Q: can a Continental A65-8
Old April 16th 09, 03:22 PM posted to rec.aviation.homebuilt
oilsardine[_2_]
Default Q: can a Continental A65-8
be tuned to make 100 HP?
Old April 16th 09, 04:25 PM posted to rec.aviation.homebuilt
[email protected][_2_]
Probably. But finding a prop to spin at 4500 RPM might be a
problem :-)
Leon McAtee
Old April 16th 09, 09:50 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Default can a Continental A65-8
"oilsardine" wrote in message
Stick a supercharger on it with fuel injection, and then a bigger oil pump
and oil cooler to get rid of the exxtra heat, and no problem.
How long it will last is another story. If you set it to not boost too
high, it might last a thousand hours.
Jim in NC
Old April 16th 09, 10:54 PM posted to rec.aviation.homebuilt
On Apr 16, 2:50*pm, "Morgans" wrote:
How long it will last is another story. *If you set it to not boost too
I doubt it. They're an 1800-hour engine that almost always need top
overhauls well before then, sometimes before mid-time. Boosting it
would overstress already-weak valves and it wouldn't go too far at
all. And with the traditionally low oil pressure these things have,
the bottom ends wouldn't last too long either. The crank was not
nitrided and wears rather rapidly anyway.
The same basic engine was boosted to 75 hp (A-75) using a
higher redline and heavier piston pins and a slightly larger carb
venturi and main jet. They got 80 hp (A-80) by raising the compression
to 7.55:1 from 6.5 as well as the higher redline and bigger carb. And
that's about as much as they dared get from 140 cubic inches with the
engine being as light as it is.
Dan
Old April 17th 09, 10:13 AM posted to rec.aviation.homebuilt
oilsardine[_2_]
hmmm....
thought to replace my Revmaster with this Conti, but now, mybe I better stay
with the VDub?
schrieb im Newsbeitrag
Dan
Old April 17th 09, 02:57 PM posted to rec.aviation.homebuilt
On Apr 17, 3:13*am, "oilsardine" wrote:
hmmm....
with the VDub?
Now you have me confused. If you are thinking that you need to up the
hp of the Cont to match the performance of the Revmaster you've been
drinking someones Kool-aid....................by the pool full :-)
Seriously, more info would help. What is you goal? What kind of
plane? If your plane can handle the extra weight, required prop
length and the C 65 is a good buy you might be better off with the C
65. If your flying something like a KR originally designed around a
VW your probably going to be better off letting the C 65 rest. Is
your Reve giving you problems or less than expected performance?
There are other options to consider. Subaru n 'Vair pop to mind.
Leon McAtee
Old April 17th 09, 03:41 PM posted to rec.aviation.homebuilt
oilsardine[_2_]
..... Seriously, more info would help. What is you goal? What kind of
plane?
I have a Revmaster (normal aspirated) in an slightly :-) overweight Sonex.
The plane hasn't flown yet. Some extra HP could help. The Conti would fit
weight-wise, but seems also underpowered for this application. The Conti
turns slower than the Revmaster, but my prop diameter is limited by ground
clearance...
Old April 17th 09, 02:43 PM posted to rec.aviation.homebuilt
jl
On Apr 16, 5:54*pm, wrote: question about
a-65-8.
The 80-hp version is cranky because the pistons are so heavy. And
there's an AD on the wrist pins because they break, and the rods will
break too. The only way to go 80 is with bootleg pistons and a few
other mods. There's a Cub in SC with Chevy pistons. It makes more
power than a C-85 Cub, or at least climbs out faster. You can't get a
Cub to cruise faster because it is so aerodynamically dirty.
Stay with an A-65-8. It is great reliable power and will last a long
time if you fly it regularly. Jugs will last a max of 500-700 hours.
Continental 757 18R @ MCO Glen in Orlando Aviation Photos 4 November 30th 06 03:15 AM
Continental O-200 ? Stealth Pilot Home Built 48 September 23rd 06 06:32 PM
continental 4 banger Philippe Vessaire Home Built 2 May 19th 06 04:27 AM
Continental 0-200 Robert Home Built 0 August 31st 05 11:57 AM
Continental 0-200 Robert Home Built 0 April 3rd 04 03:08 AM
