Throttle or Prop control first after takeoff
Old March 6th 09, 07:37 PM
cyberflyrg cyberflyrg is offline
Junior Member
First recorded activity by AviationBanter: Feb 2009
Question Throttle or Prop control first after takeoff
We are having a argument about what is better to do after takeoff. Some mechanics say pull power back first after takeoff and then adjust prop speed after, my mechanic says prop speed back first and then manifold pressure after that.
What the "right" thing to do that will not damage the prop governor and motor??? You opinion is greatly appreciated..
PS: this is in reference to my 1965 210.
thanks rg
Old March 6th 09, 08:48 PM posted to rec.aviation.owning
Robert M. Gary
Default Throttle or Prop control first after takeoff
On Mar 6, 11:37*am, cyberflyrg
Refer to your POH when in doubt. However, the rule of thumb most of us
fly under is that when reducing power you work left to right
(throttle, then prop, then mixture). When increasing power you work
the other way (mixture, prop, then throttle). This sequence ensures
you don't lug the engine. If your airframe POH or engine manual says
otherwise, go for it.
-Robert, CFII
Old March 6th 09, 08:52 PM posted to rec.aviation.owning
Mark Hansen
On 03/06/09 12:48, Robert M. Gary wrote:
On Mar 6, 11:37�am, cyberflyrg
-Robert, CFII
Yes but right after take off, don't people reduce the rpm just a bit
(to 2500 in the Archer I flew) to reduce noise?
Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot
Cal Aggie Flying Farmers
Sacramento, CA
Old March 6th 09, 08:55 PM posted to rec.aviation.owning
Robert M. Gary
I don't because I personally don't believe in touching power below
1000 feet. However, a lot of aircraft require a power reduction for
sustained climb or noise. For instance in the C-182T you pull power
and fuel flow back to the top of the green, etc. However, I still
don't touch anything below 1000 feet, even coming out of SMO in my
Mooney (where the noise nazi's live)
-Robert
Old March 6th 09, 10:39 PM posted to rec.aviation.owning
dave
thanks rg
On my bonanza, I keep full throttle then pull back the prop as per the
manual. Keep the throttle in until I reach my enroute altitude.
Dave
Old March 7th 09, 02:31 AM posted to rec.aviation.owning
BT
The Seneca II take off is 40in MP and full RPM for takeoff.
"Stabilized in the climb".. you pick when you think that is time to do that.
Reduce to "Climb Power" 30in MP and 2500RPM.
Cruise Power "as required" normally between 28-30in MP 2300-2400RPM and
about 13gph per side.
Some one already mentioned the take off procedure for the C-182T (Turbo).
Reduce the MP and the Fuel Flow to the Top of the Green.
Arrow, 25square works, MP first then Prop.
The thing about "older" POH, like your 1965 C-210.. they were not that
explict.
Dependent on the engine, some say keep RPM higher than MP, some don't.
"cyberflyrg" wrote in message
thanks rg
cyberflyrg
Old March 7th 09, 05:41 PM posted to rec.aviation.owning
Danny Deger[_2_]
explict.
The POH on my 1941 Taylorcraft doesn't say a thing about when to adjust
the prop :-)
Danny Deger
Old March 8th 09, 09:47 PM posted to rec.aviation.owning
Jay Honeck[_2_]
the prop :-)
Yeah, there's nothing in my '48 Ercoupe's POH (er, "pamphlet") about that,
either. Nuthin' about flaps or rudders, either!
The Pathfinder we always work left-to-right, as someone else stated.
Throttle, prop, mixture.
Jay Honeck
Iowa City, IA
Pathfinder N56993
Ercoupe N94856
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 16th 12, 06:25 AM posted to rec.aviation.owning
dcd
the prop :-)
Danny Deger
I didn't think the 1941 Taylorcraft came with a POH? Do you still have it?
Right prop, wrong prop? Wood prop, metal prop? Gus Rasch Aerobatics 1 February 14th 08 10:18 PM
Head wind takeoff into rising hills, or crosswind takeoff to open space ?? P S Piloting 7 September 20th 07 07:29 PM
Question on Baron 58 prop control Mxsmanic Piloting 62 December 3rd 06 05:26 AM
You Want Control? You Can't Handle Control! -- Was 140 dead ArtKramr Military Aviation 0 March 2nd 04 08:48 PM
Hydraulic CS prop converting to Adjustable prop? Scott VanderVeen Home Built 0 December 5th 03 05:54 PM
