pitch attitude sufficiently, or by attempting to break the stall by using power only. http://w3n-a.blogspot.com/2008/12/secondary-stall.html |
Can we block this idiot?
I reported it (to Google Groups) as spam. |
In article
, w3n-a wrote: [snip] Into the killfile for you. |
You guys have it all wrong: This is what sleepy tow pilots do!
Pete #309 (and former tow pilot) |
On Dec 7, 10:09*pm, 309 wrote:
You guys have it all wrong: *This is what sleepy tow pilots do! Pete #309 (and former tow pilot) This is an aircraft RESTORATION forum. No one here gives a rats's foot for what sleepy tow pilots do! |
"Werner Schmidt" wrote in message
... Hallo , Du schriebst am 08.12.2008 15:57 On Dec 7, 10:09 pm, 309 wrote: You guys have it all wrong: This is what sleepy tow pilots do! Pete #309 (and former tow pilot) This is an aircraft RESTORATION forum. No one here gives a rats's foot for what sleepy tow pilots do! this ain't no forum, it's usenet. Have a look look at the list of crossposting, then you'll see the issue. regards Werner Yup, this guy is posting to Restoration, Rotorcraft, Simulators, and Student newsgroups. |
On Dec 6, 9:04*pm, w3n-a wrote:
http://w3n-a.blogspot.com/2008/12/secondary-stall.html This stall is called a secondary stall since it may occur after a recovery from a preceding stall. It is caused by attempting to hasten the completion of a stall recovery before the airplane has regained sufficient flying speed. *When this stall occurs, the back-elevator pressure should again be released just as in a normal stall recovery. When sufficient airspeed has been regained, the airplane can then be returned to straight-and-level flight. This stall usually occurs when the pilot uses abrupt control input to return to straight-and-level flight after a stall or spin recovery. It also occurs when the pilot fails to reduce the angle of attack sufficiently during stall recovery by not lowering pitch attitude sufficiently, or by attempting to break the stall by using power only. http://w3n-a.blogspot.com/2008/12/secondary-stall.html Usenet's amazing!!! :-))) WHAT a marketing strategy!!!! The only good thing I can think of about this is that it might have been placed here by this guy's competition :-)))))))))))))))))))))))))))) Dudley Henriques |
ok, let's give the benefit....................so, what is the
point??????????? "w3n-a" wrote in message ... http://w3n-a.blogspot.com/2008/12/secondary-stall.html This stall is called a secondary stall since it may occur after a recovery from a preceding stall. It is caused by attempting to hasten the completion of a stall recovery before the airplane has regained sufficient flying speed. When this stall occurs, the back-elevator pressure should again be released just as in a normal stall recovery. When sufficient airspeed has been regained, the airplane can then be returned to straight-and-level flight. This stall usually occurs when the pilot uses abrupt control input to return to straight-and-level flight after a stall or spin recovery. It also occurs when the pilot fails to reduce the angle of attack sufficiently during stall recovery by not lowering pitch attitude sufficiently, or by attempting to break the stall by using power only. http://w3n-a.blogspot.com/2008/12/secondary-stall.html |
| Secondary Stall | w3n-a | Owning | 12 | December 10th 08 08:13 PM |
| Secondary Stall | w3n-a | General Aviation | 10 | December 10th 08 08:10 PM |
| Secondary Stall | w3n-a | Piloting | 18 | December 10th 08 08:10 PM |
| Secondary Stall | w3n-a | Home Built | 3 | December 10th 08 01:36 PM |
| secondary tach | dave | Owning | 1 | March 14th 07 08:34 PM |
