My 3970 that runs Winpilot has died and I need to replace it. I have a 3900
cradle fitted to the cockpit. What can you guys recommend that will run Winpilot? I believe the 5500 series IPAQ will fit in the same cradle. Can anyone confirm this? What about other models? The IPAQ 214 is more powerful but I would have to feed it by bluetooth. Has anyone done this? Which model has the brightest screen? I am getting older and the eyes don't work as well as they did! Will Winpilot run on the HP314? This has a big bright screen and is very cheap. Suggestions based on experience would be very welcome. Thanks Jim |
The cradle should not be your major argument for selecting a PDA.
Luminosity, power consumption and size of screen should be.... Today, my favourite selection would be the Loox N560 (it has an incorporated GPS antenna). It works perfectly with SeeYou and XCSoar. Bruno |
Hi Jim,
Please see my notes below. Good Soaring, Paul Remde Cumulus Soaring, Inc. http://www.cumulus-soaring.com "Jim White" wrote in message ... My 3970 that runs Winpilot has died and I need to replace it. I have a 3900 cradle fitted to the cockpit. What can you guys recommend that will run Winpilot? I believe the 5500 series IPAQ will fit in the same cradle. Can anyone confirm this? What about other models? - Your cradle will work with any iPAQ h3800, h3900 or h5000 series Pocket PC. Many glider pilots consider the h3800 to be the easiest of those to read in sunlight. You can probably find a good used one on eBay. The IPAQ 214 is more powerful but I would have to feed it by bluetooth. Has anyone done this? - I have done testing with both a CF Card Serial Port and using the K6 Bt BlueTooth Adapter in my iPAQ 210. The serial port option is less "elegant" looking, but works well for all communications and with all soaring software. The K6 Bt connection works well with software that has been written to work with it. I don't know if WinPilot supports the K6 Bt. SeeYou Mobile does. Which model has the brightest screen? I am getting older and the eyes don't work as well as they did! - Unfortunately, no PDA is great in sunlight. The iPAQ h3800 would be slightly easier to see than your h3900. The iPAQ hx4700 is bigger, higher resolution and a little brighter and the iPAQ 210 is a the same size and resolution as the hx4700 and a little brighter. I think the iPAQ 310 is the brightest option. Will Winpilot run on the HP314? This has a big bright screen and is very cheap. - The K6 Bt BlueTooth Adapter works great with the iPAQ 310/314, but I don't know if WinPilot supports the K6 Bt. Suggestions based on experience would be very welcome. - If I were you I would first try to find a used h3800 on ebay. - If you want a "wired" connection I recommend the iPAQ 210 with a CF Serial Card. You can see details on that he http://www.cumulus-soaring.com/nimbus.htm - If you find the WinPilot will work with the K6 Bt BlueTooth Adapter then you may want to consider the iPAQ 310/314. You can see details on the K6 Bt he http://www.cumulus-soaring.com/k6.htm Thanks Jim |
Paul Remde wrote:
- If you find the WinPilot will work with the K6 Bt BlueTooth Adapter then you may want to consider the iPAQ 310/314. You can see details on the K6 Bt he http://www.cumulus-soaring.com/k6.htm I suggest you ask Winpilot if they will be supporting the HP 314 and taking advantage of it's much more powerful hardware. SeeYou is adapting SeeYou Mobile to run on it (Mobile is available in beta version now for the 314), and says the 10 to 20 times more powerful processor will allow features not possible on the Ipaqs. A new, low cost, bright screen, high performance display for the cockpit is compelling, I think, even with the extra hassle of using Bluetooth. And you can use it to help get you the airport, too! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Eric or Paul, can you briefly summarize whether/how the 314 would/
could get the RS232 data from a Cambridge 302? (iow is there a RS232- to-Bluetooth device, and where does it get its power and how much does it consume?) |
On Jan 7, 8:05*am, Tuno wrote:
Eric or Paul, can you briefly summarize whether/how the 314 would/ could get the RS232 data from a Cambridge 302? (iow is there a RS232- to-Bluetooth device, and where does it get its power and how much does it consume?) Ted, I have tied a Gridconnect firefly serial to blue tooth converter. The firefly is on the 302. I have not been able to get a valid GPS signal on either a Ipaq 5555, 4700 or 310. Richard www.craggyaero.com |
Tuno: your questions are completely answered at the link that Paul
indicated to his very nice website: http://www.cumulus-soaring.com/k6.htm |
D'oh! How'd I miss that. Looks very nice.
Now all I need is for WinPilot to run on the 310! (Hint Jerry HINT HINT HINT) 2NO |
On Jan 7, 5:33*am, "Paul Remde" wrote:
Hi Jim, Please see my notes below. Good Soaring, Paul Remde Cumulus Soaring, Inc.http://www.cumulus-soaring.com "Jim White" wrote in message ... My 3970 that runs Winpilot has died and I need to replace it. I have a 3900 cradle fitted to the cockpit. What can you guys recommend that will run Winpilot? I believe the 5500 series IPAQ will fit in the same cradle. Can anyone confirm this? What about other models? *- Your cradle will work with any iPAQ h3800, h3900 or h5000 series Pocket PC. *Many glider pilots consider the h3800 to be the easiest of those to read in sunlight. *You can probably find a good used one on eBay. The IPAQ 214 is more powerful but I would have to feed it by bluetooth. Has anyone done this? *- I have done testing with both a CF Card Serial Port and using the K6 Bt BlueTooth Adapter in my iPAQ 210. *The serial port option is less "elegant" looking, but works well for all communications and with all soaring software. *The K6 Bt connection works well with software that has been written to work with it. *I don't know if WinPilot supports the K6 Bt. SeeYou Mobile does. Which model has the brightest screen? I am getting older and the eyes don't work as well as they did! *- Unfortunately, no PDA is great in sunlight. *The iPAQ h3800 would be slightly easier to see than your h3900. *The iPAQ hx4700 is bigger, higher resolution and a little brighter and the iPAQ 210 is a the same size and resolution as the hx4700 and a little brighter. *I think the iPAQ 310 is the brightest option. Will Winpilot run on the HP314? This has a big bright screen and is very cheap. *- The K6 Bt BlueTooth Adapter works great with the iPAQ 310/314, but I don't know if WinPilot supports the K6 Bt. Suggestions based on experience would be very welcome. Checking the XCSoar forum it seems that some folks using the HP 310 are not that impressed with the display in sunlight. It turns out to be no better than a good IPAQ in comparison. The HP38XX series seems to be best. The link below will show photo comparisons and opinions from users. http://www.nabble.com/Adding-a-seria...o20825419.html Mike *- If I were you I would first try to find a used h3800 on ebay. *- If you want a "wired" connection I recommend the iPAQ 210 with a CF Serial Card. *You can see details on that hehttp://www.cumulus-soaring.com/nimbus.htm *- If you find the WinPilot will work with the K6 Bt BlueTooth Adapter then you may want to consider the iPAQ 310/314. *You can see details on the K6 Bt hehttp://www.cumulus-soaring.com/k6.htm Thanks Jim |
On Jan 7, 8:56*am, Mike wrote:
On Jan 7, 5:33*am, "Paul Remde" wrote: Hi Jim, Please see my notes below. Good Soaring, Paul Remde Cumulus Soaring, Inc.http://www.cumulus-soaring.com "Jim White" wrote in message ... My 3970 that runs Winpilot has died and I need to replace it. I have a 3900 cradle fitted to the cockpit. What can you guys recommend that will run Winpilot? I believe the 5500 series IPAQ will fit in the same cradle. Can anyone confirm this? What about other models? *- Your cradle will work with any iPAQ h3800, h3900 or h5000 series Pocket PC. *Many glider pilots consider the h3800 to be the easiest of those to read in sunlight. *You can probably find a good used one on eBay. The IPAQ 214 is more powerful but I would have to feed it by bluetooth. Has anyone done this? *- I have done testing with both a CF Card Serial Port and using the K6 Bt BlueTooth Adapter in my iPAQ 210. *The serial port option is less "elegant" looking, but works well for all communications and with all soaring software. *The K6 Bt connection works well with software that has been written to work with it. *I don't know if WinPilot supports the K6 Bt.. SeeYou Mobile does. Which model has the brightest screen? I am getting older and the eyes don't work as well as they did! *- Unfortunately, no PDA is great in sunlight. *The iPAQ h3800 would be slightly easier to see than your h3900. *The iPAQ hx4700 is bigger, higher resolution and a little brighter and the iPAQ 210 is a the same size and resolution as the hx4700 and a little brighter. *I think the iPAQ 310 is the brightest option. Will Winpilot run on the HP314? This has a big bright screen and is very cheap. *- The K6 Bt BlueTooth Adapter works great with the iPAQ 310/314, but I don't know if WinPilot supports the K6 Bt. Suggestions based on experience would be very welcome. Checking the XCSoar forum it seems that some folks using the HP 310 are not that impressed with the display in sunlight. It turns out to be no better than a good IPAQ in comparison. The HP38XX series seems to be best. The link below will show photo comparisons and opinions from users. http://www.nabble.com/Adding-a-seria...o20825419.html Mike *- If I were you I would first try to find a used h3800 on ebay. *- If you want a "wired" connection I recommend the iPAQ 210 with a CF Serial Card. *You can see details on that hehttp://www.cumulus-soaring.com/nimbus.htm *- If you find the WinPilot will work with the K6 Bt BlueTooth Adapter then you may want to consider the iPAQ 310/314. *You can see details on the K6 Bt hehttp://www.cumulus-soaring.com/k6.htm Thanks Jim- Hide quoted text - - Show quoted text -- Hide quoted text - - Show quoted text - Mike, I have compared the ipaq 310 side to side with the Ipaq 5555 and Ipaq 4700 and I also not impressed the difference in my opinoin is slight. During the design of the Craggy Aero Ultimate. I found that many problems with visibitiy are due to the touchscreen overlay. If you want to ruin a display put a touchsceen overlay on it. Luminisity, Contrast Ratio, and Brightness are also important factors and the ipaqs do not have high enough values. I designed the Ultimate so Sunlight does not effect the visibilty. Richard www.craggyaero.com |
DME recommendations | mindenpilot | Owning | 27 | April 11th 05 05:23 PM |
Recommendations - near FLL | Hilton | Piloting | 2 | March 16th 05 06:04 AM |
CHT recommendations | Dude | Owning | 3 | December 26th 04 05:07 PM |
MFD recommendations | Richard Kaplan | Owning | 13 | January 27th 04 04:04 PM |
Kit recommendations | another fool | Home Built | 9 | November 10th 03 03:29 PM |
