Schleicher wing tanks
Old April 20th 09, 06:24 PM posted to rec.aviation.soaring
Andy[_1_]
Default Schleicher wing tanks
Are the wing ballast tanks of the 27B, 28, and 29, fabricated as
complete assemblies separate from the wing skins, or do the wing skins
form the tanks walls?
Comment from anyone that has seen the wings being built, or has seen
one opened after build, appreciated.
thanks
Andy
Old April 21st 09, 02:29 AM posted to rec.aviation.soaring
thanks
Andy
They are comprised of the upper and lower wing skins, the spar, end
cap assemblies, and baffles.
When all glued together, it is a wing with internal tank.
UH
Old April 21st 09, 06:38 PM posted to rec.aviation.soaring
Andy[_1_]
thanks
Andy
UH
Old April 21st 09, 06:39 PM posted to rec.aviation.soaring
Andy[_1_]
UH
Thanks Hank,
Andy
Old April 22nd 09, 07:00 PM posted to rec.aviation.soaring
Tuno
Schleicher owners should note that the 29's (after the first few
serial numbers) have vent holes drilled in the leading edges of the
wing root ribs. These holes are about 7mm diameter and are filled with
metal, O-ringed plugs for ballasted flight. If your Schleicher doesn't
have these, I suspect it would be a straightforward retro-fit, but be
aware that the plugs can leak (I had to replace the factory O-rings on
mine with larger ones) and you can make a real mess if you forget to
put the plugs in before you rig and water up!
Old April 21st 09, 08:22 PM posted to rec.aviation.soaring
Walter[_2_]
Hi Andy,
some of the 27 have water bags - as opposed to integral tanks (i.e. wet
wings)
Look he
http://www.alexander-schleicher.de/tm/27/270_TM09_E.pdf
The 28 and the 29 seem to have integral tanks:
http://www.alexander-schleicher.de/t...graltank_E.pdf
hope this helps
Walter
WTB Schleicher ASK-21 ZZ Soaring 1 May 11th 08 11:21 PM
Drains in Wing Tanks flybynightkarmarepair Home Built 9 April 8th 06 05:32 PM
schleicher wing faults. Bruce Greeff Soaring 4 August 18th 04 09:01 PM
Schleicher Ka6-CR For Sale Scott Soaring 4 February 6th 04 07:24 PM
FS - Schleicher Ka6CR Scott Soaring 0 October 5th 03 02:34 AM
