![]() Down in the Hudson |
![]() "Mitchell Holman" schreef in bericht ... Down in the Hudson Remarkable demonstration of airmanship by that pilot. Do you think anyone would have moving pictures of the actual forced landing? Regards, Herman |
"Herman" wrote in
b.home.nl: "Mitchell Holman" schreef in bericht ... Down in the Hudson Remarkable demonstration of airmanship by that pilot. Do you think anyone would have moving pictures of the actual forced landing? Regards, Herman The whole thing happened pretty quickly, I doubt there is any footage of the actual landing. \ |
![]() "Mitchell Holman" wrote in message ... "Herman" wrote in b.home.nl: "Mitchell Holman" schreef in bericht ... Down in the Hudson Remarkable demonstration of airmanship by that pilot. Do you think anyone would have moving pictures of the actual forced landing? Regards, Herman The whole thing happened pretty quickly, I doubt there is any footage of the actual landing. There is a video from a webcam type camera in the vicinity of the piers on the NY side. I'm not sure where you can see it, I saw it on Comcast's The Fan. Rob |
Hello,
Scubabix a écrit dans : "Mitchell Holman" wrote in message ... "Herman" wrote in b.home.nl: "Mitchell Holman" schreef in bericht ... Down in the Hudson Remarkable demonstration of airmanship by that pilot. Do you think anyone would have moving pictures of the actual forced landing? Regards, Herman The whole thing happened pretty quickly, I doubt there is any footage of the actual landing. There is a video from a webcam type camera in the vicinity of the piers on the NY side. I'm not sure where you can see it, I saw it on Comcast's The Fan. http://www.youtube.com/watch?v=3mLKfRVU3qM Skip to 2:00 Rob |
So while everyone was able to succesfully get off, why were there no
Liferafts ? "Mitchell Holman" wrote in message ... Down in the Hudson |
"Glenn" wrote
So while everyone was able to succesfully get off, why were there no Liferafts ? Not required...... FAR 1: Extended over-water operation means— (1) With respect to aircraft other than helicopters, an operation over water at a horizontal distance of more than 50 nautical miles from the nearest shoreline; Section 121.339: Emergency equipment for extended over-water operations. No person may operate an airplane in extended overwater operations without having on the airplane the following equipment: (1) A life preserver equipped with an approved survivor locator light, for each occupant of the airplane. (2) Enough life rafts (each equipped with an approved survivor locator light) of a rated capacity and buoyancy to accommodate the occupants of the airplane. Unless excess rafts of enough capacity are provided, the buoyancy and seating capacity beyond the rated capacity of the rafts must accommodate all occupants of the airplane in the event of a loss of one raft of the largest rated capacity. Section 121.340: Emergency flotation means. (a) Except as provided in paragraph (b) of this section, no person may operate an airplane in any overwater operation unless it is equipped with life preservers in accordance with §121.339(a)(1) or with an approved flotation means for each occupant. This means must be within easy reach of each seated occupant and must be readily removable from the airplane. (b) Upon application by the air carrier or commercial operator, the Administrator may approve the operation of an airplane over water without the life preservers or flotation means required by paragraph (a) of this section, if the air carrier or commercial operator shows that the water over which the airplane is to be operated is not of such size and depth that life preservers or flotation means would be required for the survival of its occupants in the event the flight terminates in that water |
Ok, so there is no provision provided for over land water crashes in sub
zero temperatures. I guess we got lucky that there was a lot of vessels around that got to them quickly. "Robert Moore" wrote in message 5.247... "Glenn" wrote So while everyone was able to succesfully get off, why were there no Liferafts ? Not required...... FAR 1: Extended over-water operation means- (1) With respect to aircraft other than helicopters, an operation over water at a horizontal distance of more than 50 nautical miles from the nearest shoreline; Section 121.339: Emergency equipment for extended over-water operations. No person may operate an airplane in extended overwater operations without having on the airplane the following equipment: (1) A life preserver equipped with an approved survivor locator light, for each occupant of the airplane. (2) Enough life rafts (each equipped with an approved survivor locator light) of a rated capacity and buoyancy to accommodate the occupants of the airplane. Unless excess rafts of enough capacity are provided, the buoyancy and seating capacity beyond the rated capacity of the rafts must accommodate all occupants of the airplane in the event of a loss of one raft of the largest rated capacity. Section 121.340: Emergency flotation means. (a) Except as provided in paragraph (b) of this section, no person may operate an airplane in any overwater operation unless it is equipped with life preservers in accordance with §121.339(a)(1) or with an approved flotation means for each occupant. This means must be within easy reach of each seated occupant and must be readily removable from the airplane. (b) Upon application by the air carrier or commercial operator, the Administrator may approve the operation of an airplane over water without the life preservers or flotation means required by paragraph (a) of this section, if the air carrier or commercial operator shows that the water over which the airplane is to be operated is not of such size and depth that life preservers or flotation means would be required for the survival of its occupants in the event the flight terminates in that water |
"Glenn" wrote: So while everyone was able to succesfully get off, why were there no Liferafts ? From the pictures, it appears that they used the slides as rafts -- standard practice. -- Remove _'s from email address to talk to me. |
Thanks for the posting Mitchell. A good example when a picture is better
than a thousand words. What I find interesting that it occurred without a single boat in the proximately of the ditching which could have been fortunate under the circumstances. Cheers, Avsec |
The ethanol nightmare has arrived! | Al[_2_] | Piloting | 210 | April 24th 08 03:27 PM |
first P-3C CUP Orion arrived at Valkenburg | Marco P.J. Borst | Military Aviation | 1 | May 27th 04 09:42 PM |
first P-3C CUP Orion arrived at Valkenburg | Marco P.J. Borst | Naval Aviation | 1 | May 27th 04 09:42 PM |
(long) WxWorx arrived... | Tom S. | Instrument Flight Rules | 1 | September 10th 03 12:37 AM |
(long) WxWorx arrived... | Dan Luke | Piloting | 0 | September 10th 03 12:37 AM |
