Considering Refinishing Club/Standard Class Gliders for part time job
Old January 2nd 09, 02:50 PM posted to rec.aviation.soaring
Default Considering Refinishing Club/Standard Class Gliders for part time job
My job has really slowed down recently. I went from working nearly
all month to having 20 days off. Now that work has slowed down, I'm
looking for a side job.
Yes I've heard that refinishing sailplanes is extremely boring...well
so is, watching TV. I need something to do. I helped refinish the
wings on an asw-19 in high school,. Two months ago I overhauled/
polished my asw-15 fuselage from 400..on up to, 1500 grit sandpaper,
then waxed to a mirror finish. It made it far nicer than I would have
thought.
If I did this for a side income, I would only want to do a club class
or standard class glider. That seems easier to do and not have to
work around flaps and the extra stuff that adds more time. I've got a
place to work on the glider, in a large garage, for just a couple
hundred dollars a month. Also I have a couple advisors nearby who
have done this work before, both AP's and IA's who can sign off this
work.
I hear people saying that it's costing them up to 20,000 dollars to
have a glider refinished. If I only charged 10,000 (since I'm of low
experience), for a less complex glider, is this reasonable to say
someone might hire me? Is it also reasonable to say working 3 full
days a week, to get it done in 2-3 months?
Any thoughts would be great. I'm filling out applications for other
types of work too. I'd rather work in and around some sort of
aviation.
Happy New Year!
SA
Old January 2nd 09, 04:08 PM posted to rec.aviation.soaring
Brad[_2_]
Default Considering Refinishing Club/Standard Class Gliders for part timejob
On Jan 2, 6:50*am, wrote:
My job has really slowed down recently. *I went from working nearly
all month to having 20 days off. *Now that work has slowed down, I'm
so is, watching TV. *I need something to do. *I helped refinish the
wings on an asw-19 in high school,. *Two months ago I overhauled/
then waxed to a mirror finish. *It made it far nicer than I would have
thought.
or standard class glider. *That seems easier to do and not have to
work around flaps and the extra stuff that adds more time. *I've got a
hundred dollars a month. *Also I have a couple advisors nearby who
work.
have a glider refinished. *If I only charged 10,000 (since I'm of low
someone might hire me? *Is it also reasonable to say working 3 full
Any thoughts would be great. *I'm filling out applications for other
types of work too. *I'd rather work in and around some sort of
aviation.
Happy New Year!
SA
Scott,
I think anyone doing this type of work has to have a fair bit of
artistic talent, patience, a good sense of touch and a great eye for
detail.
Then you will need a bunch of tools for gel-coat removal, and re-
application; of gelcoat, or of the sprayable polyester fillers
available and equipment to apply them. Sanding blocks off all sizes
and densities, rules and splines and other contouring devices, and a
knowledge of how to use them. You could probably learn all this "on
the job", but be prepared and have lot's of patience.
Good luck!
BTW..................join us at one of our Akafliegs someday and you
can learn a lot about composite construction as well.
Brad
Old January 2nd 09, 04:28 PM posted to rec.aviation.soaring
DRN
thought.
work.
aviation.
Happy New Year!
SA
Scott,
detail.
Good luck!
Brad
Brad - You didn't check his weight and boot size !
See ya, Dave
Old January 2nd 09, 05:03 PM posted to rec.aviation.soaring
Brad[_2_]
thought.
work.
aviation.
Happy New Year!
SA
Scott,
detail.
Good luck!
Brad
See ya, Dave- Hide quoted text -
- Show quoted text -
Dave.....................you are right!
on the job application that will/would be grounds for elimination from
consideration due to violation of the preparation of the
lamination....................good call......
Brad
Old January 2nd 09, 07:12 PM posted to rec.aviation.soaring
How do I post a picture on here? Is that possible?
I'd like to show the before and after pictures of my ASW-15.
Ok seem's like I'm up to the challenge. I'm pretty fastidious when it
comes to cosmetic stuff like this. I made my glider do a 180 in it's
image. I spent endless hours in the garage and in the back yard,
sweeping through all the details to make it look new again. It came a
long way, and I can make it look even better with the plans I have yet
to complete. Lots of fun for me, listen to talk radio, good 80's
music, and have the ability to stand back to look at what you've
done.
Old January 2nd 09, 04:58 PM posted to rec.aviation.soaring
Andy[_1_]
Good luck. You will probably get a variety of replies but mine is
that no one in their right mind would pay someone with low experience
to refinish their glider.
On the other hand I've seen some really nasty examples of what can
happen when an experienced refinisher farms out some of the high labor
work, so just contracting with someone experienced does not mean they
will do all the work. They will be good at hiding the mistakes
though. When it's all shinny who will know if those grind throughs
were repaired properly or just covered with primer?
If you really want to get into this, try finding an experienced
refinisher that will take you on as an apprentice.
Andy
Old January 2nd 09, 08:09 PM posted to rec.aviation.soaring
Greg Arnold[_2_]
Default Considering Refinishing Club/Standard Class Gliders for parttime job
Andy
I would think you need to refinish one glider first, just to figure out
what is involved, to convince potential customers that you can do it,
and to learn whether this really is something you want to do.
Refinishing is a lot more involved than just polishing a glider. Maybe
a friend has a glider that badly needs refinishing?
There are a lot of amateur refinish jobs out there, and the biggest
problem with them is that boredom often hits before all the old gelcoat
is removed. Unfortunately, the effects of this don't show up until
later, so there are reasons that people paying good money for
refinishing prefer to go to someone with a proven track record.
Old January 3rd 09, 12:03 AM posted to rec.aviation.soaring
Good luck. *You will probably get a variety of replies but mine is
will do all the work. *They will be good at hiding the mistakes
though. *When it's all shinny who will know if those grind throughs
Andy
Refinishing is a lot more involved than just polishing a glider. *Maybe
is removed. *Unfortunately, the effects of this don't show up until
refinishing prefer to go to someone with a proven track record.- Hide quoted text -
Andy,
Good point....well taken. I think I will use this free time, to do
the wings on my ASW-15, they really need it.
Old January 3rd 09, 08:21 PM posted to rec.aviation.soaring
John Bojack[_2_]
There's a big difference between sanding/polishing existing gel coat.....and
a true refinish job.
You'd probably earn more and work less hard at MacDonald's.
Andy
quoted text -
Andy,
Club Class Gliders Sam Giltner[_1_] Soaring 4 December 3rd 08 03:28 AM
The Future of the Standard Class charlie foxtrot Soaring 1 July 7th 06 08:17 AM
Motor gliders in Standard and 15-meter class? wiktor256 Soaring 0 July 23rd 05 08:51 AM
US Standard Class and World Class Nationals at Hobbs Ken Sorenson Soaring 7 July 16th 04 04:03 AM
UK Open Class and Club Class Nationals - Lasham Steve Dutton Soaring 0 August 6th 03 10:07 PM
