A portable ADS-B unit - no price.
http://www.dtiweb.net/main%20menu%20options/adsb.html ADS-B Automatic Dependent Surveillance Broadcast known as ADS-B is the future for all aircraft. Coming Soon expected availability late calendar 08 The ADS-B system is destined to become a nationwide r equirement for all aircraft flying in United States air space. DTI, a proven leader in the development of new technologies for both m anned aircraft, introduces a new light weight simple to use ADS-B Transmission system. DTI’s ADS-B system is fully compliant with TSO-C154b. What is ADS-B? Automatic - No pilot input required. Dependant - Uses accurate position and velocity data from aircraft's navigation system (example GPS). Surveillance -Provides aircraft position, altitude, velocity, and other data to facilities that require theinformation. Broadcast - Any appropriately equipped ground station or aircraft can monitor the ADS-B signal. The DTI ADS-B is a portable stand alone device. No upgrades to your aircraft would be required to comply with new regulations. Simply place it in the cockpit and turn it on. Operation of the unit can be determined by four LEDs on the front of the unit. The GPS sub-system will link up with GPS satellites allowing the pilot to fly the plane while the DTI ADS-B broadcasts position, altitude, velocity and other data in a standard ADS-B stream every second during flight. The DTI ADS-B works off internal batteries. No external power source is required and weighs less than two pounds. It incorporates one GPS antenna on its outer casing or one remote GPS antenna for users who prefer an externally mounted antenna. DTI ADS-B Units come complete with transmission antenna, GPS antenna, mounting bracket and instruction manual. The unit comes with tail numbers and aircraft information encoded in the unit. Physical Specifications Height 1.53 in Width 3.06 in Length 4.77 in Weight 1.25 in Electrical Specifications Power 0.978 watts Voltage 2.4 - 4 VDC (battery) Input current 0.8 Amps UAT performance Specs TSO Compliance Obtaining TSO-154 Frequency 978 Tx Power 10 watts Frequency Tolerance +/- 20 ppm Modulation Continuous Phase frequency Shift Keying GPS/WAAS Receiver Specs TSO Compliance Obtaining TSO-C145a (RTCA/DO-229C) Chipset SiRF Star III # of Channels 20 Frequency L1, 1575.42 MHz Sensitivity -159 dBm Lat/Long position accuracy 10 meters - 2D RMS 5 meters - 2D RMS, WAAS enabled Velocity 515 meters/second (1000 Kts) max TTFF 42 sec. avg (Time to first fix) Reacquisition 0.1 sec. avg Datum WGS-84 |
On Dec 17, 10:17*am, Ben wrote:
A portable ADS-B unit - no price. Electrical Specifications Power 0.978 watts Voltage 2.4 - 4 VDC (battery) Input current 0.8 Amps I had hoped DTI were more in touch with the real world than this would indicate. Where is that power going to come from? Why isn't the unit compatible with standard aircraft power systems? I saw no reference to capability to support CDTI. Do they expect to sell a separate receiver? Andy |
On Dec 17, 11:30*am, Andy wrote:
On Dec 17, 10:17*am, Ben wrote: A portable ADS-B unit - no price. Electrical Specifications Power 0.978 watts Voltage 2.4 - 4 VDC (battery) Input current 0.8 Amps I had hoped DTI were more in touch with the real world than this would indicate. *Where is that power going to come from? *Why isn't the unit compatible with standard aircraft power systems? I saw no reference to capability to support CDTI. *Do they expect to sell a separate receiver? Andy I don't know - just came across the site following a news release concerning a govt contract awarded DTI concerning UAVs. Ben |
Andy wrote:
On Dec 17, 10:17 am, Ben wrote: A portable ADS-B unit - no price. Electrical Specifications Power 0.978 watts Voltage 2.4 - 4 VDC (battery) Input current 0.8 Amps I had hoped DTI were more in touch with the real world than this would indicate. Where is that power going to come from? Why isn't the unit compatible with standard aircraft power systems? I saw no reference to capability to support CDTI. Do they expect to sell a separate receiver? I just sent this email to DTI: I'm looking for more information about your portable ADS-B unit than you have on your website. I fly a sailplane, currently with a transponder, but I very interested in ADS-B. Specifically, about your unit: 1. When will it be available? 2. What will it cost? 3. Where in the country will it usable with ATC? 4. Can it be used in lieu of transponder? 5. Does it receive information from other ADS-B units or ATC, and can this information be displayed on any moving map displays? Regards, Eric Greenwell Richland, WA -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Wed, 17 Dec 2008 21:22:39 GMT, Eric Greenwell
wrote: 1. When will it be available? 2. What will it cost? 3. Where in the country will it usable with ATC? 4. Can it be used in lieu of transponder? 5. Does it receive information from other ADS-B units or ATC, and can this information be displayed on any moving map displays? well done. Anyway, a very promising device, that was presented to the IGC by Bernald Smith during the latest plenary meeting in march. It's on my buy list... Aldo Cernezzi |
Hi Eric,
I look forward to hearing more about the unit. It look a LOT like the unit that Mitre showed at our meeting at the SSA Convention earlier this year. Mitre was selling licenses to use their design for about $10k which seems like practically nothing considering the design work was done - to a certain extent. I think it is great that a company is selling the unit. But it is a transmitter only - designed for use in UATs. Mitre has recently designed an ADS-B transceiver. I look forward to the day it is available at a reasonable cost. Pau Remde "Eric Greenwell" wrote in message ... Andy wrote: On Dec 17, 10:17 am, Ben wrote: A portable ADS-B unit - no price. Electrical Specifications Power 0.978 watts Voltage 2.4 - 4 VDC (battery) Input current 0.8 Amps I had hoped DTI were more in touch with the real world than this would indicate. Where is that power going to come from? Why isn't the unit compatible with standard aircraft power systems? I saw no reference to capability to support CDTI. Do they expect to sell a separate receiver? I just sent this email to DTI: I'm looking for more information about your portable ADS-B unit than you have on your website. I fly a sailplane, currently with a transponder, but I very interested in ADS-B. Specifically, about your unit: 1. When will it be available? 2. What will it cost? 3. Where in the country will it usable with ATC? 4. Can it be used in lieu of transponder? 5. Does it receive information from other ADS-B units or ATC, and can this information be displayed on any moving map displays? Regards, Eric Greenwell Richland, WA -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
