Yesterday I was flying from York PA to Myrtle Beach IFR, direct to destination at the time, and the controller called me and said that I had to make a decision. The airspace ahead was "closed" so I could either be routed around it IFR, or I could cancel and climb 500 ft, and continue VFR for a while, and get my IFR back from the next controller. (He stressed that he was in no way soliciting a cancelation -- it was my call.) Since I didn't want to go out of my way, I cancelled, climbed and stayed on the same code for advisories, and sure enough the next controller offered me IFR again, so I was recleared to destination and put back on an IFR altitude. Never heard of this before. Any comments? |
On Jun 20, 10:51*am, Mike Granby wrote:
Yesterday I was flying from York PA to Myrtle Beach IFR, direct to destination at the time, Any comments? Looks like about 450 miles. Any clues as to where you might have been at the time... maybe near Ft. Pickett? ----- - gpsman |
Near Seymour Johnson, so I did consider that it was the MOA north of there, but then why wouldn't he offer me a descent to 6000 instead to go under it, since I was only at 8000. (I've flown this route several times in the last few months, including in the week, and never had this issue before, but I've typically been at 6000, so the MOA does make sense.) |
He should have listed the airspace by name.. did he? A Restricted area or
MOA? He cannot clear non participating IFR aircraft through an active MOA. Non Participating means that you are not part of those that are reserving the MOA. I'm surprised he offered traffic advisories while you were in the MOA. Perhaps he knew that those reserving it were not there yet, but it had "gone hot" and he could not sued it for IFR traffic. Maybe he did not offer lower because he already had enough traffic ducking under the MOA. BT "Mike Granby" wrote in message ... Near Seymour Johnson, so I did consider that it was the MOA north of there, but then why wouldn't he offer me a descent to 6000 instead to go under it, since I was only at 8000. (I've flown this route several times in the last few months, including in the week, and never had this issue before, but I've typically been at 6000, so the MOA does make sense.) |
He should have listed the airspace by name.. did he? A Restricted area or MOA? Nope. Just "airspace closure". He cannot clear non participating IFR aircraft through an active MOA. Non Participating means that you are not part of those that are reserving the MOA. My understanding is that IFR traffic can be cleared through a MOA if ATC can ensure separation, so presumably there are some cases when they can, and some cases when they can't. I wonder what defines which case it is? I'm surprised he offered traffic advisories while you were in the MOA. Yep. Perhaps he knew that those reserving it were not there yet, but it had "gone hot" and he could not sued it for IFR traffic. Would make sense. |
Yes.. IFR traffic can be cleared through the MOA if IFR separation can be
assured. He can do it if he is controlling the MOA users and ask them to either stay in one corner while you blast through, or give them a "hard deck" above your altitude while you transition. If the MOA is being controlled by a military controller running intercepts with the active players, the military controller most likely did not want to bother with you, did not want you on frequency and told the Civil ATC to keep you. BT "Mike Granby" wrote in message ... He should have listed the airspace by name.. did he? A Restricted area or MOA? Nope. Just "airspace closure". He cannot clear non participating IFR aircraft through an active MOA. Non Participating means that you are not part of those that are reserving the MOA. My understanding is that IFR traffic can be cleared through a MOA if ATC can ensure separation, so presumably there are some cases when they can, and some cases when they can't. I wonder what defines which case it is? I'm surprised he offered traffic advisories while you were in the MOA. Yep. Perhaps he knew that those reserving it were not there yet, but it had "gone hot" and he could not sued it for IFR traffic. Would make sense. |
Yesterday I was flying from York PA to Myrtle Beach IFR, direct to destination at the time, and the controller called me and said that I had to make a decision. The airspace ahead was "closed" so I could either be routed around it IFR, or I could cancel and climb 500 ft, and continue VFR for a while, and get my IFR back from the next controller. (He stressed that he was in no way soliciting a cancelation -- it was my call.) Since I didn't want to go out of my way, I cancelled, climbed and stayed on the same code for advisories, and sure enough the next controller offered me IFR again, so I was recleared to destination and put back on an IFR altitude. Never heard of this before. Any comments? I suspect this is your explanation: http://www.newsobserver.com/news/story/1579599.html "For about 30 minutes early Friday evening, several air corridors above Eastern North Carolina had to be shut down because there was no air-traffic controller available, said Curt Johnson, vice president of the union's Washington Center division." |
I suspect this is your explanation: Now that makes sense. Especially since after I went VFR, the controller gave me a time at which to contact Seymour Approach if I lost radio contact with him before I got a hand-off. He came back later and said there was a change of plan, and that another controller had agreed to work me VFR to the south, so I never had to rely on the timed freq change, but it does rather fit with this story. |
| Wichita Airspace Question and overlapping airspace | Owen[_4_] | Piloting | 1 | February 14th 07 10:35 PM |
| behind closed doors | 5-BG | Soaring | 8 | October 1st 06 03:51 AM |
| Two airspace classes for one airspace? (KOQU) | John R | Piloting | 8 | June 30th 04 05:46 AM |
| most of eastern Massachussetts airspace closed in July | Christopher C. Stacy | Instrument Flight Rules | 29 | June 19th 04 01:47 AM |
| CGX closed (WHY!) | Tlewis95 | Piloting | 28 | March 5th 04 10:45 PM |
