Where to buy?
Old January 20th 09, 01:28 AM posted to rec.aviation.soaring
AK
Default Where to buy?
Does anyone know where to get thick felt for lining a tail wheel? It
should be around 3/16?
Old January 20th 09, 01:40 AM posted to rec.aviation.soaring
Bob Kuykendall
McMaster-Carr aircraft supplies
Bob K.
Old January 20th 09, 01:45 AM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Where to buy felt?
http://www.centralshippee.com/
They have high quality synthetic stuff, various thicknesses, with or
without pressure sensative adhesive backing.
Steve Leonard
a Happy Central Shippee Customer
Old January 20th 09, 01:47 AM posted to rec.aviation.soaring
bildan
I found it at a gasket materials company. Felt is used in industrial
applications as a gasket, gland or shaft packing material.
For example: http://www.arbanassi.com/english/pro...nifiltsi.htm#1
For tail dolly lining, you need industrial pressed gasket felt. Felt
used for clothing is too soft.
Old January 20th 09, 03:55 AM posted to rec.aviation.soaring
Steve Koerner
My supplier of choice is Sutherland Felt at 248-280-0450.
On Wing Riggers I am using a dense SAE F7 grade material that is 80%
wool.
This material is also available at www.mcmaster.com. Though McMaster
is more expensive, it may be more convenient to buy small quantity
from them.
It might also be of interest to tell you that I did trials with a
number of different adhesives. I found polyurethane adhesive to be
by far the best because it soaks a little ways into the felt and
provides a very solid grip. Gorrilla Glue is one brand of
polyurethane adhesive.
Steve Koerner
www.wingrigger.com
Old January 21st 09, 12:37 AM posted to rec.aviation.soaring
AK
Thank you to all who responded.
Old January 21st 09, 12:18 PM posted to rec.aviation.soaring
Andy[_1_]
Tail wheels are the same size as the front wheels on many wheel
chairs. Wheel chair suppliers used to sell flexible plastic liners
for puncture protection. I used one for many years and never had a
flat.
I did not buy them for the new glider and don't know if they are still
available.
Andy
