Nice cheat sheet for the electrically challenged
Old March 20th 09, 03:21 AM posted to rec.aviation.soaring
Tuno
Default Nice cheat sheet for the electrically challenged
I can never keep these rules straight in my head, so I was happy to
find this cheat sheet:
http://www.evparts.com/img/voltsampsohmwatts.PDF
2NO /* software guy */
Old March 20th 09, 03:28 AM posted to rec.aviation.soaring
rlovinggood
Tuno,
I can still remember a little rule from my high school physics
teacher: V = IR (Volts = Amps x Ohms) or VIR as in "Veer" as in the
type of offense our pitiful high school football team ran, The "veer"
offense. Or something like that.
Ray Lovinggood
Carrboro, North Carolina, USA
Old March 20th 09, 07:51 AM posted to rec.aviation.soaring
Alan[_6_]
In article Tuno writes:
Caution, the section for watts is only correct for DC or purely resistive
loads. For AC, it falls short if you are using something more complex than
an incandescent light bulb.
The 3 phase comment at the bottom assumes you are measuring the voltages
phase to phase, and that the load is purely resistive, and equally
distributed along the phases, which is probably an unusual condition.
Alan
Old March 20th 09, 11:34 AM posted to rec.aviation.soaring
The Real Doctor
There is one obvious typo: adding watts and ohms is meaningless (top
left).
And why the hell use E for volts? Not only would V be clearer, E is
also used as electric field strength (V/m)
Ian
Old March 20th 09, 03:40 PM posted to rec.aviation.soaring
"The Real Doctor" wrote in message
....Snip...
Ian
Maybe it was because E is what is used in his old Physics, and elementary
Electrical Engineering text books. (It is also the character use in FCC
Amateur Examinations.)
Amateur Radio W7ADK
HP-14 "6F"
http://www.soaridaho.com/
Old March 20th 09, 05:09 PM posted to rec.aviation.soaring
bumper
"Wayne Paul" wrote in message
m...
...Snip...
Ian
Amateur Radio W7ADK
HP-14 "6F"
When I went through the US Navy's "Electronics Technician Class-A" school .
.. . lessee, that was 46 years ago (!!!), they told us the "E" was for
Electromotive Force.
bumper
Minden
zz
QV and MKIII
Old March 20th 09, 05:21 PM posted to rec.aviation.soaring
"bumper" wrote in message
m...
...Snip...
Ian
Amateur Radio W7ADK
HP-14 "6F"
. . . lessee, that was 46 years ago (!!!), they told us the "E" was for
bumper
Other sources a
http://www.the12volt.com/ohm/ohmslaw.asp
http://www.allaboutcircuits.com/vol_1/chpt_2/1.html
http://www.angelfire.com/pa/baconbacon/page2.html
http://www.youtube.com/watch?v=_-jX3dezzMg
Old March 21st 09, 12:05 AM posted to rec.aviation.soaring
Ed Winchester[_2_]
Bumper,
Did you go to TI or Lakes? I was a year behind you at TI. Retired in 84.
Ed
m...
...Snip...
Ian
Amateur Radio W7ADK
HP-14 "6F"
bumper
Minden
zz
QV and MKIII
Old March 21st 09, 07:46 AM posted to rec.aviation.soaring
bumper
"Ed Winchester" wrote in message
Bumper,
84.
Ed
Ed,
To keep it somewhat "on thread", I'll throw in the now very non-PC method
they taught us for remembering the resistor color codes:
Black-0 Brown-1 Red-2 Orange-3 Yellow-4 Green-5 Blue-6 Violet-7 Gray-8
White-9
Bad Boys Ra_e Our Young Girls But Violet Gives Willingly
Treasure Island.
Joined in March '63 - out in late '70 and then PD for 10 years. Started
alarm company (sort of combining electronics and law enforcement), invented
some tools for running wires etc.
There's less money in inventing toys for gliders - - but it's more fun.
bumper
ASH26E
Minden, NV
Quiet Vent ($6) and MKIII high tech yaw string ($10)
Old March 20th 09, 06:08 PM posted to rec.aviation.soaring
The Real Doctor
On 20 Mar, 14:40, "Wayne Paul" wrote:
"The Real Doctor" wrote in ...
Ah. Fair enough, in the latter case particularly. I've never seen E
used in that way myself, but if it's out there ...
Ian
Any vision challenged pilots that can give some advice? Kirk Ellis Piloting 22 March 18th 08 01:55 AM
OSH Homerun? Glass Cockpit for the Budget-Challenged Marco Leon Piloting 4 July 28th 07 12:27 AM
FAA Mandatory Pilot Retirement Rule Challenged Larry Dighera Piloting 0 March 20th 05 09:56 PM
METAR cheat sheet M.E. Borner Instrument Flight Rules 11 February 10th 05 08:04 PM
Cuts to Stealth Force Challenged Henry J Cobb Military Aviation 0 March 6th 04 04:22 PM
