I was getting ready to install a replacement manifold on the old Mercury
and it occurred to me I ought to be pretty sure my torque wrench didn't strip the aluminum threads. The Snap On dial wrench hasn't been recalibrated for 30 years and the Craftsman torsion bar wrench is too clumsy to get to some of the bolts. I was kicking it around and I came up with using the torsion bar wrench on a bicycle axle nut and then putting the dial wrench on it to see if the reading matched. It did. Then, I went ahead and checked the Craftsman clicker wrench of the same vintage and recalibrating, and it came up with a match also. Then I did the torquing with the dial wrench and cross checked it with the torsion bar wrench, with all good readings. So, I'm just going to call them calibrated. Andy Phoenix |
Make it so that you can pull the torsion bar wrench with the snap on--
against each other. They should read the same. How could the torsion wrench be off if it zeros properly and nothing in the ponter binds? Bill Hale Loveland CO On Jun 25, 12:39*pm, wrote: I was getting ready to install a replacement manifold on the old Mercury and it occurred to me I ought to be pretty sure my torque wrench didn't strip the aluminum threads. *The Snap On dial wrench hasn't been recalibrated for 30 years and the Craftsman torsion bar wrench is too clumsy to get to some of the bolts. *I was kicking it around and I came up with using the torsion bar wrench on a bicycle axle nut and then putting the dial wrench on it to see if the reading matched. *It did. Then, I went ahead and checked the Craftsman clicker wrench of the same vintage and recalibrating, and it came up with a match also. *Then I did the torquing with the dial wrench and cross checked it with the torsion bar wrench, with all good readings. *So, I'm just going to call them calibrated. Andy Phoenix |
Bill wrote:
Make it so that you can pull the torsion bar wrench with the snap on-- against each other. They should read the same. How could the torsion wrench be off if it zeros properly and nothing in the ponter binds? Bill Hale Loveland CO You are correct for a bending rod type wrench--but some torque wrenches have a spring loaded(adjustable)hollow handle that allows a piece to pop out of a Vee notch making an audible click that is also felt in the handle--(very handy for torquing where you can't see the dial or pointer. Jerry On Jun 25, 12:39 pm, wrote: I was getting ready to install a replacement manifold on the old Mercury and it occurred to me I ought to be pretty sure my torque wrench didn't strip the aluminum threads. The Snap On dial wrench hasn't been recalibrated for 30 years and the Craftsman torsion bar wrench is too clumsy to get to some of the bolts. I was kicking it around and I came up with using the torsion bar wrench on a bicycle axle nut and then putting the dial wrench on it to see if the reading matched. It did. Then, I went ahead and checked the Craftsman clicker wrench of the same vintage and recalibrating, and it came up with a match also. Then I did the torquing with the dial wrench and cross checked it with the torsion bar wrench, with all good readings. So, I'm just going to call them calibrated. Andy Phoenix |
Jerry Wass wrote:
Bill wrote: Make it so that you can pull the torsion bar wrench with the snap on-- against each other. They should read the same. How could the torsion wrench be off if it zeros properly and nothing in the ponter binds? Bill Hale Loveland CO You are correct for a bending rod type wrench--but some torque wrenches have a spring loaded(adjustable)hollow handle that allows a piece to pop out of a Vee notch making an audible click that is also felt in the handle--(very handy for torquing where you can't see the dial or pointer. Jerry In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. I wonder if the electronic torque wrenches are worth the money. Has anyone in RAH tried them? Dan, U.S. Air Force, retired |
"Dan" wrote in message
... Jerry Wass wrote: Bill wrote: Make it so that you can pull the torsion bar wrench with the snap on-- against each other. They should read the same. How could the torsion wrench be off if it zeros properly and nothing in the ponter binds? Bill Hale Loveland CO You are correct for a bending rod type wrench--but some torque wrenches have a spring loaded(adjustable)hollow handle that allows a piece to pop out of a Vee notch making an audible click that is also felt in the handle--(very handy for torquing where you can't see the dial or pointer. Jerry In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. I wonder if the electronic torque wrenches are worth the money. Has anyone in RAH tried them? Dan, U.S. Air Force, retired I have not tried the electronic variety; but my recollection is that the click type torque wrenches were supposed to be calibrated annualy--so long as no incident occured, such as dropping or other abuse. Peter |
snip
In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn |
coffelt2 wrote:
snip In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn We used the "tighten it until it breaks, then back off a half turn" and the "finger tight, plus a quarter turn" methods. QC wasn't fond of the response "two clicks of the left elbow" when we were asked what the proper torque was. Wasn't the -2 T.O. series issued to sit on or to protect ones knees on a B-4 stand? Not that I ever did that, you understand, but there was talk. Dan, U.S. Air Force, retired |
"coffelt2" wrote in message ... snip In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. I like the idea of taking the wrench to a shop to check calibration. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn Hey don't forget the proper torque on the propellor retaining nut on the 4360 was "All you can with both hands on the Cheater Bar, then a 1/4 turn more". Note proper Cheater Bar was 6' long. Stu Fields B-36 engine change crew. |
On Jun 29, 9:53*pm, "coffelt2" wrote:
snip * In the Air Farce we were supposed to click the break type torque wrench three times at the lowest setting before using it. This was supposed to spread the lubrication inside. * I like the idea of taking the wrench to a shop to check calibration.. Having said that, in my first shop in the USAF we calibrated torque wrenches so I may be a tad biased. The machine we used was huge and probably weighed close to a ton. Torque wrenches in the USAF are periodically calibrated, I forget the cycle, and taken in for calibration if dropped or abused. snip Dan, U.S. Air Force, retired * * *Heck, Dan, in the Air Force there was an alternate torque measuring system that didn't even require a torque wrench. (PMEL calibrated, of course) Simply "strip" it and back off one half turn. Farm boys from Georgia taught me that. Old Chief Lynn Yeah, but ya gotta know the difference between metric and SAE torque. SAE = 1 3/4 grunts Metric = Gutentieght |
| Thread Tools | |
| Display Modes | |
| Thin 3/8" wrench | RST Engineering | Home Built | 10 | November 17th 06 01:52 PM |
| Flight wrench question | R.H. | Piloting | 14 | June 25th 06 04:48 PM |
| Ignition lead nut-wrench | jerry wass | Aviation Marketplace | 0 | April 8th 06 04:55 AM |
| Wrench size for KI214 & KI201 OBS knob | Roy Page | Owning | 7 | March 11th 05 11:07 PM |
| Volkslogger Calibration | Ray Lovinggood | Soaring | 5 | September 13th 03 05:56 PM |
