HP310 portrait driver issue
Old April 2nd 09, 02:15 AM posted to rec.aviation.soaring
sisu1a
Default HP310 portrait driver issue
I'm having difficulty getting the portrait driver to correctly work on
my 310. I've followed the installation and uninstallation directions
as carefully as possible, but continue to get only half a screen in
protrait after the install.
I've tried to join the Naviter forum to clear this up there, but have
not had my confirmation email or any response to going through the
"so you haven't gotten your confirmation email" process either, so
I'm reduced to ras. Any help is appreciated, as this thing is clearly
way smarter than I am...
-Paul
Old April 2nd 09, 05:06 AM posted to rec.aviation.soaring
"so you haven't gotten your confirmation email" *process either, so
-Paul
Have you considered just running it in landscape mode? The difference
in device width is less than an inch. Not to mention being free of the
troublesome portrait driver.
Old April 2nd 09, 05:09 AM posted to rec.aviation.soaring
-Paul
Here's a short thread on the issue you're having :
http://www.naviter.si/component/opti...8/topic,3366.0
No need to sign up. You can read all the forum threads as a guest.
Old April 2nd 09, 09:36 AM posted to rec.aviation.soaring
-Paul
Hi Paul
I am running Henryk Birecki's GPS_LOG on an i310 with the screen
rotation driver from Klaus-Peter Renner.
This driver can rotate 90deg or 270deg.
I use 270deg to have the wiring and thumbwheel on top.
The screen rotation driver just runs under WinCE, so I guess it could
work with other applications too.
You can contact me outside this forum or check out the GPS_LOG Yahoo
group.
You can find my email address in the WestWind.(don't use this gmail
addres)
It works pretty well.
Hans Van Weersch
3U
XC-Soar and HP310 / HP314 (Euro) Jim White[_3_] Soaring 12 January 31st 09 05:54 AM
mSeeYou and HP310 (USA) Tuno Soaring 4 January 21st 09 03:07 AM
HP310 and XCSoar Jim White[_3_] Soaring 2 January 14th 09 07:15 PM
[07/10] - 10 Ubiquitous Self Portrait.JPG (1/1) Part 7 - last Waldo.Pepper[_2_] Aviation Photos 0 September 16th 08 04:29 AM
Alan B Shepard Jr portrait S63-02082.jpg [email protected] Aviation Photos 0 April 7th 07 11:07 PM
