In the " I wonder if this would work " department, I have a question
about mixing different materials in main airframe structures. To make a long story short, I was wondering if some weight could be saved by making a wing with a carbon fiber spar ( high strength, light weight ) with aluminum ribs and skins. Would the carbon and aluminum be compatible? Of course an acceptable method would have to be devised to attach the ribs and skins to the spar, but I don't see this as a big problem. Since the spars are some of the heaviest part of the wing, I thought this would be a good way to save some weight, and in a case I have in mind, an easy way to join the spar to the fuselage, especially if the fuselage is composite. I would want to keep the rest of the wing aluminum mainly to save dollars, but also because of the proven history. Would the weight savings be worth the effort? Neal |
"Neal Fulco" wrote in message
om... To make a long story short, I was wondering if some weight could be saved by making a wing with a carbon fiber spar ( high strength, light weight ) with aluminum ribs and skins. Why mess with aluminum? Check out the construction methods for the new CAP-10C wing at http://www.capaviation.com/. I'm not quite sure where this link will take you - you may have to drill down a bit to reach to correct page. Rich S. |
Earlier, (Neal Fulco) wrote:
I was wondering if some weight could be saved by making a wing with a carbon fiber spar ( high strength, light weight ) with aluminum ribs and skins. I'm pretty sure a way can be found to make it work. But one awkward aspect is the mismatch in Young's modulus between the spar and the skin. See my earlier post on this topic: http://groups.google.com/groups?hl=e...g.goog le.com [Huge nasty Google link. Must be all on one line.] Thanks, and best regards to all Bob K. http://www.hpaircraft.com/hp-24 |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | October 2nd 03 04:07 AM |
| Carbon Spar design and construction workshop | Marske Flying Wings | Home Built | 0 | September 18th 03 06:47 PM |
| Worthy EAA Construction Books | Brock | Home Built | 5 | September 16th 03 08:48 PM |
| Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 06:12 AM |
| Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 05:50 PM |
