Comm Ant. Top or Bottom?
Old January 21st 09, 05:34 PM posted to rec.aviation.homebuilt
Gig 601Xl Builder
Default Comm Ant. Top or Bottom?
It's time to mount my comm antenna and I am getting mixed reviews which
is better top or bottom. Since I doubt I'll be doing any rough field
landings that isn't an issue. I'm sort of leaning to it just doesn't matter.
Old January 21st 09, 05:50 PM posted to rec.aviation.homebuilt
In electrical terms it doesn't really matter, assuming the locations
offer a ground-plane that is more or less identical. But the fact
your airplane did not come with an antenna array already installed
begs the question as to type, age, method of construction and so
forth.
For maintenance however, antennae mounted to the top of the structure
usually offer some benefits. But as always, this is a general rule;
you will run into exceptions... without which this Group could not
survive! :-)
Just be careful not to measure Field Strength readings for a system
using the lower side of the hull, since the proximity of the earth
will skew your readings. Your 'Free Space' radiation pattern should
be identical, top or bottom. But here again, that 'Free Space' only
appears in text books. Ain't nothing 'free' nowadays :-)
-R.S.Hoover
Old January 22nd 09, 05:37 PM posted to rec.aviation.homebuilt
Stuart Fields
"Gig 601Xl Builder" wrote in message
m...
forth.
survive! :-)
-R.S.Hoover
The antenna in question is a Comant CI122 bent whip. Considering all the
advice I will mount it on the bottom but make sure there is enough service
loop in the cable to move it if it doesn't work out.
Excellent comments by Hoover. My measurements on my helicopter definitely
were not "Free Space" but were done with the helo on the ground. However,
the antenna mfr. claims were limited and had a statement of minimum VSWR of
3.
Old January 21st 09, 10:40 PM posted to rec.aviation.homebuilt
stol
On Jan 21, 10:34*am, Gig 601Xl Builder
On my 801 with a Icom- 200 I mounted it on the bottom. You spend 99%
of the time flying and the radios you are transmitting to are on the
face of the earth, ie, under you, so the bottom seems logical.. Mine
works great down there. YMMV.
Ben.
Old January 21st 09, 11:28 PM posted to rec.aviation.homebuilt
stol wrote:
On Jan 21, 10:34 am, Gig 601Xl Builder
Mine is mounted *inside*. :-)
http://www.bowersflybaby.com/stories/antenna.htm
Old January 22nd 09, 12:01 AM posted to rec.aviation.homebuilt
Stuart Fields
"Ron Wanttaja" wrote in message
matter.
I had a bent Com antenna on the bottom of my Baby Belle helicopter. A
survey of its characteristics, looking from the coax fitting that connects
to the Microaire, showed a minimum VSWR of 3 accross the band. This ain't
good. I lost 25% of my range with this. I bought a straight antenna and
couldn't mount it on the bottom due to clearance and Voila VSWR accross the
band was less than 2. Beware of the bent antennas. Antenna mfr says VSWR 3
is normal.
Old January 22nd 09, 12:12 AM posted to rec.aviation.homebuilt
Mine is a bent 1/4 wave length antenna mounted on the top of the metal tail
cone. My radio is a 1 watt Filser ART 57. So far I haven't had a problem
communicating airborne aircraft or ground stations.
http://www.soaridaho.com/Schreder/HP...P-14_N990d.jpg
http://www.soaridaho.com/Schreder/HP...0_Borah_Mt.jpg
http://www.soaridaho.com/Schreder/HP.../N990_rain.jpg
HP-14 "6F"
"Stuart Fields" wrote in message
matter.
the band was less than 2. Beware of the bent antennas. Antenna mfr says
VSWR 3 is normal.
Old January 22nd 09, 03:03 AM posted to rec.aviation.homebuilt
Stuart Fields
"Wayne Paul" wrote in message
tail cone. My radio is a 1 watt Filser ART 57. So far I haven't had a
problem communicating airborne aircraft or ground stations.
HP-14 "6F"
which
matter.
connects to the Microaire, showed a minimum VSWR of 3 accross the band.
This ain't good. I lost 25% of my range with this. I bought a straight
antenna and couldn't mount it on the bottom due to clearance and Voila
VSWR accross the band was less than 2. Beware of the bent antennas.
Antenna mfr says VSWR 3 is normal.
Wayne: All my experience with antennas says that you are not getting as
much as you can due to the high VSWR. That said, if you are getting
everything that you want, why change? Those photos are great. I can
understand why you fly one of them "quiet things". Still haven't gone for a
sail plane ride but it is certainly in my "round to it" bucket.
stu
FAA ranks near bottom in Government employee morale EatMe[_2_] Piloting 0 November 18th 07 02:50 PM
Here is the most bottom price, best quality [email protected] General Aviation 0 October 29th 07 11:46 AM
FAA ranks near bottom in Government employee morale AirSafetyPatriot Piloting 6 October 20th 07 07:37 AM
xb-35-bottom.jpg Troy24 Aviation Photos 0 July 12th 07 12:07 AM
Lightnings Today, concluded - yippee-bottom.jpg (1/1) Mitchell Holman Aviation Photos 0 January 15th 07 02:12 PM
