OLC issues
Old March 1st 09, 10:16 PM posted to rec.aviation.soaring
Ramy
Default OLC issues
Is it just me or others have the follwoing issues since the 2009
season started:
1 - The result list defaults to the whole month instead of latest day
as it used to be.
2 - Most of the time the google map does not work resulting in an
error message.
I wrote to OLC about it but they claimed it is working for them...
Ramy
Old March 1st 09, 11:02 PM posted to rec.aviation.soaring
Tuno
Default OLC issues
Ramy,
It's working correctly for me, Google maps and all.
~ted/2NO (tipping cap to the OLC team)
Old March 2nd 09, 05:23 AM posted to rec.aviation.soaring
Greg Arnold[_2_]
Default OLC issues
season started:
as it used to be.
error message.
Ramy
I like #1. Just click "All", and you have a list of all flights during
the present season. You can order them by longest, highest points, and
fastest.
Old March 2nd 09, 09:00 PM posted to rec.aviation.soaring
Default OLC issues
On Mar 1, 9:23*pm, Greg Arnold wrote:
season started:
as it used to be.
error message.
Ramy
I like #1. *Just click "All", and *you have a list of all flights during
the present season. *You can order them by longest, highest points, and
fastest.
Regarding #1, it would be good if you could order them by date, but
there is no date column. Since I believe most of us most of the time
go to OLC to check the latest flights, the only way to achive that is
by clicking on the date field first and select the latest date. Two
extra clicks, so not really a big deal.
Rearding #2, I take it that others don't experience it, which is odd
since I see it in 4 computers, running Vista or XP, but all running
IE7, so maybe it is an IE7 problem. It happens 80% of the time.
Ramy
Old March 2nd 09, 09:16 PM posted to rec.aviation.soaring
Default OLC issues
For those who are getting the error message when trying to use google
maps, it might be due to the url. If the url you're using looks like
"www3.onlinecontest.org/...", just remove the "3".
Old March 2nd 09, 09:08 PM posted to rec.aviation.soaring
Default OLC issues
If all you want is the most recent day's logs, copy and try this:
http://www.onlinecontest.org/olc-2.0...oringId=1&last
Raul Boerner
LS6-B
DM
Old March 2nd 09, 09:14 PM posted to rec.aviation.soaring
Default OLC issues
season started:
as it used to be.
error message.
Ramy
If all you want is the most recent day's logs, in the USA, try this:
http://www.onlinecontest.org/olc-2.0...&subco untry=
Raul Boerner
DM LS6-b
Old March 3rd 09, 02:26 AM posted to rec.aviation.soaring
Default OLC issues
season started:
as it used to be.
error message.
Ramy
http://www.onlinecontest.org/olc-2.0....html?scoringI...
Raul Boerner
DM LS6-b
OK, this seems to do the trick. Thanks! Looks like you hacked out the
date from the url. It used to work by just bookmarking the latest day.
But I still occasionly get the browser error when switching to google
map, even though the url is still www.onlinecontest.org...
Ramy
Old March 3rd 09, 06:47 AM posted to rec.aviation.soaring
Default OLC issues
Using www instead of www3 works great for Google Maps. Finally!
Thanks!
Larry
Old March 5th 09, 04:58 AM posted to rec.aviation.soaring
Default OLC issues
season started:
as it used to be.
error message.
Ramy
I had some problems with OLC last year. Turned out that by relaxing
the security setting in my browser the problem went away.
RomeoDelta
OLC Issues Union Thug Soaring 3 July 15th 07 08:14 PM
Baron issues Viperdoc Owning 22 September 7th 06 06:55 PM
Issues around de-ice on a 182 Andrew Gideon Piloting 87 September 27th 05 11:46 PM
Issues around de-ice on a 182 Andrew Gideon Owning 35 July 18th 04 06:42 PM
Maint issues - R22 Rich Rotorcraft 4 July 8th 04 05:18 PM
