Backlit panel
Old April 9th 09, 11:44 PM posted to rec.aviation.homebuilt
cavelamb[_2_]
Default Backlit panel
I remember Linda Rice's Lockheed had a really cool backlit panel overlay.
The panel itself was heavy aluminum sheet, but then they added a plastic
overlay that had an opaque cover. Legends and labeling was done by
engraving the opaque layer.
On the back side of the there were little cavities carved for grain of rice
(well duh!) light bulbs.
The effect was quite stunning.
So does anybody know where to find this kind of plastic for the overlay?
Thanks,
Richard
Old April 9th 09, 11:59 PM posted to rec.aviation.homebuilt
Dan[_12_]
rice (well duh!) light bulbs.
Thanks,
Richard
I use white plexiglass. Paint the face and edges black and have it
engraved or engrave it then use a roller to paint the face and sides.
Dan, U.S. Air Force, retired
Old April 10th 09, 03:06 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Thanks,
Richard
Ok, so other than good intentions and great karma, what kept the paint
out of the lettering?
Old April 10th 09, 03:43 AM posted to rec.aviation.homebuilt
Dan[_12_]
cavelamb wrote:
Dan wrote:
overlay.
of rice (well duh!) light bulbs.
Thanks,
Richard
If you paint it before engraving you won't have that problem. Using a
roller to paint after you engrave means very little, if any paint gets
into the lettering. I used a rubber roller like engravers use. I prefer
the paint first method, but sometimes you need to repaint after adding
engraving or damaged paint.
I might mention painting the back of the plastic prevents light leaks.
For the truly patient/crazy you can route grooves in the back for
wiring. The number of lights required depends on the size of the panel
and embedded wiring means you only have 2 wires hanging out the back.
Military/commercial lighted panels have a little coaxial connector on
the back that presses into a socket when you mount the panel. If you
ever see one of this type of panel you'll notice a little plus sign on
the front. The connector is directly behind it. Should lighting fail you
can press there to see if the connection is bad. Older panels had light
assemblies that screwed through the panel from the front.
Old April 10th 09, 04:08 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
Dan wrote:
cavelamb wrote:
Dan wrote:
overlay.
plastic
overlay?
Thanks,
Richard
Thanks, Dan.
That's a possibility.
Old April 10th 09, 04:43 AM posted to rec.aviation.homebuilt
Dan[_12_]
cavelamb wrote:
Dan wrote:
cavelamb wrote:
Dan wrote:
overlay.
plastic
overlay?
Thanks,
Richard
it engraved or engrave it then use a roller to paint the face and
sides.
a roller to paint after you engrave means very little, if any paint
gets into the lettering. I used a rubber roller like engravers use. I
prefer the paint first method, but sometimes you need to repaint after
adding engraving or damaged paint.
on the back that presses into a socket when you mount the panel. If
you ever see one of this type of panel you'll notice a little plus
sign on the front. The connector is directly behind it. Should
lighting fail you can press there to see if the connection is bad.
Older panels had light assemblies that screwed through the panel from
the front.
Thanks, Dan.
The comm shops in USAF units was authorized an engraver for intercom
boxes face plates since the boxes had a bunch of pull-on volume controls
and had to be re-labeled for the specific location on the aircraft or
specific aircraft. Guess what? They just swapped out face plates when
replacing the boxes.
Another option you might try is the black on white plastic
trophy/engraving shops use for name plates. Granted it's thinner than
the plates we used which were 3/8" thick or so. I suppose an annunciator
light or illuminated tail number plate can be made if you make a bezel
to hold it with the lamps behind.
You might also consider LED instead of incandescent.
Old April 10th 09, 04:35 AM posted to rec.aviation.homebuilt
Orval Fairbairn[_2_]
Thanks,
Richard
If you wish to be more up-to-date, use red LEDs instead of the
grain-of-wheat bulbs. You CAN use clear plexiglass, with an inverted
bevel at the instrument holes. I would suggest painting both sides of
the plexiglass white, to contain the light, before the cutting/engraving
operations. The front face can be left whit or painted in your desired
color.
Remove _'s from email address to talk to me.
Old April 10th 09, 05:39 AM posted to rec.aviation.homebuilt
Dan[_12_]
Thanks,
Richard
color.
White plexiglass diffuses and spreads the light more evenly than
clear. One nice thing about LED illumination is you can install both
red and white LED so you can either make illumination switchable or you
can change you mind later with minimum wiring problems.
For the truly creative use blue-green LED so you can play special ops
with NVG.
Old April 10th 09, 07:24 AM posted to rec.aviation.homebuilt
cavelamb[_2_]
overlay.
Thanks,
Richard
cutting/engraving operations. The front face can be left whit or
painted in your desired color.
with NVG.
Kool! LOL.
But the red/white back-light idea already crossed my mind.
I hadn't thought of the special ops angle tho.
I like the bevels suggestion too.
There are a couple of places that that might work real well.
This is actually the electrical control panel on my sailboat,
so weight is not quite as critical.
But being able to read it at night IS.
Richard
Old April 10th 09, 07:47 AM posted to rec.aviation.homebuilt
Dan[_12_]
cavelamb wrote:
overlay.
plastic
overlay?
Thanks,
Richard
you can change you mind later with minimum wiring problems.
ops with NVG.
Kool! LOL.
I spent 14 years in special ops. When everything started going NVG
compatible things got strange. Interiors were painted flat black and
lighting included blue-green flood lamps, C-4 lights and stuff like that
there.
Some of the assorted lamps in earlier tests were so bright in NVG
the area around them would be washed out and unreadable.
As for flat black interiors let me tell you sitting in the sun in
Florida things got HOT.
20B Panel jcarlyle Soaring 21 April 1st 09 11:57 PM
Panel Planner [email protected] Home Built 6 March 8th 06 12:48 AM
IFR PANEL Flyhighdave Home Built 4 January 18th 05 05:24 AM
IFR PANEL Flyhighdave Home Built 4 January 17th 05 08:15 PM
182 panel Jim Owning 2 August 2nd 03 10:06 PM
