Thrust vs Shaft Horse Power?
Old July 19th 04, 07:45 PM
Evan Williams
Default Thrust vs Shaft Horse Power?
A question for all of the pilots, engineers, and people who are a lot
smarter than me. Is there a simple rule of thumb for comparing the amount
of thrust or lift you can get from an engine which drives a set of propeller
or rotor blades to the amount of thrust you can get from the exhaust of a
non-turbo prop engine? For example, a T56-15 from a C-130 has 4,910 SHP and
a J85-21 from an F-5E has 5,000 lbs of thrust (These numbers are from a
twenty year old book of mine. For the sake of this discussion, lets just
assume they are correct). How much actual thrust can you get from the T56
on the C-130? I realize that there must be a lot of variables involved with
the propellers or rotors due to different airfoil shapes and the "lift" that
they provide and the pitch the blades are set at. But I was wondering if
there was a "general rule" that people went by. Keep in mind that math was
one of the main reasons that I dropped out of college and I just spend the
last twenty years as an Aviation Ordnanceman (Population Control) so any
large mathematical equations would go right over my head.
I apologize in advance for posting a question with little chance of
degrading into a political rant.
Evan Williams
Old July 19th 04, 11:38 PM
Paul J. Adam
In message et, Evan
Williams writes
Short answer... no.
Me clankie, me not know much, but actual thrust depends on atmospheric
conditions and airspeed and other factors too.
It seems to my non-specialist eye that props are better at turning
'power' into 'thrust' at low speeds, less so as speeds and altitudes
increase.
on the C-130?
At what airspeed? In what atmospheric conditions?
Sorry to sound like a broken record, but the answer is 'it depends'.
If you want to haul cargo from short airstrips, turboprops.
If you want to haul lots of cargo from longer airstrips over longer
ranges, turbofans or *maybe* turboprops.
For general-purpose multirole fighters, turbofans.
For high-altitude interceptors, turbojets.
Others who know more will correct me, I'm sure.
He thinks too much: such men are dangerous.
Julius Caesar I:2
Paul J. Adam MainBoxatjrwlynch[dot]demon{dot}co(.)uk
Old July 20th 04, 12:32 AM
Scott Ferrin
On Mon, 19 Jul 2004 23:38:24 +0100, "Paul J. Adam"
In message et, Evan
Williams writes
Short answer... no.
increase.
on the C-130?
It's been discussed here in the past and I don't recall there being
any definitive answer. The lift fan on the X-35 draws about 28000hp
off the main engine to produce 18000 pounds of thrust but then if you
hooked that same 28000 to a big helicopter roter you'd generate a LOT
more lift.
Old July 20th 04, 04:05 AM
Evan Williams
Thank you for the responses. And the very simple explinations. I was
"out of town" for much of last year so I must have missed the previous
thread.
Evan Williams
"Scott Ferrin" wrote in message
In message et, Evan
Williams writes
amount
propeller
a
Short answer... no.
increase.
just
T56
on the C-130?
more lift.
Old July 20th 04, 11:20 AM
Guy Alcala
thread.
Evan Williams
In message et, Evan
Williams writes
amount
propeller
a
Short answer... no.
increase.
just
T56
on the C-130?
more lift.
I expect Pete Stickney will be giving you his patented thrust vs. horsepower
lecture shortly, if he's not on vacation or otherwise occupied. If youre in a
hurry, you could do a google search restricted to this group with
as the author and "Maximum Speed of Airliner at Low
Altitude" as the subject, and you'll get one of his recent posts which
discusses this subject in some detail.
The short version is that propeller thrust = horsepower @ 375 mph. HP is
greater than thrust below that speed, less above.
Guy
Old July 20th 04, 01:03 PM
Evan Williams
snip
Thank you
horsepower
in a
Guy
Old July 21st 04, 05:05 AM
Peter Stickney
Guy Alcala writes:
thread.
Just back - I'll get to it tomorrow - right now I'm wading through the
"British Night Bombers vs. the P-38" thread.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
Old July 21st 04, 11:23 AM
Cub Driver
Guy, is this the same as saying that a turbojet's thrust in pounds at
375mph is the same as a horsepower rating for that engine?
Put another way: is a 3,000-lb thrust turbojet equivalent to a 3,000hp
recip at 375mph?
(I haven't been reading this thread either. Yesterday I discovered
that if I posted first, my newsreader downloaded all the new posts,
and if I then downloaded all the new posts (as I did) I wiped out the
day's work of all these brilliant people.)
all the best -- Dan Ford
email: (put Cubdriver in subject line)
The Warbird's Forum
www.warbirdforum.com
Expedition sailboat charters www.expeditionsail.com
Old July 22nd 04, 02:12 AM
Eunometic
"Evan Williams" wrote in message ink.net...
Evan Williams
Power = Speed x Thrust.
Power in Watts,
Speed in meters per second,
Thrust in Newtons (about 101 grams).
Thus a jet moving at 440mph (200m/sec) with a 2000kg (20,200N) jet
engine is equivalent to a 200 x 20,200 = 4040000 watts (4040kW,
5200hp).
Propellers are between 75% to 85% efficinet so we would have to add
about 25% to those figures to get the shaft horsepower equivalent.
Ofcrouse the equation gets a little silly (non linear) about Mach 0.66
or so as compressability reduces propeller efficiency.
Turboprops posses substantial jet thrust and inefficient engines in
terms of shaft power often perform better due to jet thrust in faster
aircraft.
The WW2 spitfire merlin possesed about 300lb (1330N) jet thrust. At
440mph (200m/s) and 75% propellor efficiency this equated to 353kw or
460hp. This is one reason NOT to use a turbo charger.
Maximum Speed of Airliner At Low Altitude Roger Helbig Military Aviation 26 June 22nd 04 04:57 PM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 07:03 AM
#1 Jet of World War II Christopher Military Aviation 203 September 1st 03 03:04 AM
Aircraft engine certification FAR's Corky Scott Home Built 4 July 25th 03 06:46 PM
