Any Ballistic Recovery Chute Users?
Old April 4th 09, 01:14 AM posted to rec.aviation.soaring
Ian
Default Any Ballistic Recovery Chute Users?
I would be very interested, for professional reasons, to hear from
anyone who has used a ballistic recovery chute in a glider.
Ian
Old April 4th 09, 02:00 AM posted to rec.aviation.soaring
Gregg Ballou
from
Ian
Only one I've heard of was the sparrowhawk that broke during
highspeed flight testing. I believe the ballistic chute
attachments failed and the pilot used a regular parachute.
Story was in Soaring sometime in the last couple of years.
Old April 4th 09, 02:23 AM posted to rec.aviation.soaring
Uncle Fuzzy
On Apr 3, 6:00*pm, Gregg Ballou wrote:
At 00:14 04 April 2009, Ian wrote:I would be very interested, for professional reasons, to hear
from
Ian
highspeed flight testing. * I believe the ballistic chute
attachments failed and the pilot used a regular parachute. *
August '08 article in Soaring magazine "Lord, if You're Up There" was
written about that incident. Also read
http://newsgroups.derkeiler.com/Arch.../msg00364.html
Old April 4th 09, 06:08 PM posted to rec.aviation.soaring
Mark Jardini
Apis Bee is sold with ballistic recovery as standard equipment. It has
a lower powered engine for German regulations than the Apis M. It is
available as an option on the M model. I have not heard of it being
used. I have not seen reference to the testing either....
Mark
Apis M 821AC
Old April 5th 09, 01:18 AM posted to rec.aviation.soaring
ventus2[_2_]
You may want to also contact Hanko Streifeneder who fitted the ballistic
chute to the Discus for purposes of testing and certification.
http://www.streifly.de/gesamtrettungssystem-e.htm
or their home page
http://www.streifly.de/home-e.htm
Old April 5th 09, 10:58 PM posted to rec.aviation.soaring
Jim Logajan
By "used" do you mean has one installed in their glider, or had to deploy
one due to an inflight emergency? I'm assuming the latter.
Old April 6th 09, 03:57 AM posted to rec.aviation.soaring
Mike Bamberg
There has been at least one installed in an HP-16:
http://www.soaridaho.com/Schreder/HP...S_in_HP-16.htm
Old April 6th 09, 04:27 AM posted to rec.aviation.soaring
Jim Logajan
deploy one due to an inflight emergency? I'm assuming the latter.
BRS, the most well known U.S. vendor of such chutes, keeps a list of "lives
saved" he
http://brsparachutes.com/files/Docum...ives-Saved.pdf
I see some hang gliders listed where BRS chutes were deployed, but I didn't
see any conventional gliders listed (but I'm not that familiar with model
names, so may have overlooked them.) My own search of the U.S. NTSB
database yielded two accidents where the aircraft had ballistic chutes
that proved of no value due to circumstances of the accidents - accident
IDs SEA04FA111 and DFW07LA006:
http://www.ntsb.gov/ntsb/brief.asp?e...25X00871&key=1
http://www.ntsb.gov/ntsb/brief.asp?e...30X01573&key=1
(The latter accident has already been mentioned.)
If one includes motorgliders, then all the Pipistrel and Lambada
motorgliders have ballistic chutes available either as standard equipment
or options, depending on the model:
http://www.mcp.com.au/pipistrel-usa/
http://www.urbanairusa.com/
Old April 6th 09, 06:23 PM posted to rec.aviation.soaring
Darryl Ramm
saved" he
database yielded two accidents *where the aircraft had ballistic chutes
http://www.mcp.com.au/pipistrel-usa/...banairusa.com/
I suspect there are several more. Examples include -
Failure to activate BRS in a spin...
http://www.ntsb.gov/ntsb/brief.asp?ev_id=20020502X00613
BRS failure due to activation at excessive speed (likely loss of
control due to icing in IMC).
http://www.ntsb.gov/ntsb/brief.asp?ev_id=20050222X00211
http://www.flyingmag.com/accidents/7...onditions.html
(This accident is pretty horrible and the whole issue of flight into
know icing, the capability of the TKS system in the Cirrus etc. got
widely discussed because of this. In hindsight the (lack of) icing
forecast provided to the pilot was just awful).
I think BRS systems are pretty impressive and the goal here should be
to understand the capabilities of a BRS system, and the need to be
willing to use it under appropriate situations. So please also focus
on the lives saved/success stories.
And I also hope people read the Windward Owl in-flight failure and
what that glider had been through in the test program as an
endorsement of the capability of that impressive Sparrowhawk glider on
which the Owl is based, when pushed well beyond its design limits.
Darryl
Old April 6th 09, 10:29 PM posted to rec.aviation.soaring
The Real Doctor
That is very much the intention of the work for which I am interested
in this. I'm sorry to be opaque, but will happily explain just what's
going on to anyone who cares to email and ask!
Ian
All Cessna Piston Singles to be Offered With Ballistic Recovery Parachutes Larry Dighera Piloting 8 October 12th 07 05:01 AM
Ballistic Rocket Chute FS Victor Bravo Home Built 12 April 25th 06 01:40 AM
Ballistic parachutes - RVs Ric Home Built 3 September 19th 04 04:09 AM
Ballistic parachutes with pushers anonymous coward Home Built 18 May 18th 04 11:28 PM
Ballistic chute saves 4 souls Bob Babcock Home Built 28 April 27th 04 09:29 PM
