I know the compressor requirements are stated when considering a
sandblaster, but is there anyway to measure the effectiveness e.g. is my blaster taking off paint as quickly as someone elses? As an example, I can take off an 1/8" strip of paint at about 1"/second, but have no idea what should be happening - Mike |
![]() "Michael Horowitz" wrote in message ... | I know the compressor requirements are stated when considering a | sandblaster, but is there anyway to measure the effectiveness e.g. is | my blaster taking off paint as quickly as someone elses? | | As an example, I can take off an 1/8" strip of paint at about | 1"/second, but have no idea what should be happening - Mike | To take a lot off in one pass you have to have a industrial capacity compressor and nozzle. 100 to 115psi @ 5 to 7cfm doesn't give you much except for cleaning small parts. A water separator is a must. A commercial shop I use shuts down when the humidity is high. They use an old Military surplus compressor that puts out close to 100cfm @ 150psi or there-a-bouts. FWIW yours is doing about what my old Sears compressor/blaster used to do. -- But a Constitution of Government once changed from Freedom, can never be restored. Liberty, once lost, is lost forever. John Adams, letter to Abigail Adams, July 17, 1775 Anyolmouse |
![]() "Anyolmouse" wrote To take a lot off in one pass you have to have a industrial capacity compressor and nozzle. 100 to 115psi @ 5 to 7cfm doesn't give you much except for cleaning small parts. A water separator is a must. A commercial shop I use shuts down when the humidity is high. They use an old Military surplus compressor that puts out close to 100cfm @ 150psi or there-a-bouts. FWIW yours is doing about what my old Sears compressor/blaster used to do. WoW! I can't even comprehend a compressor that big! What is the power source; IC engine, or electric, and do you know how big the power source is, in either HP or amps? That would help me try to put it into size. -- Jim in NC |
![]() "Morgans" wrote in message ... | | "Anyolmouse" wrote | | To take a lot off in one pass you have to have a industrial capacity | compressor and nozzle. 100 to 115psi @ 5 to 7cfm doesn't give you much | except for cleaning small parts. A water separator is a must. A | commercial shop I use shuts down when the humidity is high. They use an | old Military surplus compressor that puts out close to 100cfm @ 150psi | or there-a-bouts. FWIW yours is doing about what my old Sears | compressor/blaster used to do. | | WoW! I can't even comprehend a compressor that big! | | What is the power source; IC engine, or electric, and do you know how big the | power source is, in either HP or amps? That would help me try to put it into | size. | -- | Jim in NC | The compressor is diesel powered and is about the size of my Safari van, maybe a little bigger. The sand hopper is roughly a 10 ft square funnel at the top that tapers down to an outlet at the bottom. The guy that operates it has a helmet with a face plate that has a leather/canvas breastplate and apron. The delivery hose is about the size of a fire hose. Filtered air is fed to his helmet to make sure he has good air to breathe. They sand blasted a friends old VW beetle in about a half hour. I think almost half of that was prep time. -- "We have no government armed with power capable of contending with human passions unbridled by morality and religion. Avarice, ambition, revenge, or gallantry, would break the strongest cords of our Constitution as a whale goes through a net. Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other." --John Adams, October 11, 1798 Anyolmouse |
On Jun 12, 4:30*pm, "Morgans" wrote:
*WoW! *I can't even comprehend a compressor that big! What is the power source; IC engine, or electric, and do you know how big the power source is, in either HP or amps? *That would help me try to put it into size. ------------------------------------------------------------------------------ Dear Jim, A modified VW engine makes a pretty good media blaster in the medium- size range. This is a 96cid engine that is modified so that two barrels are constantly pumping whilst the other two serve as the power source (ie, about 15hp). Using a VW bug body as an example, it will usually take from six to eight hours to strip one of paint, tar, etc. Tthe really big units are found at dry docks, for treatment of concrete piers and other heavily encrusted objects. -R.S.Hoover -(USN Retired) |
Bob wrote:
On Jun 12, 4:30 pm, "Morgans" wrote: WoW! I can't even comprehend a compressor that big! What is the power source; IC engine, or electric, and do you know how big the power source is, in either HP or amps? That would help me try to put it into size. ------------------------------------------------------------------------------ Dear Jim, A modified VW engine makes a pretty good media blaster in the medium- size range. This is a 96cid engine that is modified so that two barrels are constantly pumping whilst the other two serve as the power source (ie, about 15hp). Using a VW bug body as an example, it will usually take from six to eight hours to strip one of paint, tar, etc. Tthe really big units are found at dry docks, for treatment of concrete piers and other heavily encrusted objects. -R.S.Hoover -(USN Retired) The VW engine idea sounds interesting. Any suggestions where to find plans? I don't think Id build one, but it should be an interesting read. I would imagine such Navy machines would be a tad noisy. I have never had the pleasure of hearing a rivet gun used in building large sea going vessels. I have the feeling it also would be a bit loud. Dan, U.S. Air Force, retired |
![]() "Dan" wrote in message ... Bob wrote: A modified VW engine makes a pretty good media blaster in the medium- size range. This is a 96cid engine that is modified so that two barrels are constantly pumping whilst the other two serve as the power source (ie, about 15hp). Using a VW bug body as an example, it will usually take from six to eight hours to strip one of paint, tar, etc. Tthe really big units are found at dry docks, for treatment of concrete piers and other heavily encrusted objects. -R.S.Hoover -(USN Retired) The VW engine idea sounds interesting. Any suggestions where to find plans? I don't think Id build one, but it should be an interesting read. I would imagine such Navy machines would be a tad noisy. I have never had the pleasure of hearing a rivet gun used in building large sea going vessels. I have the feeling it also would be a bit loud. Dan, U.S. Air Force, retired You can do the same with the old 289/302 Ford engines. I rented a jack hammer from a local rental supply company many years ago, that was a tankless compressor built on a trailer with nothing more than a 302 Ford with one stock head, and one compressor head. |
On Jun 12, 10:21*pm, Dan wrote:
* * The VW engine idea sounds interesting. Any suggestions where to find plans? I don't think Id build one, but it should be an interesting read. Dan, U.S. Air Force, retired http://dunnrightinc.com/ Great use for those VW parts that really shouldn't be put back on the road much less in the air.......................... ==================== Leon McAtee |
Dan wrote:
Bob wrote: On Jun 12, 4:30 pm, "Morgans" wrote: WoW! I can't even comprehend a compressor that big! What is the power source; IC engine, or electric, and do you know how big the power source is, in either HP or amps? That would help me try to put it into size. ------------------------------------------------------------------------------ Dear Jim, A modified VW engine makes a pretty good media blaster in the medium- size range. This is a 96cid engine that is modified so that two barrels are constantly pumping whilst the other two serve as the power source (ie, about 15hp). Using a VW bug body as an example, it will usually take from six to eight hours to strip one of paint, tar, etc. Tthe really big units are found at dry docks, for treatment of concrete piers and other heavily encrusted objects. -R.S.Hoover -(USN Retired) The VW engine idea sounds interesting. Any suggestions where to find plans? I don't think Id build one, but it should be an interesting read. I would imagine such Navy machines would be a tad noisy. I have never had the pleasure of hearing a rivet gun used in building large sea going vessels. I have the feeling it also would be a bit loud. Dan, U.S. Air Force, retired Here is an exchange from several years ago hear on RAH. ======== "Bruce A. Frank" wrote: I helped build a Chevy 327 into a compressor many years ago. We kept it simple and crude. Every other cylinder in the firing sequence was made into a pumping cylinder. The intake manifold runners to each compressor cylinder was plugged with a chunk of wood and JB Weld epoxy to prevent fuel mixture from flowing there. A hole was drilled in each compressor cylinder runner between the epoxied plug and the intake valve. those four holes were piped together to draw air from an air cleaner element. The rocker arms on each of the compressor cylinders were removed and a hardware store light spring installed in place of the normal intake valve spring. This allowed the intake valve to open every time the piston headed down, rather than just on the "intake cycle" of the cylinder. A check valve replaced the spark plugs so every up stroke of the piston compressed air. The Chevy 327 ran like a top and produced enough air at 4000 rpm to power a small jack hammer. It seems we calculated 200+ cfm at 100 psi. Intake and exhaust were muffled so it ran very quietly. -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL BAFRANK(at)worldnet.att.net Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| *------------------------------**----* \(-o-)/ AIRCRAFT PROJECTS CO. \___/ Manufacturing parts & pieces / \ for homebuilt aircraft, 0 0 TIG welding While trying to find the time to finish mine. ======== Tony P wrote: HI Bruce. So YOU'RE the guy who built that one I saw! That explains it. I even think it was an SBC engine. Sounds pretty similar to what I saw, but somehow I think the thing plugged along at idle most of the time and just accelerated as needed. Maybe it vented off surplus? Also had a neat loping sound. The powered cylinders clearly had no difficulty keeping up, probably ridiculously overpowered. Tony Pucillo -- I speak only for myself unless otherwise stated. One personality is enough, thank you. "Irony better befits a gentleman than buffoonery; the ironical man jokes to amuse himself, the buffoon to amuse other people." (Aristotle, 'Rhetoric') ======== "Bruce A. Frank" wrote: From empty tank to full, from start up to pop off, was about 20 seconds (50 gal tank). While we were using it it ran at about 1000 rpm. With the jack hammer we turned it up to 4000 rpm and with the JH running full bore the pop off valve was always blowing. When we put the commercially mfg. controller on it the rpm hardly ever got above 500 (the tank would fully pressureize before the engine reached its controller set 2500 rpm). Last I heard it was still running just fine (30 years now! and the engine had 90,000 miles when we converted it with no overhaul) Ours had a sort of pocketta-pocketta sound, much like an antique 4 cylinder engine. An interesting side note, the air out of that engine was as oil free and clean as if it had been charcoal filtered. There was no exhaust gas blow-by smell or gasoline smell. A friend in PA built the same thing for a sandblast outfit. It'll pump through 600 lbs of sand at 130 psi in about 15 minutes. -- Bruce A. Frank, Editor "Ford 3.8/4.2L Engine and V-6 STOL BAFRANK(at)worldnet.att.net Homebuilt Aircraft Newsletter" | Publishing interesting material| | on all aspects of alternative | | engines and homebuilt aircraft.| *------------------------------**----* \(-o-)/ AIRCRAFT PROJECTS CO. \___/ Manufacturing parts & pieces / \ for homebuilt aircraft, 0 0 TIG welding While trying to find the time to finish mine. |
On Jun 12, 9:21*pm, Dan wrote:
* * The VW engine idea sounds interesting. Any suggestions where to find plans? I don't think Id build one, but it should be an interesting read. ------------------------------------------------------------------------------ There used to be a company named 'Dunn-Rite' (sp?) which supplied a conversion kit, but the idea dates from the 1930's and the conversion of anu I-4 or V-8 engine for that purpose. The VW is especially easy to convert and the DIY method has been explained several times on VW- specific Groups. Basically, you simply select a pair of sequenctially- firing cylinders as your power pair (ie, 1-3 or 2-4) and use the other pair as your 'pumping' cylinders. The spark plugs of the pumping cylinders are modified to act as ball-type check valves while the exhaust stack is modified to become an input valve by the use of a flapper valve made of light-gauge spring steel. The push-rods & rocker arms of the pumping pair are modified so as to always be open. --------------------------------------------------------------------------------- * * I would imagine such Navy machines would be a ta d noisy. I have never had the pleasure of hearing a rivet gun used in building large sea going vessels. I have the feeling it also would be a bit loud. --------------------------------------------------------------------------------------- Actually, they sound remarkably like welding machines :-) (I don't think the Navy hasn't used riveted hulls since the 1920's) -Bob |
Clarke sandblaster gun - moisture? | Michael Horowitz | Home Built | 16 | May 24th 09 03:38 PM |
TRMM - Tropical Rainfall Measuring Mission | sen | Piloting | 0 | October 31st 07 05:13 AM |
measuring flap angles for rigging | [email protected] | Home Built | 12 | April 28th 06 02:46 PM |
measuring arm distances | Heino & Deanne Weisberg | Home Built | 1 | October 21st 05 05:49 PM |
Metric measuring tool source? | DL152279546231 | Home Built | 12 | April 29th 04 02:13 AM |
