One of the more troublesome aspects of aviation electrical work is the fact our wires are usually NOT color-coded. That means you can have a bundle of twenty wires and before you can do any useful work you will need to figure out which one of the twenty at the equipment rack is the frayed one you've spotted behind the instrument panel. How to do it? The good ol' fashioned way, which I described in an article some time ago, is to use a continuity tester. That is, a hunka wire long enough to run from here to there, a couple of flashlight batteries, and a flashlight bulb. You know you've found the correct lead when the bulb lights up. I even described a do-it- yourself tester based on an old-style Navy flashlight. Alas, while 3 volts ain't all that much, that's what you are connecting to your wires when you use a continuity-check as I described in my article. If you're dealing with a real mess, such as a bundle of wires that have been chopped with an ax (!) ...you could be connecting those 'unimportant' three volts to a meter-circuit that blows it's top at two volts. Whatcha REALLY want is a cable tracker. A cable track is a little oscillator that puts a warbling TONE on the wire under test, which you can then 'hear' by waving a matching receiver at the other end of the wire. Harbor Freight's gottem. Item #94181 about $20 US, probably less if you can find a Sale. (But Santa brought me this one :-) I'll probably do a little write-up, put it on my blog so you can see what it looks like. But not this year. Was it a good year? Of course it was; they're all good years. Some are just better than others. Time for my Ten O'Clock pills. I'll see you guys next year. -R.S.Hoover |
On Jan 1, 1:17*am, " wrote:
One of the more troublesome aspects of aviation electrical work is the fact our wires are usually NOT color-coded. *That means you can have a bundle of twenty wires and before you can do any useful work you will need to figure out which one of the twenty at the equipment rack is the frayed one you've spotted behind the instrument panel. How to do it? *The good ol' fashioned way, which I described in an article some time ago, is to use a continuity tester. *That is, a hunka wire long enough to run from here to there, a couple of flashlight batteries, and a flashlight bulb. *You know you've found the correct lead when the bulb lights up. *I even described a do-it- yourself tester based on an old-style Navy flashlight. Alas, while 3 volts ain't all that much, that's what you are connecting to your wires when you use a continuity-check as I described in my article. *If you're dealing with a real mess, such as a bundle of wires that have been chopped with an ax (!) ...you could be connecting those 'unimportant' three volts to a meter-circuit that blows it's top at two volts. Whatcha REALLY want is a cable tracker. A cable track is a little oscillator that puts a warbling TONE on the wire under test, which you can then 'hear' by waving a matching receiver at the other end of the wire. Harbor Freight's gottem. *Item #94181 about $20 US, probably less if you can find a Sale. *(But Santa brought me this one :-) *I'll probably do a little write-up, put it on my blog so you can see what it looks like. *But not this year. Was it a good year? *Of course it was; they're all good years. *Some are just better than others. Time for my Ten O'Clock pills. *I'll see you guys next year. -R.S.Hoover I just put that on my list for my yearly Harbor Freight run on Friday. Hope it's in stock. Thanks Karl |
....you could be connecting those 'unimportant' three volts to a meter-circuit that blows it's top at two volts. yep A cable track is a little oscillator that puts a warbling TONE on the wire under test, which you can then 'hear' by waving a matching receiver at the other end of the wire. good tip. thanks. -R.S.Hoover Mark |
.. And it takes about 20% more time to do the wiring on a NEW airplane or a COMPLETE REBUILD on an old one to get the good old aviation white wire insulation and down to Staples for 9 marking pens; black, brown, red, orange, yellow, green, blue, violet, and gray. (0, 1, 2, 3, 4, 5, 6, 7, 8, and 9) Assign each wire in the aircraft a number in accordance with a little thought about what the numbers really mean. With three digits you can have about 800 wires, with four digits 8000. Above that, you are making a 747. Each wire starts off with a double stripe of the lead digit. Then one stripe on the insulation for the second digit, and so on. FOr example, wire #234 would start off with two thin red stripes around the circumference of one end of the wire, then a single orange stripe, then a yellow stripe. THen a CLEAR shrink sleeve around the whole "number". Repeat at the far end. Or, get yourself some colored shrink and do the whole job with about half the time. Same drill, but this time the first digit is twice as wide as the rest of them. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle wrote in message ... One of the more troublesome aspects of aviation electrical work is the fact our wires are usually NOT color-coded. |
On Jan 1, 10:53*am, "RST Engineering" wrote:
. . And it takes about 20% more time to do the wiring on a NEW airplane or a COMPLETE REBUILD on an old one . . . . . ----------------------------------------------------------------------------------------------------- An along about there Mr. Newbie shakes his head and sez, "Well, I can't see any way that you'd EVER need to re-wire some of them ol' birds," with the clear implication that, as a new owner of an old airplane he is liable to be practiced upon by one of them CERTIFIED fellers who are the only ones ALLOWED to touch his antique battle-damaged warbird. He's wrong, of course. Here... lookit this. It's what's left of a 1943 grommet. ("What IS this stuff?" he asks.) Usta be rubber. No, not Neoprene -- RUBBER. Came from a big plantation in AFRICA, not Brazil. Sixty years ago. Sixty years, tucked into a hole in an aluminum bracket of a war-bird. ( This was a coupla years ago.) The 'rubber' is harder than a bride's biscuits -- you can't even dent it with your thumb-nail. It dried out, cracked, vibrated loose and left a small bundle of wires to vibrate against the aluminum bracket, which they did for Heaven knows how many hours... before it wore through the insulation, shorted out and set the insulation on fire. Lotsa sixty year old white smoke but that was about it, plus welding the wire to the bracket and blowing the breaker. And no, this thing right here in my hand is NOT the original grommet, it's the one next to it... there were about six of them, all in this condition. But here's the Lesson that goes with this little billy-dew: Almost every piece of rubber in the whole damn plane is in similar condition. (And here's another lesson: Where are you going to find someone to rewire it? Because with that attitude of yours it sure as hell ain't going to be me -- nor by any one I know, least ways not at this airport :-) -R.S.Hoover PS -- Nope, I'm not an A&E. But neither are about 90% of the people maintaining America's airplanes, from Piper 'Cubs' to Boeing 747's. What they are, are guys working 'under instruction,' meaning there's a certified Someone, somewhere out there on the hangar floor. Bucking rivets, pulling wire, assembling an engine, replacing a tire... all that sorta work. But don't expect to find 'Am Pan' on the back of his coveralls nor anyone passing out 1099-R's neither. |
"RST Engineering" wrote in message
m... . . And it takes about 20% more time to do the wiring on a NEW airplane or a COMPLETE REBUILD on an old one to get the good old aviation white wire insulation and down to Staples for 9 marking pens; black, brown, red, orange, yellow, green, blue, violet, and gray. (0, 1, 2, 3, 4, 5, 6, 7, 8, and 9) Assign each wire in the aircraft a number in accordance with a little thought about what the numbers really mean. With three digits you can have about 800 wires, with four digits 8000. Above that, you are making a 747. Each wire starts off with a double stripe of the lead digit. Then one stripe on the insulation for the second digit, and so on. FOr example, wire #234 would start off with two thin red stripes around the circumference of one end of the wire, then a single orange stripe, then a yellow stripe. THen a CLEAR shrink sleeve around the whole "number". Repeat at the far end. And skip wire #233, or any with repeating last digits. Otherwise you end up with red-red-orange-orange. You couldn't distinguish that from wire #322. |
"RST Engineering" wrote in message m... . . And it takes about 20% more time to do the wiring on a NEW airplane or a COMPLETE REBUILD on an old one to get the good old aviation white wire insulation and down to Staples for 9 marking pens; black, brown, red, orange, yellow, green, blue, violet, and gray. (0, 1, 2, 3, 4, 5, 6, 7, 8, and 9) Assign each wire in the aircraft a number in accordance with a little thought about what the numbers really mean. With three digits you can have about 800 wires, with four digits 8000. Above that, you are making a 747. Each wire starts off with a double stripe of the lead digit. Then one stripe on the insulation for the second digit, and so on. FOr example, wire #234 would start off with two thin red stripes around the circumference of one end of the wire, then a single orange stripe, then a yellow stripe. THen a CLEAR shrink sleeve around the whole "number". Repeat at the far end. Or, get yourself some colored shrink and do the whole job with about half the time. Same drill, but this time the first digit is twice as wide as the rest of them. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle I really like this idea, especially the colored heat shrink version which works just as well with Telfon and Tefzel which did not acept stamped numbers very well--even when I had a stamping machine available. The marking pen is most usefull on Mil-W-5086 and the older (PVC) version of Mil-W-16878; and should also be kept away from sunlight; but the colored shrink tube "rocks"! Peter |
On Jan 1, 4:24*pm, "Peter Dohm" wrote:
I really like this idea, especially the colored heat shrink version ---------------------------------------------------------------------------- Do you know a good source of small quantities of the required colors? Writing on white (or at least, light colored) Heat Shrink is a pretty good way of identifying the lead. -Bob |
wrote in message ... On Jan 1, 4:24 pm, "Peter Dohm" wrote: I really like this idea, especially the colored heat shrink version ---------------------------------------------------------------------------- Do you know a good source of small quantities of the required colors? Writing on white (or at least, light colored) Heat Shrink is a pretty good way of identifying the lead. -Bob Harbor freight? |
wrote in message ... On Jan 1, 4:24 pm, "Peter Dohm" wrote: I really like this idea, especially the colored heat shrink version ---------------------------------------------------------------------------- Do you know a good source of small quantities of the required colors? Writing on white (or at least, light colored) Heat Shrink is a pretty good way of identifying the lead. -Bob That's a fair question, and I admit that I haven't had occasion to buy this sort of thing in about a decade. Locally, in Florida, I used to buy heat shrink from Electronic Equipment Company, Vance Baldwin Electronics and occasionally Deanco (if I recall the name correctly) in the Orlando area. I did a Google search using the keywords: color coded heat shrink tube http://www.google.com/search?hl=en&q...earch&aq=f&oq= which gave a lot of results, but most provide only a few of the colors. The most promising for very small quantities, meaning only a couple of four foot sticks of each color and size, is http://www.justradios.com/heatshrinktubing.html and they appear to be set up for completely automated ordering on line with very economical shipping. Interestingly, they also look good for large quantities and spools are shipped free. I was curious, and also gave a phone call to Cable Specialties. They sell in a minimum of 100 foot packages, so you would need to purchase 1000 feet of the same size in addition to the clear and extra black; which is more than most hobbyists would consider at one time. However, they appear to be an excellent value for "shop" quantities, and carry a wide variety of types by Mil-Spec. Of course, those numbered Brady Labels, with a sleeve of clear heat shrink, are another old stand by--in addition to your suggestion of writing on light colored heat shrink, and possibly placing a clear sleeve over the result. But anything other than a stamping machine will make you crazy if you try to follow the Mil-Spec, or Boeing, workmanship standards to break wires out of the resulting bundles! I hope this helps. Peter |
| Grumman Tracker | niceguy[_2_] | Aviation Photos | 0 | November 9th 08 06:56 PM |
| Fly Argentina, concluded - S2F Tracker Arg.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | December 12th 06 02:23 PM |
| Fly Argentina, concluded - S2F Tracker.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | December 12th 06 02:23 PM |
| flight tracker needed asap! | Paul Turner | General Aviation | 4 | September 21st 05 10:41 AM |
| FS: Tracker Blue GPS | Jon Hicks | Aviation Marketplace | 0 | July 7th 04 03:43 AM |
