piston connecting rod bolt replacement
Old October 5th 03, 09:47 PM
Dick
Default piston connecting rod bolt replacement
Although finally successful at getting connecting rod pins pressed out with
our chapter's hydraulic press, I don't see how to "rig/jig" to drive out the
rod bolts.
Could someone provide some clarification? thanks.
Old October 5th 03, 11:42 PM
Larry Smith
"Dick" wrote in message
om...
with
rod bolts.
You should be able to remove piston pins and rod bolts with a suitable
drift, i. e., something soft like brass or delrin. Most piston pins will
push out with finger pressure, especially if they are still oily and you
apply a little heat from a hair dryer. Of course, you don't beat on piston
pins while the rod is still attached to the crank. You take the rod off
first, with piston attached, then drive out the pins by supporting the
piston on a piece of wood like a 4 by 4, with a big hole for the pin to go
down into.
WTH are you working on? If it's an aircraft engine, people with heavy
hammers should be kept away. Go by the book. Go buy the book.
Old October 6th 03, 03:37 AM
Larry Smith
om...
with
rod bolts.
Hey, dude, I forgot to point out to you that a little heat from a hair dryer
or heat gun -- not much -- would have released those piston pins without
your having to use a hydraulic press. Aluminum (the piston) and steel (the
wrist pin) have differing rates of expansion when heated. With the least
bit of heat directed around the pins the aluminum would have let the pins go
in about 2 shakes of a sheep's tail.
A few light pecks on a brass drift with a machinist's hammer would have
finessed the rod bolts out. It's like sex, guy. You have to finesse it or
she won't respond.
Old October 6th 03, 05:20 AM
clare @ snyder.on .ca
On Sun, 5 Oct 2003 22:37:59 -0400, "Larry Smith"
. com...
with
rod bolts.
UNLESS the pin is a press fit in the ROD and floats in the piston,
like on a CorvAir
she won't respond.
Old October 6th 03, 02:56 PM
Corky Scott
like on a CorvAir
And the Ford V-6.
Corky Scott
Old October 7th 03, 02:34 PM
Dick
thanks, got pin out but still seeking thoughts on jigging connecting rod
bolt for removal..
