Grob 109 wing pins
Old February 7th 09, 02:43 PM posted to rec.aviation.soaring
Bob Jenneson
Default Grob 109 wing pins
Hi,
I am seeking advise on the replacement of the wing pins fitted in the
end of the spars on Grob 109 and 109B.
This also applies to the Grob Twin Astir.
A brief history.
These pins are welded to a plate that is glassed into the wing spar end
during manufacture. It was found out at a later time that some of these
assemblies were prone to cracking around the welds and required replacement
if found to be cracked.
In Australia we are required to "ultrasonic " test these pins every 500
hours ( AD 370 )
If tested 'OK' we keep flying.
We now have two aircraft that have 3000 hours each ( Life extension time )
and no cracks found.
Do we need to change the pins?
This is serious and expensive surgery and I am seeking advise as to how
other countries have dealt with this problem.
I understand that Australia in the only country that uses the ultrasonic
test.
Grob are happy to supply the new pin assemblies, but is it really necessary
if the old ones have a 3000 hour safe history.
Any help appreciated, Bob.
Old February 7th 09, 05:13 PM posted to rec.aviation.soaring
Gilbert Smith
In the UK we replace them on the G109B at 3000 hours irrespective,
together with a few other mods which come up at that time. The new
pins have a better taper, handy if you rig frequently as I do, and are
replaceable without the major surgery reuired on the first occasion.
- Colin.
"Bob Jenneson" wrote:
Hi,
A brief history.
hours ( AD 370 )
test.
Old March 23rd 09, 12:00 AM posted to rec.aviation.soaring
Rod Swallow
Dear Gilbert
I am a Grob 109b owner in Australia. Currently I am trying to assemble a
trolley to make wing folding easier as I want to be able to rig it on my
own. Do you have any suggestions?
Thanking you
Rod Swallow
- Colin.
Hi,
A brief history.
replacement
every
500
hours ( AD 370 )
time
test.
necessary
Old March 25th 09, 01:18 AM posted to rec.aviation.soaring
Gilbert Smith
Hello Rod,
I use a home-spun device which clamps to the wingtip just outboard of
the aileron. I have fitted two small wheels to this so that the wing
can be moved into position while vertical. When rigging you then have
to lift the tip with the device still fitted, go flat, and push it
home. A fold-down prop then supports the tip while I engage the main
and leading edge pins.
It also has an extension of about a foot out from the trailing edge to
help with the aft c of g at the tip. I rig and derig alone every day,
and the device has been in use for 25 years.
My attempt at a trolley and hydraulic jack was a failure because I
lost the "feel" required to locate the spar pin.
If you like I can email photos of both.
Regards,
"Gilbert"
Rod Swallow wrote:
Dear Gilbert
Thanking you
Rod Swallow
- Colin.
Hi,
A brief history.
replacement
every
500
hours ( AD 370 )
time
test.
necessary
Old March 25th 09, 12:59 PM posted to rec.aviation.soaring
On Mar 25, 9:18*am, Gilbert Smith wrote:
Hello Rod,
Regards,
"Gilbert"
Rod Swallow wrote:
Dear Gilbert
Thanking you
Rod Swallow
- Colin.
"Bob Jenneson" *wrote:
Hi,
* *I am seeking advise on the replacement of the wing pins fitted in
A brief history.
replacement
* * In Australia we are required to "ultrasonic " test these pins
every
500
hours ( AD 370 )
time
test.
necessary
Any help appreciated, Bob.- Hide quoted text -
- Show quoted text -
Dear Gilbert
I would really appreciate the photos as it sounds like a much simpler
system than the one I was considering.
Thanking you
Rod Swallow
Old April 11th 09, 11:45 PM posted to rec.aviation.soaring
Robert Hart[_2_]
Gilbert,
I am getting a 109B and would like to get photos of your rigging device.
Did you fabricate it yourself or have it made for you? I have looked at
the trolley and jack system and it seems overly complex and expensive.
Regards, Robert
At 00:18 25 March 2009, Gilbert Smith wrote:
Hello Rod,
Regards,
"Gilbert"
Rod Swallow wrote:
Dear Gilbert
a
my
Thanking you
Rod Swallow
- Colin.
Hi,
A brief history.
end
these
replacement
every
500
hours ( AD 370 )
time
how
ultrasonic
test.
necessary
Grob 109 wing pins BT Soaring 0 February 7th 09 06:05 AM
Grob wing retainer bearings Tim Soaring 3 September 3rd 06 03:55 PM
ASW-15B spar pins [email protected] Soaring 1 May 9th 06 01:46 AM
Hinge pins for Pegasus AD tooromeo Soaring 0 May 17th 05 03:56 PM
taper pins Ernest Christley Home Built 4 September 12th 03 04:15 AM
