A thought & question on simulators
Old January 13th 09, 12:09 AM posted to rec.aviation.piloting
Ricky
Default A thought & question on simulators
During my instrument training (early 90s) I spent a lot of time in a
simulator. It was not a new, modern simulator, but it did the job.
I remember going out to the C-172 for instrument training and thinking
how glad I was that I wasn't in the sim today. The plane was like a
breath of relief. Flying the sim was hard, I remember it being more
difficult than the airplane. Induced failures were frequent, things
happened faster, and the sim was not nearly as forgiving as the
airplane.
I have never flown a MS simulator but I do wonder if the thing has the
same level of difficulty that a non-motion sim from the early 90s may
have had? The MS sim I speak of would have a basic lightplane setup
with pedals, yoke, throttle, radios, etc, in other words; as close to
a light plane as is possible in MS. It would also mean the MS sim is
flown as a pilot would be doing in gaining hours & instruction or
recurrency toward his/her instrument rating.
This post is meant for those instrument rated pilots who've flown MS
and a real sim, too, not Anthony.
Ricky
Old January 13th 09, 01:46 AM posted to rec.aviation.piloting
Dudley Henriques[_2_]
airplane.
Ricky
No good for the scenario you describe.
DH
Old January 30th 09, 08:39 PM posted to rec.aviation.piloting
Dylan Smith
I respectfully *strongly* disagree; a PC sim is great for instrument
procedure training if used properly. I used one and it was tremendously
helpful. I set it up with a faster, slipperier plane than I was actually
flying, and it helped greatly on things such as instrument scan,
procedures, partial panel etc.
From the sunny Isle of Man.
Yes, the Reply-To email address is valid.
Old January 31st 09, 12:01 AM posted to rec.aviation.piloting
In the context you are describing you are absolutely correct. I read
the OP as asking about the sim in direct comparison to the physical
action/ reaction of the real airplane which of course the sim cannot
duplicate in any way.
For instrument procedures ONLY, as relates to instrument training, the
sim has many practical uses when used in conjunction with an
instrument instructor, and in fact I have highly recommended it for
that purpose many times in the past and will continue to do so in the
future.
Dudley Henriques
Old January 31st 09, 05:06 AM posted to rec.aviation.piloting
Jon
There has been a fair amount of research done which supports Dudley's
statement. Some of the recently published papers can found he
http://www.volpe.dot.gov/hf/pubs.html
http://www.volpe.dot.gov/hf/docs/aiaa-2007-6564.doc may provide
useful info to some here.
Dudley Henriques
Regards,
Jon
Old February 1st 09, 06:30 AM posted to rec.aviation.piloting
Gezellig
future.
Dudley Henriques
Dudley, you preferred one Microsoft Sim version, which one and why?
Old February 1st 09, 02:06 PM posted to rec.aviation.piloting
future.
Dudley Henriques
I worked with Microsoft on both 2004 and all through FSX. Both
programs are similar as relates to what we have been discussing here.
Without going into a ton of detail, I would simply say that I find
2004 contains everything needed by a CFI or CFII to work with a
student and do that without the glitches and issues that live in FSX.
2004 in my opinion contains very good programming and runs well on
almost all computer systems. FSX requires MUCH more computer power to
run at the same level of smoothness as 2004.
DH
Old January 13th 09, 05:04 PM posted to rec.aviation.piloting
Darkwing
"Ricky" wrote in message
airplane.
Ricky
It's fun shooting approaches to minimums in a 747 into O'Hare but I can't
say MSFS has significantly added to my aviation knowledge. I learn more
reading the posts on RAP (well before all the idiots moved in).
Old January 13th 09, 09:49 PM posted to rec.aviation.piloting
Paul kgyy
airplane.
Ricky
I found MS sim to be overkill for instrument practice and use ASA's
OnTop instead. I find it significantly harder than the airplane.
Part of it is having to use a mouse to tune radios and set up the GPS
- knobs are more efficient. I find the flying also a good deal more
"twitchy" than the plane (76 Bo). You can tell the system what
failures you want it to simulate and it will do that at a random time.
Notwithstanding all of that, I still use it to practice during the
winter when the clouds are full of ice, and even during the rest of
the year if I'm headed out in the plane I may do a practice approach
into the planned airport.
Old January 13th 09, 10:40 PM posted to rec.aviation.piloting
Darkwing
"Paul kgyy" wrote in message
airplane.
Ricky
I was hoping MSFS-X would help me learn the G1000 since it is offered on the
program but it was way to stripped down with only the basic screens so I
can't say I learned much unfortunately. Wonder if they will offer the Garmin
Perspective?! That way you can fly a simulator on the simulator!
A thought on BRS Martin Gregorie Soaring 47 April 29th 04 06:34 AM
Another question about simulators James Blakely Instrument Flight Rules 1 July 25th 03 03:31 PM
