Loud noise upon braking
Old June 16th 09, 07:56 PM posted to rec.aviation.soaring
Itsaplane[_2_]
Default Loud noise upon braking
Making a relatively low-energy landing in my DG-300 (s/n 3E1) on
Sunday, I modestly applied the brakes and instantly heard a loud
buzzing (?) noise. I released the brakes, the noise stopped, and I
reapplied the brakes and heard no noise with normal braking power.
This is a TOST drum brake.
A cursory inspection of the main wheel/brake assembly revealed nothing
out of the ordinary -- though the drum appears to be dragging on the
wheel at various points around its turn (*very* softly dragging, i.e.,
not turning friction-free) -- not sure if it was this way before.
Should I investigate this further?
Thanks,
Eric
Old June 17th 09, 04:22 PM posted to rec.aviation.soaring
Dave Nadler
Na, just turn the radio up.
Old June 18th 09, 12:48 AM posted to rec.aviation.soaring
Andy[_1_]
I'd assume that whatever was buzzing either died or escaped.
Perhaps some rusting of the brake drum caused a resonance which went
away after the rust was polished off. How long since the last brake
usage and is the glider in a damp environment?
You could try disconnecting the brake cable so the actuating arm is
fully relaxed and see if the rubbing goes away. If it does not, you
may need to pull the wheel and inspect the brake plate, shoes, and
drum. If it does, you may need to adjust the cable or the arm
position. The best geometry is for the arm and cable to be just short
of a 90 deg angle at max brake application and the shoes should not
rub when there is no brake application.
I always applied full brake as the wheel spindle bolt was tightened.
This ensures the brake plate is centered if there is any free play.
I'm assuming you dismantle it every year and clean and lubricate the
pivot points and the cam faces.
Andy
Old June 20th 09, 05:09 AM posted to rec.aviation.soaring
Terry Mc Elligott
You might want to contact Michael "Mercury" Morse at Vintage Brake, in
Sonora, California ... he
http://www.vintagebrake.com/
should your TOST brake cease stopping the DG quite as effectively. One
of those very handy contacts to keep in mind.
Terry Mc Elligott
DG-200 / C-GVLB
buzzing (?) noise. *I released the brakes, the noise stopped, and I
Thanks,
Eric
Fwd: [CivilAirComms] Loud noise on Delta 351 [email protected] General Aviation 0 July 27th 08 07:47 AM
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets Jim Macklin Instrument Flight Rules 15 January 13th 07 01:06 AM
Thinking out loud Marco Rispoli Owning 21 May 4th 04 05:22 PM
LOUD Scott Lowrey Military Aviation 40 September 11th 03 01:39 AM
LOUD Scott Lowrey Piloting 34 September 11th 03 01:39 AM
