Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Products
A question about transducer function
Old January 3rd 09, 03:15 AM
waistgunner waistgunner is offline
Junior Member
First recorded activity by AviationBanter: Jan 2009
Default A question about transducer function
In respect to an autopilot system, can anyone describe the path, more so what happens, from the A/P control in the cockpit to the transducer and lastly the flight controls?
I know what a transducer does. it converts one form of energy into a different form The transducer in this system is a pressure transducer. what type of energy enters the transducer and what does it convert it to in respect to the A/P system?
thanks,
matt
Old January 12th 09, 09:10 PM posted to rec.aviation.products
James M. Knox
waistgunner wrote in
[Warning: Extremely simplified answer.]
The pressure transducer is for altitude. The air pressure is converted by
the tranducer to a voltage. This is compared with another semi-fixed
voltage representing the desired altitude. That difference is amplified
and fed by the autopilot to a servo motor to move the control surfaces to
cause a climb (or descent, depending on the sign of the difference).
Similar for direction hold. In the simplest case (wing leveler) a pickoff
from the AH generates a voltage that corresponds to the amount by which the
wings are no longer level (and the sign represents left or right wing dip).
The signal is amplified and fed to aileron servos to move them in a
direction opposite to that of the bank angle. Bingo... the wings level
themselves again.
Add a similar input from a heading bug off the DG and you have heading
hold. Add a voltage from the VOR or GPS deviation and you have tracking.
Variations include roll-rate gyros and accelerometer transducers.
James M. Knox
TriSoft ph 512-385-0316
1300 Koenig Lane West fax 512-371-5716
Suite 200
Austin, Tx 78756
Old July 4th 11, 03:23 AM
KateDaring52 KateDaring52 is offline
Junior Member
First recorded activity by AviationBanter: Jul 2011
Quote:
Originally Posted by NerRemengelry View Post
Does your GG mod make your rex RUN like a grocery getter too?
Great post! It's very nice. Thank you so much for your post.
Lower Price Invicta Men's Stainless Steel Multi-Function Watch 3350 [email protected] Piloting 0 April 17th 08 07:33 AM
Cell phones in gliders - tracking function Bill Daniels Soaring 10 May 13th 07 05:58 AM
Gemini Diagrams of Spacecraft Reaction Control System (RCS) Function S64-03506.jpg [email protected] Aviation Photos 0 April 9th 07 08:47 PM
Parallel Track function in GPS? Roy Smith Instrument Flight Rules 25 April 30th 04 12:57 AM
A-10 lift transducer B2431 Military Aviation 5 October 23rd 03 02:47 AM
