F15E/1941
Old May 31st 04, 12:32 AM
Bob Urz
Default F15E/1941
I know similar scenarios were made into a movie.
But, if on Dec 1941 you had two strike eagles.
Only two. Your sortie arrived at the Japanese fleet
about the time 1/2 of the first wave was launched.
Question 1#
given the choice of any weaponry available for the F15,
(even some that may not be normally used)
what would your weapon load be? This is using all available hard points
and taking fuel out of the equation.
Question #2
Given the choice of weapons above, what would your tactics be to
maximize damage to the carrier fleet and prevent as many planes
as possible from reaching Pearl. (while saving your own butt)
Now there would have to be a balance between destroying the carriers
from future use and destroying the attacking planes that have already
left the carrier. Have it it. Hang as much on the plane as you can.
But when your out of munitions, what other tactics could you use?
Bob
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
Old May 31st 04, 01:00 AM
JDupre5762
Not really sure what the weapons load out of an F-15E can be but I would load
enough air to surface missiles to put two killing shots into every carrier from
a distance that leaves me invulnerable to AAA return fire. If I can still carry
air to air missiles then as many of them as possible.
I would kill every carrier before they can finish launching the first wave
strikes. Then I would go warp 9 till I caught the strike group and start
killing the leaders with Sparrows or Sidewinders. (Assuming the Sidewinder can
pick up a heat signature from an early 20th century recip aircraft.) Then use
my Vulcan 20mm using as short a burst as possible in order to kill as many of
the survivors as possible.
High speed passes with pull ups in full burner that will swat the Japanese
aircraft out of the air. The Isralis used this tactic against helicopters in
1973.
At the same time I am screaming as loudly as possible to the Army and Navy
commands on Oahu that the Japanese are coming.
John Dupre'
Old May 31st 04, 01:04 AM
John Mullen
"JDupre5762" wrote in message
(snip)
Didn't they know that anyway, but could not be bothered getting out of bed?
It was a Sunday after all!
John
Old May 31st 04, 01:31 AM
Keith Willshaw
"Bob Urz" wrote in message
Question 1#
Mk/B61 Nuclear weapons
Question #2
Throw em a coupla buckets o instant sunshine
Keith
Old May 31st 04, 01:37 AM
Scott Ferrin
On Mon, 31 May 2004 01:31:01 +0100, "Keith Willshaw"
Question 1#
Question #2
Keith
You know it. You could carry five at the *least*. Come to think of
it you could probably put a B83 (more bang) on the centerline, one on
each CFT and one under each wing. Five 1-2 MT bombs (ten I guess if
you're using two Eagles) ought to do the trick :-)
Old May 31st 04, 02:36 AM
Kyle Boatright
Question 1#
Question #2
Bob
I carry 4x cluster bombs per aircraft (just in case I miss with one or two),
and all the sidewinders and 20mm the F-15 will haul. I'm hitting the
carriers with cluster bombs, which ought to do a number on any aircraft and
people on deck. The secondaries from the Japanese munitions will finish the
job on the carriers. Once the carriers are lit up like the 4th of July, I
take out bombers and torpedo planes until I exhaust my supply of
sidewinders. Following that, I go plinking with 20 mm. I don't waste my
time shooting up Zero's unless there is nothing else to shoot at.
KB
Old May 31st 04, 03:20 PM
Alan Minyard
Question 1#
Question #2
Bob
KB
AIM 9s at recips?? I doubt if you would ever get a tone.
Al Minyard
Old May 31st 04, 05:01 PM
Peter Stickney
Alan Minyard writes:
Question 1#
Question #2
Bob
KB
They do, and quite nicely. Recip exhaust gas is very hot. Teh
volume's lower, but that doesn't really matter - a Sidewinder's seeker
is looking at temperature, not volume.
Remember - the seekers these days are able to see the aerodynamic
heating on the leading edges of a subsonic airplane - that's not very
much.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
