"Private" wrote in news:jHRdl.109710$4M4.29097
@newsfe02.iad: http://online.wsj.com/article/SB123241485664396363.html Fairly balanced article even if a bit innacurate . The RAT woudl have given them enough even inf the APU had been U/S. With the APU running they had nearly everything available to them Full electrics, except for maybe th egallys, and almost all hydraulics, if a bit slow. Flight controls would have been fine though. Bertie |
On Jan 21, 10:01*pm, Bertie the Bunyip wrote:
"Private" wrote in news:jHRdl.109710$4M4.29097 @newsfe02.iad: http://online.wsj.com/article/SB123241485664396363.html Fairly balanced article even if a bit innacurate . The RAT woudl have given them enough even inf the APU had been U/S. With the APU running they had nearly everything available to them Full electrics, except for maybe th egallys, and almost all hydraulics, if a bit slow. Flight controls would have been fine though. Bertie I can almost see the 'bonus' round in the simulator now. Same conditions only *bingo* a ferry adrift right where you want to be. And perhaps a newsie copter tagging along covering the story. If you get that one right, let's pop in some low ceilings and if you're still alive you'll progress to the fog. Bwahahahah!! "Test to destruction". |
.. It has been nearly fifty years since I went to Boeing school, so please forgive the misrememberances. As I recall, once the engines spool up and take the load, the APU is shut down and once the aircraft has departed, the squat switches have to be enabled to restart the APU. It cannot be started airborne. At least that is my memory. The reason I say that is that I was trying to do some autopilot work for which I needed electrics and hydraulics and with the airplane on jacks, I couldn't get the APU to fire up. Perhaps one of the sparkies pulled a breaker somewhere so that I couldn't accidentally activate the gear via the APU/electrics/hydraulics, but I also remember something in school about it. Jim -- "It is the mark of an educated mind to be able to entertain a thought without accepting it." --Aristotle With the APU running they had nearly everything available to them Full electrics, except for maybe th egallys, and almost all hydraulics, if a bit slow. Flight controls would have been fine though. Bertie |
RST Engineering wrote:
It has been nearly fifty years since I went to Boeing school, so please .... squat switches have to be enabled to restart the APU. It cannot be started airborne. I hardly believe that the Boeing school of 50 years ago covered Airbus systems. Besides, I'd assume that a plane entrely flown by wire must provide features which guarantee controllability even in the event of a complete engine failure to get certified in the first place. |
"John Smith" wrote in message
... RST Engineering wrote: It has been nearly fifty years since I went to Boeing school, so please ... squat switches have to be enabled to restart the APU. It cannot be started airborne. I hardly believe that the Boeing school of 50 years ago covered Airbus systems. No, but it covered 727 systems and one might suspect that Boeing had a reason to disable APU starts in midair. Engineering design generally builds on successful designs in the past. Besides, I'd assume that a plane entrely flown by wire must provide features which guarantee controllability even in the event of a complete engine failure to get certified in the first place. Look up the etymology of the verb "assume" some day. Jim |
"RST Engineering" wrote in
m: . . It has been nearly fifty years since I went to Boeing school, so please forgive the misrememberances. As I recall, once the engines spool up and take the load, the APU is shut down and once the aircraft has departed, the squat switches have to be enabled to restart the APU. It cannot be started airborne. At least that is my memory. The reason I say that is that I was trying to do some autopilot work for which I needed electrics and hydraulics and with the airplane on jacks, I couldn't get the APU to fire up. Perhaps one of the sparkies pulled a breaker somewhere so that I couldn't accidentally activate the gear via the APU/electrics/hydraulics, but I also remember something in school about it. You remember correctly, but only for the transversely mounted APUs in the 707 and 727. All those tail mounted APUs can be run throughout the flight and sometimes are if, for instance, an engine driven genny is U/S. They can be started in flight, even, and for Cat 3 landings they usually ae, though this is usually not a requiement to do the Cat 3 Bertie |
You remember correctly, but only for the transversely mounted APUs in the 707 and 727. No APUs in 707s, but I have seen some private operators put a unit in the forward cargo compartment that swung out and sat on the ground for operation. Bob Moore |
Robert Moore wrote in
5.250: Bertie the Bunyip wrote You remember correctly, but only for the transversely mounted APUs in the 707 and 727. No APUs in 707s, but I have seen some private operators put a unit in the forward cargo compartment that swung out and sat on the ground for operation. OK, Seen a few that had them and was led to believe they had the same installation as the 727. Bertie |
Information on Ditching | Dylan Smith | Piloting | 2 | May 5th 05 02:19 AM |
Ditching at Sea | Mike Keown | Naval Aviation | 5 | November 17th 03 09:58 PM |
Ditching Gear Down | Dave Kearton | Military Aviation | 18 | October 7th 03 10:27 PM |
Ditching Gear Down | Mike Keown | Naval Aviation | 6 | October 6th 03 04:39 PM |
Kinda morbid I guess, big iron enroute ditching | Dylan Smith | Piloting | 20 | August 15th 03 07:03 AM |
