T Tailed Libelle?
Old February 4th 09, 03:24 PM posted to rec.aviation.soaring
Gary Boggs
Default T Tailed Libelle?
I see on Wings and Wheels there is a T tailed Libelle for sale. I
don't think I've ever seen one of these before. I don't see any
reference of that configuration on the sailplane index. Can anyone
give me any info on them, like how many were made this way, and any
other relevant info?
Thanks
Boggs
www.nwskysports.com
Old February 4th 09, 03:40 PM posted to rec.aviation.soaring
Doug Hoffman
My 1997 Soaring Sailplane Directory shows a T-tailed Club Libelle on
page 59.
Regards,
-Doug
Old February 4th 09, 03:46 PM posted to rec.aviation.soaring
Doug Hoffman
page 59.
Regards,
-Doug
Sorry, incomplete answer.
"The Club Libelle is an outgrowth of the Standard Libelle design. Double
taper wings raised to the shoulder position provide greater clearance on
landouts. Th wings carry broad-span trailing edge flaps for approach
control. The landing gear is fixed and a T-tail replaces the low-set
tailplane of the Standard Libelle. ATC.
L/D max 35 @ 49 kt
min sink 1.84 fps @ 36 kt
no built 171
no in US 3
Old February 4th 09, 04:00 PM posted to rec.aviation.soaring
Mark Wright[_2_]
Thanks
Boggs
www.nwskysports.com
It'll be a 205 Club Libelle, T tail, Fixed u/c, high wing . I think
about 170 were made.
Old February 4th 09, 04:03 PM posted to rec.aviation.soaring
Tim Mara[_2_]
that would be the Club Libelle.....really not close to a Libelle...different
in almost every respect....different tail, fuselage, cocppit, rear hinged
canopy, Hornet wing with trailing edge dive brake....like I said, not close
to a Libelle ..but still a nice glider...we have 2 locally I imported
several years ago..
tim
"GARY BOGGS" wrote in message
Thanks
Boggs
www.nwskysports.com
Old February 4th 09, 07:45 PM posted to rec.aviation.soaring
Tea Nott
Glasflugel 205 Club Libelle - balsa wood core wings
http://www.sailplanedirectory.com/glasflugel.htm
Libelle...different
close
several years ago..
tim
Thanks
Boggs
www.nwskysports.com
Old February 4th 09, 08:35 PM posted to rec.aviation.soaring
Tim Mara[_2_]
absolutely not......205 had all foam cores
tim
Libelle...different
close
several years ago..
tim
Thanks
Boggs
www.nwskysports.com
Old February 4th 09, 09:30 PM posted to rec.aviation.soaring
Tea Nott
true, but only for s/n 140 onwards
http://www.streifly.de/TN205-11e.pdf
tim
Libelle...different
hinged
close
several years ago..
tim
Thanks
Boggs
www.nwskysports.com
Old February 5th 09, 12:26 AM posted to rec.aviation.soaring
Martin Gregorie[_4_]
The last balsa in the Std.Libelle, in the fin and elevator, vanished with
S/N 182 at the end of 1970. Martin Simons says the H.205 was introduced
in 1973 and the first AD is dated 1974, so its chances of containing any
balsa is about zero.
According to Simons the H.205's only vice was a sudden loss of height if
you closed the TE flaps since they added lift and lowered the stalling
speed: not a good thing to do toward the end of finals. I've seen a lot
of Std.Libelles (there are three on our field including my all-balsa
example, S/N 82) but I've never seen an H.205 in the flesh.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old February 4th 09, 10:55 PM posted to rec.aviation.soaring
Andy[_1_]
The new Fork Tailed Doctor Killer Denny Piloting 182 March 24th 08 12:54 AM
Oshkosh 2004-T-Tailed Pusher Aircraft Jesse Zufall Home Built 3 February 13th 05 03:12 PM
For F-5 fans - Iran reveals new F-5 based twin-tailed Azarakhsh fighter TJ Military Aviation 1 July 11th 04 09:40 PM
