ATC Radar Question
Old June 12th 09, 01:53 AM posted to rec.aviation.piloting
Jackie
Default ATC Radar Question
I understand that ATC radar uses an encoding altimeter and a transponder
operating with Mode C to determine an aircraft's altitude. Let's forget
about Mode C for a moment and switch to Mode A only or just a primary
return.
If an aircraft is at 18,000 ft (approx 3 nm) and 3 nm away from the
radar antenna, as seen on a map, how does the radar correct for slant
distance when distance is displayed (e.g. using concentric circle
distance markers on the scope or relative to a known distance, such as a
marker on the display)?
In other words how does the radar know that the aircraft is actually 3
nm away laterally and not 4.25 nm (approx slant distance at that altitude)?
Old June 12th 09, 02:40 AM posted to rec.aviation.piloting
Matt Barrow[_8_]
"Jackie" wrote in message
operating with Mode C to determine an aircraft's altitude. Let's forget about
Mode C for a moment and switch to Mode A only or just a primary return.
If an aircraft is at 18,000 ft (approx 3 nm) and 3 nm away from the radar
antenna, as seen on a map, how does the radar correct for slant distance when
distance is displayed (e.g. using concentric circle distance markers on the
scope or relative to a known distance, such as a marker on the display)?
In other words how does the radar know that the aircraft is actually 3 nm away
Asquared + B squared = C squared, I'd guess.
Old June 12th 09, 02:51 AM posted to rec.aviation.piloting
Jackie
And how does it separate A and B?
Old June 12th 09, 11:21 PM posted to rec.aviation.piloting
Matt Barrow[_8_]
return.
when distance is displayed (e.g. using concentric circle distance markers on
the scope or relative to a known distance, such as a marker on the display)?
"A" is the radar range, "B" is garnered from the encoding altimiter.
Old June 13th 09, 12:44 AM posted to rec.aviation.piloting
Peter Dohm
"Matt Barrow" wrote in message
transponder
forget
return.
radar
distance
markers on
display)?
nm
altitude)?
Interesting thread!
But, for the life of me, I can't figure any reason that atc would really
care about the exact map location of an aircraft--especially when it is both
close enough and high enough for the error to be significant.
Given the two most common uses, surveilance approaches to an airport at
nearly the same elevation as the radar and collision avoidance, the map
distance should be a trivial issue.
Peter
Old June 13th 09, 03:10 AM posted to rec.aviation.piloting
Matt Barrow[_8_]
"Peter Dohm" wrote in message
Interesting thread!
But, for the life of me, I can't figure any reason that atc would really care
about the exact map location of an aircraft--especially when it is both close
Given the two most common uses, surveilance approaches to an airport at nearly
the same elevation as the radar and collision avoidance, the map distance
Given the effort put into the significantly more accurate WAAS infrastructure,
I'd suspect that getting a more accurate fix would be correspondingly desirable.
Old June 13th 09, 06:09 AM posted to rec.aviation.piloting
Jackie
return.
Huh? In the example I provided, "Let's forget about Mode C for a moment
and switch to Mode A only..." there is *no encoding altimeter* so your
point doesn't make sense here.
Old June 14th 09, 01:09 AM posted to rec.aviation.piloting
Jim Logajan
transponder operating with Mode C to determine an aircraft's
altitude. Let's forget about Mode C for a moment and switch to
slant distance when distance is displayed (e.g. using concentric
circle distance markers on the scope or relative to a known
actually 3 nm away laterally and not 4.25 nm (approx slant distance
at that altitude)?
Nit: Actually "C" would be radar range and either "A" or "B" would be from
the altimeter, solving then for "B" or "A".
Old June 12th 09, 03:15 AM posted to rec.aviation.piloting
return.
Absent something else, it doesn't.
All a primary paint radar knows is azimuth and slant range.
Jim Pennino
Remove .spam.sux to reply.
Old June 12th 09, 03:22 AM posted to rec.aviation.piloting
Jim Logajan
Without altitude information from the pilot or a Mode C transponder, the
radar system can't extract the horizontal distance from the slant distance.
Where did you read that their systems correct for altitude without Mode C
transponders? If they could do that then they wouldn't have ever needed the
transponders to report altitude.
below the radar Philip Stroh Aviation Photos 31 November 27th 06 03:12 PM
Integrating onboard weather radar data with satellite-fed Doppler radar [email protected] General Aviation 3 January 9th 05 08:57 PM
Question about the F-22 and it's radar. Scott Ferrin Military Aviation 128 June 13th 04 01:23 AM
Yet another "Radar Required" question. Roy Smith Instrument Flight Rules 14 April 27th 04 05:07 PM
F15E Radar question. Bill Silvey Military Aviation 5 August 30th 03 06:17 PM
