LAS approaches
Old March 24th 09, 12:54 AM posted to rec.aviation.ifr
Ron Garret
Default LAS approaches
Some questions about flying to LAS:
1. The RNAV RWY 1R (http://naco.faa.gov/d-tpp/0903/00662R1R.PDF) has
two IAFs: BOACH and SKEBR. I can find BOACH on the enroute chart (on
V21 between WHIGG and CRESO) but not SKEBR. Where is it?
2. Same question for KACCY intersection, which is the IAF for the
VOR/DME-A (http://naco.faa.gov/d-tpp/0903/00662VDA.PDF)
3. The route I get from DUATS low-altitude auto-routing (from VNY) ends
at OASYS (on V394), which does not appear to be the IAF for any
approach. Am I missing something? Is DUATS broken? If I were cleared
"as filed" and lost comm, which should I do when I got to OASYS?
Thanks,
rg
Old March 24th 09, 06:53 AM posted to rec.aviation.ifr
A Guy Called Tyketto
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
SKEBR should be defined as the LAS R-211, 28DME. It's a little
bit northeast of CLARR.
http://www.airnav.com/airspace/fix/skebr
KACCY? LAS R-180, 16.5DME, and/or BLD R-224, 21DME.
http://www.airnav.com/airspace/fix/kaccy
ugh.. You'll want to avoid anything near OASYS (in fact, ATC
will keep you away from it) as you'll come into conflict with the
BOACH2, MCCRN3, and SHEAD5 departures out of KLAS.
Two things. If you're looking at flying into KLAS, if you're a
prop or slow and go, consider filing the CRESO3 arrival. They've kept
that one around for the slower planes so they can be kept out of the
main CLARR/KEPEC arrival stream. This would put you pretty much in line
with V21 all the way to BLD.
Secondly, this is all under normal configuration at KLAS
(normal being landing/departing runways 19L/R and 25L/R). Currently
25L/7R is closed for reconstruction (as been since October and will be
until May) so current calm wind config is landing 25R and 1L, departing
1R. From the south, you'll more than likely be given something low to
cross underneath the SoCal departures at BOACH, then turned directly
towards LAS. Clear skies prevail for the most, so visuals will be in
order.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (GNU/Linux)
iD8DBQFJyINhyBkZmuMZ8L8RAk+pAKD7V4RJ2Bom65y6bjEd+/RKehczBgCg0WhX
1kWWGONqm3+a6p+VrV3OVyg=
=syiW
-----END PGP SIGNATURE-----
Old March 24th 09, 04:19 PM posted to rec.aviation.ifr
Ron Garret
Hash: SHA1
I guess I should have phrased the question a little differently. I know
where these waypoints are (obviously they're on the approach plate).
What I want to know is how do you get to them if they're not shown on
the enroute chart? (I'm talking theory here. I know that in practice
you just get vectored around, and it's visual approaches 99.9% of the
time.)
Conversely, what do you do if your DUATS-recommended flight plan
terminates at a waypoint that is not the IAF for any approach and you
lose comm?
rg
Old March 24th 09, 05:49 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
know where these waypoints are (obviously they're on the approach
plate). What I want to know is how do you get to them if they're not
shown on the enroute chart? (I'm talking theory here. I know that
in practice you just get vectored around, and it's visual approaches
99.9% of the time.)
SKEBR is connected to the enroute environment through the CLARR2 arrival,
KACCY is connected via the feeder route from BLD VORTAC.
lose comm?
Whatever you feel is in your own best interest.
Old March 24th 09, 04:06 PM posted to rec.aviation.ifr
Sam Spade
Thanks,
rg
Did you check the STARS for LAS?
Old March 24th 09, 04:13 PM posted to rec.aviation.ifr
Ron Garret
Thanks,
rg
Yep. Couldn't find them there either. But I didn't do an exhaustive
search.
rg
Old March 24th 09, 05:07 PM posted to rec.aviation.ifr
Sam Spade
Thanks,
rg
search.
rg
SKEBR is on the CLARR2 STAR. And, although it is not part of V-394,
SKEBR lies directly on V-394.
Old March 27th 09, 02:27 AM posted to rec.aviation.ifr
Ron Garret
Thanks,
rg
search.
rg
Just returned from an uneventful (and CAVU, albeit a bit bumpy) trip to
LAS. Thanks for all the responses!
rg
Old March 27th 09, 02:31 PM posted to rec.aviation.ifr
Sam Spade
Thanks,
rg
search.
rg
rg
Not much fun when the Santa Anas are at play. Where are you based?
Old March 24th 09, 05:43 PM posted to rec.aviation.ifr
SKEBR is on the LAS R-211 at 28 DME, you'll find it on the CLARR TWO STAR:
http://naco.faa.gov/d-tpp/0903/00662CLARR.PDF
KACCY is on the LAS R-180 at 16.5 DME. I can't find it on any enroute chart
or STAR, but it does have a feeder route from BLD VORTAC.
ends at OASYS (on V394), which does not appear to be the IAF for any
cleared "as filed" and lost comm, which should I do when I got to
OASYS?
You mean if you suffer some bizarre failure in IMC that prevents you from
receiving on any comm radio but leaves your other avionics unaffected? You
should get your airplane on the ground before it does spread and you lose
your ability to navigate. Pick an approach that you feel is most
advantageous to you, broadcast your intentions in the event that your
transmitter is still functioning, squawk 7600 briefly to let ATC know you
can't hear them (they probably know already), squawk 7700 briefly to let
them know you consider it an emergency, then return to your original code
for better tracking and to silence any annoying alarms. Fly your approach
and land.
crazy approaches buttman Instrument Flight Rules 18 November 2nd 06 12:02 AM
Is an IPC a substitute for 6 approaches? Ben Jackson Instrument Flight Rules 105 September 2nd 06 12:38 AM
My First GPS Approaches john smith Instrument Flight Rules 10 November 9th 04 09:14 PM
ILS PRM approaches Riddler Instrument Flight Rules 2 October 28th 04 12:37 PM
Logging approaches Ron Garrison Instrument Flight Rules 109 March 2nd 04 05:54 PM
