I've seen some excellent lists on this forum for the pilot, glider,
and landout/emergency kit. I'm wondering if anyone has developed a list for the tools, parts & materials to always have in the tow vehicle. I need to assemble a single toolbox that I can transfer between tow vehicles (I use a primary and two alternates). Easy to start with: Screwdriver(s) Electrical tape Wire, wire cutter/crimper, heat shrink tubing Pneumatic tubing and connectors Gaffer tape (awesome stuff) Scissors Multimeter Fuses Yaw string Extra catheters Lighter What am I missing? 2NO (yeah ... software guy) |
Nut drivers/adjustable wrench/pliers
Spare wingtip skids Footpump Spare tube Spare tire At 01:52 18 January 2009, Tuno wrote: I've seen some excellent lists on this forum for the pilot, glider, and landout/emergency kit. I'm wondering if anyone has developed a list for the tools, parts & materials to always have in the tow vehicle. I need to assemble a single toolbox that I can transfer between tow vehicles (I use a primary and two alternates). Easy to start with: Screwdriver(s) Electrical tape Wire, wire cutter/crimper, heat shrink tubing Pneumatic tubing and connectors Gaffer tape (awesome stuff) Scissors Multimeter Fuses Yaw string Extra catheters Lighter What am I missing? 2NO (yeah ... software guy) |
Tuno wrote:
I've seen some excellent lists on this forum for the pilot, glider, and landout/emergency kit. I'm wondering if anyone has developed a list for the tools, parts & materials to always have in the tow vehicle. I need to assemble a single toolbox that I can transfer between tow vehicles (I use a primary and two alternates). Easy to start with: Screwdriver(s) Electrical tape Wire, wire cutter/crimper, heat shrink tubing Pneumatic tubing and connectors Gaffer tape (awesome stuff) Scissors Multimeter Fuses Yaw string Extra catheters Lighter What am I missing? Why not just one box that stays in the trailer? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
Also include:
1/4" drive socket set with metric sockets 5mm through 13mm and SAE sockets 1/4" through 1/2". 25 feet of .032" safety wire. Small hacksaw, small fine-tooth file |
You've left out:
Drill and bits Soldering tool and solder Trailer lighting repair materials Volt Ohm Meter (esp w/continuity checker) -- oops, Tuno had it under "multitester." Tire/ballast bag repair kit (will duct tape suffice? probably not) HAMMER. SAE/metric combo wrenches (for us metal glider drivers) Needle & Thread (for the FABRIC parts) 400 MPH Tape (REALLY Awesome stuff) Bondo & hardener (two things that mix together to make awesome stuff...) Snake Bite Kit (I prefer the Glenlivet, my buddy prefers Chevas). -Pete #309 |
Valve stem extension
Tail wheel items At 05:18 18 January 2009, Bob Kuykendall wrote: Also include: 1/4" drive socket set with metric sockets 5mm through 13mm and SAE sockets 1/4" through 1/2". 25 feet of .032" safety wire. Small hacksaw, small fine-tooth file |
![]() I'm with Eric, I'd leave anything glider related or spares for the glider in the trailer. We both have the luxury of the 26E trailer having a large area up front to carry stuff. What you might carry also depends on what you are doing and how long you'll be away from base. Personally I'll carry a log of stuff in the trailer and truck. My full tool set and car spares stay in the car/truck. If I'm out in the great basin etc. I'll carry things like a full set of belts, hoses and water pump for the truck, many gallons of water, large capacity jumper battery, jumper cables, tubeless tyre patch kit, spare oil, transmission fluid, real factory service manual, heavy duty tow rope, etc... and a roll of fencing wire. (fencing wire can fix about anything). Some other things you might want to consider for the glider are - - I'm lazy and would carry a 12V compressor in my car/truck rather than a foot pump. I carry one of the small ones designed for off-road tire inflation, set up with an small 150PSI tank. Much more heavy duty than the typical parts store junk. If needed I can charge the tank and carry it to the glider. - Tire pressure gauge (get a real quality needle or digital one not the sliding indicator type). - Entire spare tailwheel with tire already mounted - Bicycle spare innertube (to fit wing wheel etc.) - Bicycle innertube patch kit (for wing wheel, tail dolly wheel, etc.) - Spare tire valves (spare innertubes may come with them, an extra spare or two may not hurt) - Tire valve removal tool - Spare tire valve caps (replace any plastic crap ones with good quality ones with a real o-ring seal.) - Any tools required to adjust the wheel brake (try it to make sure you have all the right size tools). I would really only bother for cable brakes. Hydraulic brakes usually stay pretty well adjusted. - 5 or 15 minute epoxy (I've found this awfully handy for misc temporary repairs). I'd only use something like an unopened small syringe type packaging and throw it away after opening so it does not leak. Replace each year. - A variety of multimeter leads, including alligator or fine clip on leads that allow you to use the multimeter hands free while debugging things. - Specific adapter leads for multimeter - e.g. make up a set of leads that allow the multimeter to be pluggged into various things e.g. if your ship uses Anderson powerpoles then cut up a set of multimeter cables and put PowerPole plugs on the ends. Carry similar cables or adapters for any connectors e.g. Powerlet Plugs, various Molex connects etc. - Set of hex wrenches (if your glider uses hex headed bolts) - Set of jewelers screwdrivers - Bright flashlight (for looking inside things/working in the dark) - Inspection mirror - Telescopic magnetic parts picker (for when you drop things down places they should not be - esp. for motorgliders)) - Claw style parts picker (snap-on make great ones) - Spare fuse holder (esp for when you drop an end cap and can't find it) - Spare TE probe - Assorted size nylon cable ties - Spare electric switches - Small rubber stoppers (suitable for blocking pneumatic instrument lines). - Small tip soldering iron and fine rosin core solder (only if stuff has been soldered - check behind the panel). - Might also consider a small butane powered iron if operating where there really is no electricity. - Long electrical extension cord - Electrical power strip (I got into a habit of putting one of these the trailer after seeing things like running out of power outlets for battery chargers etc at some places.). - A small flourescent (or LED ?) leadlight (for working at night/under car etc.) - 20' or so of wire in each of the different sizes used behind the panel (hopefully Trefzel (oops that's another thread)) - Spare misc things like instrument mounting screws, etc. all the sort of things you just collect after a while working on the glider a bit. - Cloth tape and/or wide wing seal type tape - e.g. some gliders use this to attach tail wheel fairings and other things. 1" wing tape may work if needed, but I'd prefer the real cloth tape for some things. - A can of WD-40 - Loctite 262 - A can of 3M adhesive cleaner - Spare elestic cord (used for gear doors, engine bay doors, etc.) and wire to make clips for (I also heatshrink the ends and/or dab with epoxy to make sure they will not let go.). McMaster stocks a good variety. - Lengths of chain and shackles for tying the trailer down (esp. at places like Minden or Parowan during Monsunal weather). - Rolls of paper rag - A tube of hand cleaner - A small ground sheet or tarp to lie on (more useful for under car) - Carry stuff in the car or trailer that can help get you out of being bogged if venturing off-road in a retrieve. e.g. Folding metal blade shovel, short planks of wood, nylon car tow rope, etc. - Gettign off topic... Make sure your ground crew have AAA or similar roadside assistance membership. Lots of navigation help, maps, GPS etc. Carry lots of water and some survival gear. Consider giving them a SPOT messenger in case they get stuck or lost. Darryl |
In my toolbox:
Spare set of Keys for all vehicles, trailer, hangar, airport gate, etc. Small bandages -- I usually nick myself fixing most anything. Gotta slow down. Tire plug kit for the trailer tires. For straightening bent parts of the car or trailer such as fenders damaged by road debris or off-road excursions, a long "wrecking bar". Also good for killing rattlesnakes if unarmed. Hmmm. This trailer's tongue weight is getting a bit heavy! Burt Marfa Gliders, west Texas |
On Jan 17, 9:18*pm, Bob Kuykendall wrote:
Also include: 1/4" drive socket set with metric sockets 5mm through 13mm and SAE sockets 1/4" through 1/2". Since you have a metric glider, I'd over-subscribe on the metric wrenches. If you want to change a tailwheel tire, for instance, you will need two sockets - one for the bolt end and one for the nut end. I have always been fortunate to find someone to borrow from, but am investing in a duplicate set. I also carry enough electrical stuff to remake most of the connectors in my panel. Spare seat pan screws and washers - I don't know how those guys crawl out of the cockpit, but they do Spare yaw string Rubbing and polishing compound and 400-1200 grit sandpaper Battery-powered electric drill/screwdriver Spare batteries for everything battery operated (EDS, Pulse/Ox, SPOT, PDA - and glider of course). Spare glider battery connectors. Keep a spare EDS battery in the cockpit too. Instead of a tarp I use a cheap yoga mat (camping bed pads work too) for taping under the wings in the dirt - it keeps the sharper stones from sticking to my back. 110V power inverter - how else are you going to run the soldering iron 300 yards from the closest outlet? Radio Shack makes decent, compact ones. Ted, you going to post a Word doc with your summary? Andy We've wandered into spares and support equipment and away from tools |
" wrote in message
: SNIP 110V power inverter - how else are you going to run the soldering iron 300 yards from the closest outlet? Radio Shack makes decent, compact ones. I like the small propane powered soldering pencils. Work great. Even with a extra small can of propane, it is much lighter, compact, and versatile than an electric soldering iron and inverter. Zero One |
Checklist | Larry D. Cosby | Piloting | 148 | March 29th 08 04:10 AM |
Checklist use | Private | Piloting | 2 | February 12th 08 08:25 PM |
Landing Checklist | E. Douglas Whitehead | Soaring | 25 | January 7th 06 05:19 PM |
747-100 Checklist | Bartscher | General Aviation | 0 | December 18th 04 07:20 PM |
C-180 100 hr checklist | ConchyJoe | Owning | 1 | May 3rd 04 11:53 PM |
