Here's a model report on treating home-builders like grownups.
Highlights: Mass balancing controls - tight control wires not enough Reduced stick force per G at higher G made worse by aft CofG Don't push the stick hard by mistake - it may be your last. http://www.ntsb.gov/recs/letters/2009/A09_30_37.pdf Brian W |
On Apr 19, 5:49*am, Brian Whatcott wrote:
Here's a model report on treating home-builders like grownups. Highlights: -------------------------------------------------------------------------- For anyone unfamiliar with bureaucratic formats, skipping to the last page of the 12 page report, will give you a complete list of the highlights. But the real message is more subtle than it appears. The real message offers a polite Heads-Up to ALL American airmen, telling us that if we can't keep our house in order there are plenty of bureaucrats more than eager to jump in and take care of that little matter for us. (Need I mention that bureaucrats don't come cheap?) I STRONGLY suggest you read the whole report and be prepared to act on it accordingly, when appropriate. -R.S.Hoover |
![]() "Bob Hoover" wrote For anyone unfamiliar with bureaucratic formats, skipping to the last page of the 12 page report, will give you a complete list of the highlights. But the real message is more subtle than it appears. The real message offers a polite Heads-Up to ALL American airmen, telling us that if we can't keep our house in order there are plenty of bureaucrats more than eager to jump in and take care of that little matter for us. (Need I mention that bureaucrats don't come cheap?) I STRONGLY suggest you read the whole report and be prepared to act on it accordingly, when appropriate. -R.S.Hoover ***********************************************8 Zactly. Even better, I can't imagine flying a plane that might come apart in mid air (for no apparent reason) without fixing the problem causing it to come apart. Perhaps people should consider that fact, too. Does anyone know why there is no mass ballancing (as is common practice) on the ailerons, in the first place? -- Jim in NC |
On Apr 19, 3:15*pm, "Morgans" wrote:
Does anyone know why there is no mass ballancing (as is common practice) on the ailerons, in the first place? Mass balancing of ailerons may be common, but it is far from universal. The majority of the Aeroncas and T-carts and high-wing Pipers that are such a large part of the GA fleet do not have aileron mass balancing. Since mass balancing will often triple the mass of the surface to which it is applied, it can have a serious effect on performance and useful load. Furthermore, even many fast (200 mph or so) airplanes that do have mass-balanced ailerons are not 100% mass balanced. This category includes Vans RV-series airplanes. Thanks, Bob K. |
Bob Kuykendall wrote:
On Apr 19, 3:15 pm, "Morgans" wrote: Does anyone know why there is no mass balancing (as is common practice) on the ailerons, in the first place? Mass balancing of ailerons may be common, but it is far from universal. The majority of the Aeroncas and T-carts and high-wing Pipers that are such a large part of the GA fleet do not have aileron mass balancing. Since mass balancing will often triple the mass of the surface to which it is applied, it can have a serious effect on performance and useful load. Furthermore, even many fast (200 mph or so) airplanes that do have mass-balanced ailerons are not 100% mass balanced. This category includes Vans RV-series airplanes. Thanks, Bob K. Fair comments.... some aircraft use fractional balancing - in the 1/2 to 2/3 region as a weight-saving measure. A hinge line aft of the aileron leading edge is another tactic. Brian W |
Bob Kuykendall wrote: On Apr 19, 3:15 pm, "Morgans" wrote: Does anyone know why there is no mass balancing (as is common practice) on the ailerons, in the first place? Mass balancing of ailerons may be common, but it is far from universal. The majority of the Aeroncas and T-carts and high-wing Pipers that are such a large part of the GA fleet do not have aileron mass balancing. Since mass balancing will often triple the mass of the surface to which it is applied, it can have a serious effect on performance and useful load. Furthermore, even many fast (200 mph or so) airplanes that do have mass-balanced ailerons are not 100% mass balanced. This category includes Vans RV-series airplanes. Thanks, Bob K. Fair comments.... some aircraft use fractional balancing - in the 1/2 to 2/3 region as a weight-saving measure. A hinge line aft of the aileron leading edge is another tactic. Brian W Below 120 knots or so, the excitation frequency from airflow is probably too low to get too excited about (if you were an aileron, anyway). Above that, things get closer to the fundamental excitation frequency of the structure. Richard |
Morgans wrote:
"Bob Hoover" wrote For anyone unfamiliar with bureaucratic formats, skipping to the last page of the 12 page report, will give you a complete list of the highlights. But the real message is more subtle than it appears. The real message offers a polite Heads-Up to ALL American airmen, telling us that if we can't keep our house in order there are plenty of bureaucrats more than eager to jump in and take care of that little matter for us. (Need I mention that bureaucrats don't come cheap?) I STRONGLY suggest you read the whole report and be prepared to act on it accordingly, when appropriate. -R.S.Hoover ***********************************************8 Zactly. Even better, I can't imagine flying a plane that might come apart in mid air (for no apparent reason) without fixing the problem causing it to come apart. Perhaps people should consider that fact, too. Does anyone know why there is no mass ballancing (as is common practice) on the ailerons, in the first place? The Zenair Zodiac uses wing warping. (They call it a "hingeless aileron"). Looks pretty springy to me. http://www.zenithair.com/kit-data/ht-aileron.html John Kimmel |
John Kimmel wrote:
The Zenair Zodiac uses wing warping. (They call it a "hingeless aileron"). Not all of them. Zenair has offered a piano-hinged aileron for quite a while...the SLSA version of the CH601 uses 'em, and some kit builders have opted for them. Two of the wing-failure accidents involved SLSA Zenairs, which have the piano hinges. Haven't heard the type of ailerons for the others. Ron Wanttaja |
Ron Wanttaja wrote:
John Kimmel wrote: The Zenair Zodiac uses wing warping. (They call it a "hingeless aileron"). Not all of them. Zenair has offered a piano-hinged aileron for quite a while...the SLSA version of the CH601 uses 'em, and some kit builders have opted for them. Two of the wing-failure accidents involved SLSA Zenairs, which have the piano hinges. Haven't heard the type of ailerons for the others. Ron Wanttaja As best we can find out NONE of the accident aircraft had the hingeless ailerons. This could explain why there has been no problems until the last few years when the hinges started replacing the hingeless. In fact the only commonality that I can find between the accident aircraft is hinged ailerons and the sort of strange (for an plane that the majority of the fleet is EXP-HB) fact that none of the aircraft were flown by the builder. |
Here's a model report on treating home-builders like grownups. I sure hope you're being facetious, since it asks that even experimental aircraft be grounded, even though it contradictorily also states some aircraft built from that design have already made design changes that make the cited concerns mute. The report also references material from the Matronics Zenith e-mail list and uses it as supporting circumstantial evidence (the core argument is an entirely circumstantial one of course.) Considering the total lack of authentication of such e-mail material, it's a bit irresponsible to build an already questionable circumstantial case on unauthenticated claims. Also, I've browsed that list and the hysteria and infighting concerning this issue in that e-mail list almost puts Usenet to shame. There may indeed be a problem with the 601 design, though the report is something of a shot-gun affair re causal factors. I guess if they put in enough issues they can hope to later say "we told you so" no matter the cause(s) found for the cited accidents. |
Klewless newbie alert! (Was Troll alert! Why is "CovvTseTung" using multiple aliases here?) | Maxwell[_2_] | Piloting | 76 | August 22nd 08 04:07 PM |
USA / The Soaring Safety Foundation (SSF) Safety Seminars 2008 | [email protected] | Soaring | 0 | November 8th 07 11:15 PM |
Find a Safety Pilot in your area with Safety Pilot Club | Safety Pilot Club | Instrument Flight Rules | 0 | December 29th 06 03:51 AM |
The Soaring Safety Foundation (SSF) Safety Seminars Hit The Road in the USA | [email protected] | Soaring | 0 | September 11th 06 03:48 AM |
