SeeYou Flight Display
Old January 10th 09, 11:21 PM posted to rec.aviation.soaring
Hal[_2_]
Default SeeYou Flight Display
I downloaded a flight yesterday from the Cambridge 302. When
displaying with SeeYou there was no wind data. The wind data was
there on a previous flight. I assume the problem is with the 302
log. Anyone seen this problem before?
Old January 10th 09, 11:36 PM posted to rec.aviation.soaring
Tuno
Hal, are you sure about wind data being included in a previous flight?
I've never heard of wind data in a 302 log. It's a calculated
parameter, so having a data sentence for it doesn't make sense.
2NO
Old January 10th 09, 11:43 PM posted to rec.aviation.soaring
Darryl Ramm
2NO
Hal
This was your recent wave flight right? What exactly are you seeing
that says no wind? The windsock? It's possible that you are looking at
a part of the flight that SeeYou just does not have you turning enough
in to calculate the wind. I'll load your file when I'm near my copy of
SeeYou and look at it.
Darryl
Old January 11th 09, 12:02 AM posted to rec.aviation.soaring
Hal[_2_]
2NO
Hal
Darryl
No windsock and no wind info on the stats page. I don't understand
how the wind calculation is done in the 302 or for that matter SeeYou
display. I am sure I turned enough to have wind information. The 302
and winpilot were displaying the wind althought I am not sure it was
accurate all the time and I thought I could look at SeeYou to see if
it was accurate.
Old January 11th 09, 12:37 AM posted to rec.aviation.soaring
Paul Remde
Hi,
The wind data calculated by the 302 is not saved in the flight log. SeeYou
uses wind drift while circling to estimate the wind speed and direction
throughout the flight.
Paul Remde
"Hal" wrote in message
2NO
Hal
Darryl
it was accurate.
Old January 11th 09, 05:02 AM posted to rec.aviation.soaring
Darryl Ramm
On Jan 10, 3:37*pm, "Paul Remde" wrote:
Hi,
The wind data calculated by the 302 is not saved in the flight log. *SeeYou
Paul Remde
Hi Hal
The 302 does it's internal wind calculation using TAS vs. GPS
groundspeed to try to do better than just pure circling. Winpilot Pro
will also use TAS data output on the NMEA stream to also better
calculate wind in flight. I'm pretty sure it is doing this, not
directly reading the wind data that the 302 computes itself (and can
also put on its NMEA stream), since at times you'll see differences
between what a 303 display says and what WinPiltot Pro calculates.
SeeYou Mobile definitely does it's own wind calculations from the TAS
data and does not read the 302 calculated wind data. WinPilot Adv does
not use the TAS/GS enhanced calculation.
This wind calculation that SeeYou Mobile and (very likely) Winpilot
Pro ignore is calculated in the Cambridge 302, some people seem to
think the 303 is needed for this. The 303 is just a display. Obviously
you need it to see the 302 calculated wind, but the 302 can also send
this calculation on the NMEA stream without a 303 being attached. Just
most PDA software appears to ignore it. As I would if I was writing
the PDA software -- I'd want to be fully in control of my own wind
algorithm.
When not thermalling I find I only needs some smooth flight with turns
+/- 30 or so either side of track for few minutes to get reasonable
wind updates from the 302/303 or SeeYou Mobile and I'd be surprised if
Winpilot Pro is much different.
The 302/303 and WinPilot Pro show very good instantaneously calculated
headwind which is handy you can just point into wind and see the
maximum headwind component while in wave and this will be very
accurate.
Lets me expand on what Paul is saying about SeeYou (desktop not
Mobile) and wind. SeeYou (desktop) *can* use enhanced TAS data to
calculate wind from an IGC file - but obviously the file needs to
contain the TAS data. If you are downloading an IGC file from your
Cambridge 302 it won't have this, even though the Cambridge can put
this out on the NMEA steam. However the IGC logger built into Winpilot
Pro and SeeYou Mobile and maybe other PDA software will record (a sub-
sample of) the enhanced TAS data from the Cambridge 302 NMEA steam in
the B-records. Look at the header of any IGC file if you see the
string "TAS" in the I record (which describes the B-record format)
then it's recording TAS (or at least leaving space to do so).
In my 26E I have a Cambridge 302/303 and a PDA running SeeYou Mobile.
I'll mostly use SeeYou Mobile for Wind but will check against the 303
display. I'll download an IGC flight log from the 302 and use that for
OLC and similar since motorgliders require need the ENL (engine noise)
support for OLC. I also have SeeYou Mobile logging at 1 sample/sec for
nice smooth traces and will use that in SeeYou for flight analysis -
and it has the added benefit since it has TAS data embedded. (Since
I'm trying to see if my C302 security fail issues have been fixed I
also have that logging it at 1 sample /sec.).
You might want to look at having Winpilot Pro record a back-up flight
log and use that for analysis like looking at this wave flight.
If you can't do this you can always take a few circles at times just
to mark wind for non-TAS enhanced SeeYou analysis, not always
practical in a wave situations but it usually only takes a few
circles.
(You need to work that Diamond altitude wave flight out of Petaluma.
Do it man!).
Darryl
Old January 11th 09, 03:09 AM posted to rec.aviation.soaring
Brad[_2_]
2NO
Hal
Darryl
I use a Garmin Map60CS and run XCSoar on my PDA. I noticed the same
thing that Hal mentioned a few flights ago myself. On a previous
thermal flight I had lot's of wind "data" I guess, because the
windsock kept moving around and I could see the wind info on the stats
page. Right after that flight we had a wave day. I was really excited
to see the replay to get an idea of direction and strength when
replayed in SeeYou, but alas........no wind info at all. I thought
somthing was wrong until I remembered that XCSoar requires a certain
amunt of circling to determine wind. Of course during the flight there
was no problem at all knowing the wing strength and direction, as it
was readily apparent on my GPS.
Brad
Old January 11th 09, 05:34 AM posted to rec.aviation.soaring
Papa3
On Jan 10, 5:21*pm, Hal wrote:
I downloaded a flight yesterday from the Cambridge 302. *When
displaying with SeeYou there was no wind data. *The wind data was
there on a previous flight. *I assume the problem is with the 302
log. *Anyone seen this problem before?
Hal,
Others have answered, but just thought I'd clarify. I'm assuming the
SeeYou you're talking about above is the desktop version and you were
using it for post-flight analysis (since you say "I downloaded", seems
pretty clear but just checking).
Anyway, if you look at the specs for the IGC log file, you'll see that
the only position data stored is location and time. None of the
calculated data (such as wind) is stored. Thus, whatever SeeYou
displays is based in post-flight calculation using only on position
and time data. As others have pointed out, unless you have some
amount of drift in circling flight, it's impossible for a post-flight
analysis using only this position data to determine wind.
P3
Old January 11th 09, 05:41 AM posted to rec.aviation.soaring
Darryl Ramm
Hal,
Others have answered, but just thought I'd clarify. *I'm assuming the
the only position data stored is location and time. * None of the
calculated data (such as wind) is stored. *Thus, whatever SeeYou
and time data. * As others have pointed out, unless you have some
P3
Sory, this may be a common misconception, but it is not correct. IGC
files B records can contain more than position and time, including ENL
(engine noise) and the magic TAS data used for enhanced wind
calculations. And See You will use that to enhance wind calculations
just as SeeYou Mobile and WinPilog Pro uses. If your sample rate is
fast enough (1 sec?) you should get a fairly accurate replay of the
wind you PDA/computer told you existed during the flight. But yes it a
recalculation, nothing is writing pre-computed wind data to the IGC
file.
Darryl
Old January 11th 09, 08:20 AM posted to rec.aviation.soaring
Bruce
Hal,
P3
file.
Darryl
I do not know the Cambridge 302 - but on the LX loggers you can add a
long list of optional data to the B record. It does consume memory, but
that is no problem with the LX toys...
No idea where / how / if you even can set this on a 302 - but it is
certainly worth exploring.
Seeyou NMEA to Winpilot/Seeyou Jean Soaring 4 June 3rd 06 12:38 PM
U.S. Cloud Images for flight display [email protected] Soaring 0 January 21st 06 08:37 PM
OLC 2006 flight uploads with SeeYou Ted Wagner Soaring 2 October 15th 05 06:31 AM
Dynamic Contest Flight Display Bob Soaring 0 August 8th 05 02:38 PM
OQO Handtop computer for flight display. Guy Byars Owning 2 June 28th 05 04:09 PM
