Power connector for Garmin 400/420/430
Old March 30th 09, 09:50 PM posted to rec.aviation.homebuilt,rec.aviation.owning
rmhou at yahoo.com
Default Power connector for Garmin 400/420/430
I want to build a power cable so I can practice using my Garmin GNC
420W at home. I called Garmin and was told that I can order their
$125 connector kit to build my cable.
The GPS side uses a 78-pin connector that looks like a D-subminiature
78-pin connector. Mouser has them for around $10. But Garmin tech
told me that their connectors are not "computer connector" but
"aviation connector"; at $125, it sure feel like aviation grade and
price.
Would this work: http://www.mouser.com/Search/Product...QH3iWQ %3d%3d
Thanks in advance.
Robin Hou
Old March 31st 09, 06:28 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Marco L
"rmhou at yahoo.com" wrote in message
price.
Would this work:
Have you tried these two other options?
1. You can use Garmin's simulator available for free. It is the same
software as the real thing and you can choose from different 400-series
flavors
2. Buy Reality-XP's 400W add-on to MS Flight Simulator for $40.
Marco
Old April 7th 09, 06:21 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Bill
420W at home. *I called Garmin and was told that I can order their
78-pin connector. *Mouser has them for around $10. *But Garmin tech
price.
Would this work:http://www.mouser.com/Search/Product...fj%252b8r7ekpZ...
Thanks in advance.
Robin Hou
Robin, The connector isn't anything real special. The one on the
COM does have some special
high current pins.
The commentators are correct. The sim will do everything but VOR-LOC
simulation. You would
have to hook up a lot of stuff to make the box do it!! Maybe a whole
airplane.
Bill Hale
Garmin 396 24-volt power? Dan[_1_] Piloting 6 September 30th 10 01:42 PM
Garmin 396 496 Data Connector Wiring Standard mikem Owning 3 October 25th 06 04:40 AM
Garmin 396 496 Data Connector Wiring Standard mikem Home Built 3 October 25th 06 04:40 AM
WTB: Power or cigarette lighter cable for Garmin GPS195 Larry Rachman Aviation Marketplace 1 December 22nd 04 08:47 PM
