Panel lights breaker pops
Old July 2nd 09, 02:58 PM posted to rec.aviation.owning
Steve - KDMW
Default Panel lights breaker pops
Has anyone seen this?...1974 Warrior panel lights don't come on, and
when I turn the rheostat past a certain point (almost full bright) the
panel lights breaker pops. I'm thinking it's the power transistor, at
least that's what I'm going to try first (along with cleaning the
rheostat) since it's the cheapest thing to do.
Steve
PA28-151
KDMW
Old July 2nd 09, 03:33 PM posted to rec.aviation.owning
vaughn[_2_]
"Steve - KDMW" wrote in message
Before you start blindly changing parts, troubleshoot your problem by
measuring the current through that circuit with an ammeter. If you have too
much current for that circuit, then figure out why. If the breaker is
popping too soon, then replace the breaker.
Another possible cause is a bad connection near the breaker heating up,
conducting heat into the breaker, and causing it to trip.
Vaughn
Old July 9th 09, 01:43 AM posted to rec.aviation.owning
Blanche
I did have a bad transistor that controls various lights in the
cherokee. I think I paid $4.00 for the transistor, and $65 in labor.
But, I also bought a complete set of 4 extra transistors because
I know they'll die - afterall, they were original 1969 equipment.
I'm astonished they lasted this long.
Old July 2nd 09, 05:44 PM posted to rec.aviation.owning
Tauno Voipio
Steve
PA28-151
KDMW
My bets on a genuine short circuit in the lights, maybe
a bad bulb. There is not enough current to pop the breaker
before the setting is nearly full.
Tauno Voipio
PA28RT-201T
EFHF
Old July 25th 09, 12:50 AM posted to rec.aviation.owning
Larry D. Cosby
Common problem on older Cherokee models. Chaffed wiring where it passes thru
bulkheads in wings or fuselage. Isolate one circuit at a time to pinpoint
correct wiring path to look at.
Larry
Steve
PA28-151
KDMW
Old July 25th 09, 06:01 PM posted to rec.aviation.owning
On Jul 24, 5:50 pm, "Larry D. Cosby" lcosby at knology dot net
It wasn't the nav lights that were popping the breaker; it was the
panel lights. If there's a short there, they shouldn't come on at all.
The easiest path would be to ground, not through the bulbs. My bet is
a bad breaker, or a corroded or burnt crimp terminal at the breaker.
The breaker's internal contacts oxidize with age and start making
resistance and heat that fools the bimetal thermal strip into popping.
The rheostat (potentiometer) carries only the tiny base current for
the transistor; flickering lights should be the result of a worn pot,
not a popped breaker. Unless, of course, it's a wirewound pot and the
wires are frayed and broken inside. Not likely, though. Wirewound pots
aren't common in the resistances used here and they cost too much.
Dan
Old July 25th 09, 07:59 PM posted to rec.aviation.owning
RST Engineering - JIm
That's unfortunately not the case, Dan. Everything Wichita turned out up
until the mid 60s used Ohmite wirewounds. Of course, they would burn out
right where the wire got the hottest ... where the resistance of the bulbs
and the resistance of the pot were the same. THis was almost always 10% or
so from the high side contact of the pot.
.. Wirewound pots
Dan
Old July 25th 09, 09:09 PM posted to rec.aviation.owning
Just looked up ... the suckers are running $25-30 at the wholesale
electronics suppliers. I don't want to know what they cost when they come
in a Beech box.
"RST Engineering - JIm" wrote in message
m...
or so from the high side contact of the pot.
. Wirewound pots
Dan
Old July 28th 09, 06:09 PM posted to rec.aviation.owning
Ross
in a Beech box.
m...
. Wirewound pots
Dan
I bought correct ones from aircraft salvage yards for $50 -$70 each. I
sure would have like to know the part number for a replacement.
Regards, Ross
C-172F 180HP
Sold
KSWI
Old July 28th 09, 06:08 PM posted to rec.aviation.owning
Ross
. Wirewound pots
Dan
That is exactly where my pot would burn out.
Regards, Ross
C-172F 180HP
Sold
KSWI
Instrument and panel lights in 152 TNap Owning 1 July 12th 06 04:23 PM
Panel lights failure in Piper WarriorII Piperflyer Owning 6 September 23rd 04 07:26 AM
Panel Lights - Need Help Barnyard BOb - Home Built 2 May 29th 04 07:51 PM
Panel Lights Dimmer MII Driver Home Built 3 April 3rd 04 01:56 AM
Premade master and circuit breaker panel Corky Scott Home Built 6 March 19th 04 02:18 PM
