The Home-made Home-builders Engine
Old May 29th 09, 03:15 PM posted to rec.aviation.homebuilt
Veeduber[_2_]
Default The Home-made Home-builders Engine
To All:
For those of us who own a lathe and milling machine, somewhere in our
past there is probably a tiny steam engine. Indeed, there's probably
more than than one. A company in England provides the basic castings
as a kit. As the machinist, you are expected to provide all else,
from the machine to do the work to the KNOWLEDGE needed to operate the
machine.
Producing such an engine, from the basic one-cylinder model to larger
engines of remarkable complexity, serves as silent testimony as to our
abilities.
It strikes me as little more than a step along the way to produce a
FULL SIZE engine such as the Pobjoy. The crankshaft calls for a
professional piece of goods, probably obtainable from a Chinese
manufacturer, but the cylinders, being identical, call for much less
in the way of skills and tooling. With cast-iron cylinder barrels and
cast aluminum heads, the bulk of the engine can be produced on the
tooling found in the shops of literally thousands of amateur
machinists found in every country around the world.
While the copyright to the engine is presently held by the same
company that produces the Rotax, there are enough example of the
Pobjoy in aviation museums that it would be a relatively minor chore
to produce a set of drawings. Indeed, knowing the engine's bore &
stroke even a good PHOTOGRAPH gives a wealth of data leading to a
usable drawing. So long as those drawings contained significant
differences from the original there should be no question as to
violation of those rights. Such differences could be calling out
parts and bearings NOT used in the original Pobjoy.
With suitable drawings in hand we could produce the required molds
needed to produce the required castings. The drawings will also tell
us what gears and bearings are required, allowing us to order them
from suppliers who deal in such components. The drawings will also
show what type of valve guides are needed and even the valves, springs
and rocker-arms. With a bore of 75mm and a stroke of 87, we can
determine what EXISTING pistons my be used as well as the size of the
carburetor that is required.
The 'Experiment- Amateur-built' licensing category exists to promote
aeronautical education in America. Learning how radial engines work
and even building one yourself is no more difficult, in my opinion,
than building your own airframe.
-Robert S. Hoover
Old May 29th 09, 07:50 PM posted to rec.aviation.homebuilt
Bob Murray
"Veeduber" wrote in message
To All:
machine.
abilities.
-Robert S. Hoover
There is also the Lawrance 5-cyl. radial, about 35 HP from 75 cubic inches,
and a crankcase just under 9" in diameter.
As far as crankshafts, most radials used built-up cranks which can be
machined fairly easily. In the size of engine under discussion, the parts
that need to be ground can be finished on any commercial tool & cutter
grinder, and then assembled.
BTW, 75 cubic inches works out to 250cc per cylinder - how many 250 singles,
500 twins, and 1000-1200 fours are out there that could donate pistons,
pins, & rings; valves, springs & keepers, etc.?
Another Bob
Old May 30th 09, 05:21 PM posted to rec.aviation.homebuilt
bildan
To All:
past there is probably a tiny steam engine. *Indeed, there's probably
more than than one. *A company in England provides the basic castings
as a kit. *As the machinist, you are expected to provide all else,
machine.
abilities.
FULL SIZE engine such as the Pobjoy. *The crankshaft calls for a
in the way of skills and tooling. *With cast-iron cylinder barrels and
usable drawing. *So long as those drawings contained significant
violation of those rights. *Such differences could be calling out
needed to produce the required castings. *The drawings will also tell
from suppliers who deal in such components. *The drawings will also
and rocker-arms. *With a bore of 75mm and a stroke of 87, we can
aeronautical education in America. *Learning how radial engines work
-Robert S. Hoover
machined fairly easily. *In the size of engine under discussion, the parts
Another Bob
Seem to me that the most modern motorcycle cylinders would be the
best. Metallurgy is still advancing rapidly and there are a lot of
innovations in recent bikes. Some even use "diamond-like coatings" on
high wear parts like cams and followers.
Recall that the Merlin and Allison V-12's of WWII used dual overhead
cams and 4 valves per cylinder which is the norm for motorcycles
today.
I worked up a CAD drawing of a radial using 5 banks of 4-cylinder
500cc motorcycle cylinder blocks. (7 banks didn't leave enough room
for intake and exhaust plumbing between the blocks.) The result is an
amazingly small 20 cylinder liquid cooled radial engine.
20 cylinders is enough that you could stop worrying about 2-plugs per
cylinder. If you fouled a couple, you probably wouldn't notice.
Looking through race parts catalogs turned up automatic transmission
planetary gear sets that are rated for 1500hp but are only 6" in
diameter and weigh about 15 pounds. The gear ratios are just right
for a PSRU. If they stand up to the hammering from a drag racer,
handling a couple of hundred HP should be a breeze.
To build this engine would require making a case, crank and rods with
the planetary in a nose case with thrust bearings. (Of course a lot
of other fiddly bits would need to be made as well.) However, the
heads, cylinders and pistons are the hard part and they are available
cheap.
Old May 31st 09, 07:35 AM posted to rec.aviation.homebuilt
Veeduber[_2_]
the planetary in a nose case with thrust bearings. *(Of course a lot
of other fiddly bits would need to be made as well.) *However, the
cheap.
I disagree with regard to the heads and cylinders. But you are
correct when it comes to the gear reduction unit.
As several others have pointed out, publicly and in private messages,
there has been significant advances in metallurgy since the Pobjoy
first ran in 1926.
The Pobjoy had its share of problems, from its inception until its
production was finally dropped in 1946. But those problems would
probably not apply if the engine were produced today. For example,
the use of a planetary gear reduction system would eliminate the wear
problems encountered with the original herringbone gear, while a
modern, fully sealed valve train would improve the engine's mean time
before failure.
As for the question of using existing cylinders and heads, an aircraft
engine uses a different design philosophy than is used when producing
any other type of engine, although a stationary industrial engine
comes very close.
Ideally, the heads should follow standard aircraft engine practice in
the use of forgings rather than castings, although if the engine were
kitted, even partially so -- perhaps a pre-assembled lower end plus a
kit of parts for the cylinders and heads -- the price may be low
enough to satisfy the home-builder's budget limitations. For example,
if the heads were already machined, it does not take a great deal of
skill to swage the valve seats into place nor to stone them.
Volkswagen parts could be used for almost the entire valve train.
As a point of interest, while the basic idea is to produce an engine
sufficiently low in cost as to fulfill the needs of home-builders
around the world, should we be able to tap into a manufacturer at this
level, it is most likely they might be convinced to use their
facilities to produce the Fat-fin head needed to make the Volkswagen
engine more suitable than the existing engines by producing heads
having an honest sixty-five horsepower's-worth of fin area. Indeed,
this could be a method of subsidizing the cost of a 'replica' radial
-- OR OTHER ENGINE -- in that home-builders in those parts of the
world where Volkswagen components are still in good supply would
probably buy enough Fat-fin heads that their sale would provide the
start-up funds needed to get a more appropriate engine into
production.
Toward this end, while I mentioned the Pobjoy because of its excellent
ratio of power-to-weight, I also mentioned that an in-line engine such
as the de Havilland would be the least expensive.
This is another case where modern-day metallurgy may prove beneficial,
in that Lost Foam Casting might be used to produce the head and lower
end, using aftermarket air-cooled cylinders. The key to success in
this case would be the existence of a suitable crankshaft. That is,
one in which the throws are spaced sufficiently far apart to allow the
use of finned barrels.
-R.S.Hoover
Old May 31st 09, 07:24 PM posted to rec.aviation.homebuilt
[email protected][_2_]
this case would be the existence of a suitable crankshaft. *That is,
If I'm looking at this properly a standard VW water-cooled inline
crank (or most any similar 5 main bearing inline 4 crank) can be used
in a 90 deg. "V" 4. This would give plenty of room for fins. I think
all of the water-cooled VW cranks have 86mm or longer strokes and the
matching stock rods are between 7mm and 30mm longer than air-cooled
units, which should give good low speed torque. If it were a push rod
motor parts count would not be much greater than an inline?
A stub attached to the flywheel end of the crank and ground with the
mains to match a stock Continental front bearing, IMHO, would take
care of prop loads.
Leon McAtee
Old May 31st 09, 08:20 PM posted to rec.aviation.homebuilt
Anthony W
care of prop loads.
Leon McAtee
What about using an American V8 crank to build a straight air cooled
four? All the ones I've seen apart had 2 rods per throw and that would
space things out more. Machining down the counter weights would be
required but it would still leave you with a very strong crank. A light
weight aluminum clamp that looked like a big end of a rod could be easy
to make to block off the extra oil ports.
Another option would be to take a lesson from the so called V6 VW that
is little more than a staggered in-line six. Staggering the cylinders
to make a shallow V4 would also improve cooling. The problems of uneven
firing order could be solve by using a distributorless ignition or a
pare of 2 cylinder distributors. This way you could choose any in-line
4 crank that is both cheap and common as dirt (like the Toyota 20R for
example...)
Tony
Old June 1st 09, 06:09 AM posted to rec.aviation.homebuilt
Veeduber[_2_]
Lots of interesting ideas coming out. I've been doodling with them
using DeltaCAD. Trying to do an isometric of a V6 crankshaft is
enough to make you wanna go back to steam. Ditto for air-cooling.
Another ditto for valve trains.
Backing off, looking at the project from a different perspective, it
seems I'm more into details than basic concepts.
An exchange of messages with a fellow who actually works with the Lost
Foam process: when asked how fine I could go with details, he said to
go as fine as I like -- that producing the part was HIS task. Which
is kinda like money from home when you're trying to work out valve
train details. Some oil channels may have to be cleaned up with a
drill but the hole would still be there. Ditto for the fins. I spend
two hours on the thing before realizing I've got to do a lefty and a
righty.
Old May 31st 09, 07:45 PM posted to rec.aviation.homebuilt
bildan
cheap.
I disagree with regard to the heads and cylinders. *But you are
first ran in 1926.
production was finally dropped in 1946. *But those problems would
probably not apply if the engine were produced today. *For example,
before failure.
comes very close.
kit of parts for the cylinders and heads -- *the price may be low
enough to satisfy the home-builder's budget limitations. *For example,
facilities to produce *the Fat-fin head needed to make the Volkswagen
having an honest sixty-five horsepower's-worth of fin area. *Indeed,
-- OR OTHER ENGINE -- *in that home-builders in those parts of the
production.
end, using aftermarket air-cooled cylinders. *The key to success in
-R.S.Hoover
With respect, motorcycle heads are CNC machined from high strength
forged alloy billet. To my knowledge, no such head has ever failed
even under severe racing conditions.
The only 'top end' failures I'm aware of resulted from revving way
over red line RPM which caused valve failure. I know of a few which
suffered bent rods when the owner tried to start a hydraulically
locked engine after fuel had drained into a cylinder.
I would SWAG that top end motorcycle heads and cylinder blocks are
over designed for aircraft use by around 5X. The motorcycle news
group I belongs to recently asked if anyone had EVER overhauled their
engine due to simple wear. No one reported they had even though some
reported over 300,000 miles on their bikes. One reported tearing down
a high-mileage engine after the bike was wrecked just to find out what
the tolerances were - and to possibly re-use the parts. He reported
no measurable wear.
These are enormously strong engines and I think homebuilders should
take a serious look at them.
Another home-made helicopter Dave Whiley Aviation Photos 0 November 19th 07 11:45 PM
Home Made Helicopter J.F. Aviation Photos 0 November 17th 07 02:02 PM
Good news for scratch builders of metal airplanes - Home Depot rents bending brakes flybynightkarmarepair Home Built 7 January 6th 07 04:22 PM
Home made plane crashes Bill Smith Piloting 0 August 7th 06 06:07 AM
Home made aviation websites are cool! CFLav8r Piloting 2 January 21st 04 05:31 AM
