It is winter here and the only soaring we are doing in Chicago is in
the hangar . During an energetic discussion on the pros and cons of various soaring programs, I mentioned I fly "Direction-Up", rather than "North-Up". WHOA! You would have thought that I had said I was going to give up soaring to fly helicopters by the dirty looks that I received. Now, to be fair, with every GPS device I use (car, boat, GA), I *ALWAYS* orient the map as north-up, and prefer it overall...except, that is, when soaring. I started using north-up at first, but soon found that a direction-up display was much better in letting me anticipate the timing of rolling out of a thermal and heading towards the next turn point. Attempting to coordinate the rotating glider icon on a stationary north-up map, with the view outside and/or compass, all while centering a thermal, is a bit like patting my head and rubbing my stomach at the same time. Maybe this is unique to a thermal-only soaring climate. NOTE: I am not directionally challanged. Anyway, I wondered what others use relative to the type of soaring they do. Thanks, John |
Not sure what you mean by "direction-up". (Wherever my nose is
pointed, that's my direction, I figure.) I use "goal up" when I have a turnpoint dialed in, "north up" otherwise. ~ted/2NO |
I agree with the direction up. I AM directionally challenged on the ground
and when I enter an building I no longer remember after one turn which way north is. If you get any more dirty looks, ask if they always hold their sectional north up or if they rotate it to follow their course line. It can be done both ways, but course line up is much easier. At 02:09 17 December 2008, ContestID67 wrote: It is winter here and the only soaring we are doing in Chicago is in the hangar . During an energetic discussion on the pros and cons of various soaring programs, I mentioned I fly "Direction-Up", rather than "North-Up". WHOA! You would have thought that I had said I was going to give up soaring to fly helicopters by the dirty looks that I received. Now, to be fair, with every GPS device I use (car, boat, GA), I *ALWAYS* orient the map as north-up, and prefer it overall...except, that is, when soaring. I started using north-up at first, but soon found that a direction-up display was much better in letting me anticipate the timing of rolling out of a thermal and heading towards the next turn point. Attempting to coordinate the rotating glider icon on a stationary north-up map, with the view outside and/or compass, all while centering a thermal, is a bit like patting my head and rubbing my stomach at the same time. Maybe this is unique to a thermal-only soaring climate. NOTE: I am not directionally challanged. Anyway, I wondered what others use relative to the type of soaring they do. Thanks, John |
While flying, especially in thermals, I prefer "heads up".
W7 ContestID67 wrote: It is winter here and the only soaring we are doing in Chicago is in the hangar . During an energetic discussion on the pros and cons of various soaring programs, I mentioned I fly "Direction-Up", rather than "North-Up". WHOA! You would have thought that I had said I was going to give up soaring to fly helicopters by the dirty looks that I received. Now, to be fair, with every GPS device I use (car, boat, GA), I *ALWAYS* orient the map as north-up, and prefer it overall...except, that is, when soaring. I started using north-up at first, but soon found that a direction-up display was much better in letting me anticipate the timing of rolling out of a thermal and heading towards the next turn point. Attempting to coordinate the rotating glider icon on a stationary north-up map, with the view outside and/or compass, all while centering a thermal, is a bit like patting my head and rubbing my stomach at the same time. Maybe this is unique to a thermal-only soaring climate. NOTE: I am not directionally challanged. Anyway, I wondered what others use relative to the type of soaring they do. Thanks, John |
I am one of the developers of SoarPilot which supports, north up,
track/direction up and course-up and I have pondered this many times. I believe a given person's preference is simply that...personal. I'm not a neuro-scientist in anyway, but I think a given person's preference is mostly driven by how they process spacial and/or geospacial representations in general and by what they have been taught to use. Do you prefer to have what you see outside the glider match what you are seeing on the screen OR do you prefer to mentally convert and correlate what you are seeing outside with what you would see on a North up map? From elementary school we are taught to use and read north-up maps. So we become VERY comfortable with that way of looking and processing geospacial information. As an example of what I mean, I have seen a large world wall map in the typical, oval, equidistant-cylindrical representation. It is normal in every respect for one....it has the world depicted South UP. And when you look at it, it immediately seems VERY, VERY wrong? But if you think about it, it is no more incorrect a representation than a North up map. It only seems wrong because it's not they way we're used to seeing it. Later! -Mark PS. I like track up best as well. On Dec 16, 8:22*pm, Ray wrote: While flying, especially in thermals, I prefer "heads up". W7 ContestID67 wrote: It is winter here and the only soaring we are doing in Chicago is in the hangar . During an energetic discussion on the pros and cons of various soaring programs, I mentioned I fly "Direction-Up", rather than "North-Up". WHOA! You would have thought that I had said I was going to give up soaring to fly helicopters by the dirty looks that I received. Now, to be fair, with every GPS device I use (car, boat, GA), I *ALWAYS* orient the map as north-up, and prefer it overall...except, that is, when soaring. * I started using north-up at first, but soon found that a direction-up display was much better in letting me anticipate the timing of rolling out of a thermal and heading towards the next turn point. *Attempting to coordinate the rotating glider icon on a stationary north-up map, with the view outside and/or compass, all while centering a thermal, is a bit like patting my head and rubbing my stomach at the same time. *Maybe this is unique to a thermal-only soaring climate. * *NOTE: I am not directionally challanged. Anyway, I wondered what others use relative to the type of soaring they do. Thanks, John |
I taught map and compass skills for the army for many years. We
always plotted our route in North Up, but then used it oriented to track when we were out in the field -- much easier to co-ordinate objects on the ground with objects on the map this way, we looked in the correct relative direction. |
I'm a happy use of SoarPilot. On course I use it in "track up" mode
because that gives me the most screen space along my path of flight. I'm not interested in what's 90 degrees off the course line (not usually anyway). While thermalling I'm not looking at the PDA much; the color coding that SP does for the lift is usually too far behind what I'm doing, and it's too hard to see. All I look at is the average lift calculation so I know when the lift is petering out (I leave when the 20sec average drops below that bottom-top average, which usually means the thermal is down to 80% of its best). Well, I do look at the course line, but again the depiction is usually a couple seconds out of date so it's easy to overshoot the course line if I depend on the PDA. Instead, I try to pick out landmarks in the direction I want to go so I stay oriented, and then pick out lift sources in the last several times around in the thermal. As far as looking at the map (I refer to that too) I use that both "course-up" and "north-up" depending on whether I want to find landmarks or read the text printed on the map. -- Matt PS that north-up cylindrical projection we all had in our schoolrooms as kids had another feature -- the Northern Hemisphere is depicted in a larger scale than the Southern! They did it that way since most of the landmass is in the north. The next time you see one take note of where the equator is. That "upside-down" map you saw, Mark, places the equator back in the middle so the sizes won't match what you remember even if you look at it in your familiar orientation. On Dec 16, 10:43*pm, MarkHawke7 wrote: I am one of the developers of SoarPilot which supports, north up, track/direction up and course-up and I have pondered this many times. I believe a given person's preference is simply that...personal. *I'm not a neuro-scientist in anyway, but I think a given person's preference is mostly driven by how they process spacial and/or geospacial representations in general and by what they have been taught to use. *Do you prefer to have what you see outside the glider match what you are seeing on the screen OR do you prefer to mentally convert and correlate what you are seeing outside with what you would see on a North up map? *From elementary school we are taught to use and read north-up maps. *So we become VERY comfortable with that way of looking and processing geospacial information. *As an example of what I mean, I have seen a large world wall map in the typical, oval, equidistant-cylindrical representation. *It is normal in every respect for one....it has the world depicted South UP. *And when you look at it, it immediately seems VERY, VERY wrong? *But if you think about it, it is no more incorrect a representation than a North up map. *It only seems wrong because it's not they way we're used to seeing it. Later! -Mark PS. *I like track up best as well. On Dec 16, 8:22*pm, Ray wrote: While flying, especially in thermals, I prefer "heads up". W7 ContestID67 wrote: It is winter here and the only soaring we are doing in Chicago is in the hangar . During an energetic discussion on the pros and cons of various soaring programs, I mentioned I fly "Direction-Up", rather than "North-Up". WHOA! You would have thought that I had said I was going to give up soaring to fly helicopters by the dirty looks that I received. Now, to be fair, with every GPS device I use (car, boat, GA), I *ALWAYS* orient the map as north-up, and prefer it overall...except, that is, when soaring. * I started using north-up at first, but soon found that a direction-up display was much better in letting me anticipate the timing of rolling out of a thermal and heading towards the next turn point. *Attempting to coordinate the rotating glider icon on a stationary north-up map, with the view outside and/or compass, all while centering a thermal, is a bit like patting my head and rubbing my stomach at the same time. *Maybe this is unique to a thermal-only soaring climate. * *NOTE: I am not directionally challanged. Anyway, I wondered what others use relative to the type of soaring they do. Thanks, John |
On Dec 16, 8:29*pm, wrote:
I'm a happy use of SoarPilot. *On course I use it in "track up" mode because that gives me the most screen space along my path of flight. *I'm not interested in what's 90 degrees off the course line (not usually anyway). *While thermalling I'm not looking at the PDA much; the color coding that SP does for the lift is usually too far behind what I'm doing, and it's too hard to see. *All I look at is the average lift calculation so I know when the lift is petering out (I leave when the 20sec average drops below that bottom-top average, which usually means the thermal is down to 80% of its best). *Well, I do look at the course line, but again the depiction is usually a couple seconds out of date so it's easy to overshoot the course line if I depend on the PDA. *Instead, I try to pick out landmarks in the direction I want to go so I stay oriented, and then pick out lift sources in the last several times around in the thermal. *As far as looking at the map (I refer to that too) I use that both "course-up" and "north-up" depending on whether I want to find landmarks or read the text printed on the map. -- Matt Track up for me - makes it easier to align what's on the map with the view out the window, particularly for course deviations, finding alternates, picking MAT turnpoints, etc. 9B |
On Dec 16, 9:09*pm, ContestID67 wrote:
It is winter here and the only soaring we are doing in Chicago is in the hangar . During an energetic discussion on the pros and cons of various soaring programs, I mentioned I fly "Direction-Up", rather than "North-Up". WHOA! You would have thought that I had said I was going to give up soaring to fly helicopters by the dirty looks that I received. Now, to be fair, with every GPS device I use (car, boat, GA), I *ALWAYS* orient the map as north-up, and prefer it overall...except, that is, when soaring. * I started using north-up at first, but soon found that a direction-up display was much better in letting me anticipate the timing of rolling out of a thermal and heading towards the next turn point. *Attempting to coordinate the rotating glider icon on a stationary north-up map, with the view outside and/or compass, all while centering a thermal, is a bit like patting my head and rubbing my stomach at the same time. *Maybe this is unique to a thermal-only soaring climate. * *NOTE: I am not directionally challanged. Anyway, I wondered what others use relative to the type of soaring they do. Thanks, John Actually, the question is a bit more complicated then you've posed, as there are more options: - track up - North up - nose up Nose up is not what precedes a stall ;-) It's when the map is rotated to match what you see over the nose, adjusting your track to take account of the wind. Also used in ILEC SN10 to rotate the wind arrow so it matches the view outside. The advantage is substantial when you're flying with a crosswind. ILEC SN10 pilots can choose North or Nose Up for the map (wind arrow is always rotated Nose Up). Hope that helps, Best Regards, Dave "YO electric" |
Heading (Nose) up while flying - allows orientation with real world
(really important when winds are strong!). But this requires a good Track display on the map; I have a nice track line on my mSeeYou map that I can use to see how my wind corrected track compares with my desired course line. I just adjust my heading to make sure my actual track is taking me to the next turnpoint to avoid "homing". Also matches the map on my SN10. North up when creating a task - somewhat easier to see "big picture", but not useful when actually flying, IMO (other than possibly when thermalling - tried it but still prefer Heading up). Kirk 66 |
Traffic with direction | Dave | Products | 14 | August 10th 05 06:44 AM |
more bitching about the IFR written - CDI left/right versus north/south/etc | G. Sylvester | Instrument Flight Rules | 58 | January 12th 05 02:32 AM |
"zero" versus "oscar" versus "sierra" | Ron Garret | Piloting | 30 | December 20th 04 08:49 AM |
Dr. Jack's Wind Direction | rjciii | Soaring | 14 | October 5th 03 05:37 AM |
Wind Direction | --=JJay=-- | Soaring | 2 | September 27th 03 07:18 PM |
