....as those applied to the Backfire and Fencer? I know of
anti-radiation white applied to the underside of nuclear bombers, but the reason of white leading edges on the Su-24 escaps me - seems 'anti'camouflage. Perhaps it helps in disguising the shape of the 'incoming' from visible/IR sensors on the ground? Thanks in advance for any explanation. TIA Bonehammer |
This is a total shot in the dark, but I remember puting tape on the leading
edges of F/A-18 wings in order to protect the paint. When the A/C flew a lot of low level sortes in dusty or sandy environments the tape would wear down fairly quickly. It was easier to replace tape than it was to repaint the A/C. Of course I'm probably wrong. I have a tendancy to look for simple solutions to complex problems. Evan Williams "Bonehammer" wrote in message om... ...as those applied to the Backfire and Fencer? I know of anti-radiation white applied to the underside of nuclear bombers, but the reason of white leading edges on the Su-24 escaps me - seems 'anti'camouflage. Perhaps it helps in disguising the shape of the 'incoming' from visible/IR sensors on the ground? Thanks in advance for any explanation. TIA Bonehammer |
Disruptiove camo works in odd ways sometimes. In World War 2 they did try
covering the leading edges of Catalina wings with spotlights, which were lit (By photo cell) to the same intensity as the background sky. Worked a trreat as well...Voila! 60 year oold stealth! regards, John "Bonehammer" wrote in message om... ...as those applied to the Backfire and Fencer? I know of anti-radiation white applied to the underside of nuclear bombers, but the reason of white leading edges on the Su-24 escaps me - seems 'anti'camouflage. Perhaps it helps in disguising the shape of the 'incoming' from visible/IR sensors on the ground? Thanks in advance for any explanation. TIA Bonehammer |
General Zinni on Sixty Minutes | WalterM140 | Military Aviation | 428 | July 1st 04 11:16 PM |
Did the Germans have the Norden bombsight? | Cub Driver | Military Aviation | 106 | May 12th 04 07:18 AM |
Germany Lost the War... So What? | robert arndt | Military Aviation | 55 | February 26th 04 08:51 AM |
How fast should an ADF point? | Ben Jackson | Instrument Flight Rules | 6 | November 21st 03 03:50 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
